Can Anyone Help??? Stuck with an extended generator... 84PT40!!!!
06-28-2007, 15:38
Hello.... I hope someone can help....
84 PT40 generator stuck open .... hydraulic leak from piston that pushes & pulls the generator tray open & closed.... how... or where do I add hydraulic fluid so that I can get the generator to slide back in??? Many.... many much appreciated thanks in advance.... family is supposed to be leaving town in the morning to attend a funeral.... Thank You Brian |
06-28-2007, 15:54
Brian,
That system is part of your front step/HWH leveler system. Make sure the reservoir under the entry step is full of ATF fluid & hopefully is will retract the generator. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T t3brian wrote: > Hello.... I hope someone can help.... > > 84 PT40 generator stuck open .... hydraulic leak from piston that > pushes & pulls the generator tray open & closed.... how... or where do > I add hydraulic fluid so that I can get the generator to slide back in??? > > Many.... many much appreciated thanks in advance.... family is > supposed to be leaving town in the morning to attend a funeral.... > > Thank You > Brian > > [Non-text portions of this message have been removed] |
06-28-2007, 16:03
Brian,
Sorry to hear about the funeral. Re the gen set hydraulic leak: Been there, done that. The seal is blown. NO big deal. Adding more fluid is pointless right now. To get going NOW, you just need to crawl under there and just pull the cotter key that holds in the pin on the back of the genset hydraulic ram. Then pull the pin and push the genset tray back in by hand (You may have to lift the genset ram up to clear the frame cross rail). When all the way in, lock the handset bar in the front. Make very sure it is secure and stays locked! You're good to go now. When you get back, you will then need to replace the seals in the ram. About a 20 minute job. To get the correct seals, unscrew the clevis end, on the end of the ram you disconnected and remove it. Then remove the cap on the end of the ram with a pair of water pump pliers. As I recall, there is a "wiper" seal in the cap and a hydraulic fluid seal in the cap. Take them to a good hydraulic shop to match up the replacements and reinstall them the way you took them out. Put everything back together and THEN add the hydraulic fluid (actually Dexron ATF) to the reservoir under the steps. Cycle the syetm a couple of times and you will be done. Mike Bulriss 1991 WB40 "Texas Minivan" VERY wet San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > Hello.... I hope someone can help.... > > 84 PT40 generator stuck open .... hydraulic leak from piston that > pushes & pulls the generator tray open & closed.... how... or where do > I add hydraulic fluid so that I can get the generator to slide back in??? > > Many.... many much appreciated thanks in advance.... family is > supposed to be leaving town in the morning to attend a funeral.... > > Thank You > Brian > |
06-28-2007, 17:36
OK!...THANK YOU SOOOOO MUCH!
I will do it in the morning and we will be on our way.... then worry about replacing the seal later! again.... THANK YOU! Brian --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Brian, > > Sorry to hear about the funeral. > > Re the gen set hydraulic leak: > Been there, done that. The seal is blown. NO big deal. Adding more > fluid is pointless right now. To get going NOW, you just need to > crawl under there and just pull the cotter key that holds in the pin > on the back of the genset hydraulic ram. Then pull the pin and push > the genset tray back in by hand (You may have to lift the genset ram > up to clear the frame cross rail). When all the way in, lock the > handset bar in the front. Make very sure it is secure and stays > locked! You're good to go now. > > When you get back, you will then need to replace the seals in the ram. > About a 20 minute job. To get the correct seals, unscrew the clevis > end, on the end of the ram you disconnected and remove it. Then > remove the cap on the end of the ram with a pair of water pump pliers. > As I recall, there is a "wiper" seal in the cap and a hydraulic fluid > seal in the cap. Take them to a good hydraulic shop to match up the > replacements and reinstall them the way you took them out. Put > everything back together and THEN add the hydraulic fluid (actually > Dexron ATF) to the reservoir under the steps. Cycle the syetm a > couple of times and you will be done. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > VERY wet San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > Hello.... I hope someone can help.... > > > > 84 PT40 generator stuck open .... hydraulic leak from piston that > > pushes & pulls the generator tray open & closed.... how... or where do > > I add hydraulic fluid so that I can get the generator to slide back > in??? > > > > Many.... many much appreciated thanks in advance.... family is > > supposed to be leaving town in the morning to attend a funeral.... > > > > Thank You > > Brian > > > |
06-28-2007, 18:21
OK.... I couldn't wait till the morning!
I just did what you mentioned.... I did have to remove both pins... slide the RAM out of the way.. and presto! I slid the generator into position and it is locked and ready to go! again.... THANK YOU SO MUCH! I really have not been able to participate in this forum and contribute to it's content as I could have.... self employeed .... family of 6 .... we are also foster parents.... and a wanderlodge newbe....... I will make time in the future to return to this forum that in only a few interactions with my questions... had made such a positive and supportive effect on our families well being! Thank You Brian! --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Brian, > > Sorry to hear about the funeral. > > Re the gen set hydraulic leak: > Been there, done that. The seal is blown. NO big deal. Adding more > fluid is pointless right now. To get going NOW, you just need to > crawl under there and just pull the cotter key that holds in the pin > on the back of the genset hydraulic ram. Then pull the pin and push > the genset tray back in by hand (You may have to lift the genset ram > up to clear the frame cross rail). When all the way in, lock the > handset bar in the front. Make very sure it is secure and stays > locked! You're good to go now. > > When you get back, you will then need to replace the seals in the ram. > About a 20 minute job. To get the correct seals, unscrew the clevis > end, on the end of the ram you disconnected and remove it. Then > remove the cap on the end of the ram with a pair of water pump pliers. > As I recall, there is a "wiper" seal in the cap and a hydraulic fluid > seal in the cap. Take them to a good hydraulic shop to match up the > replacements and reinstall them the way you took them out. Put > everything back together and THEN add the hydraulic fluid (actually > Dexron ATF) to the reservoir under the steps. Cycle the syetm a > couple of times and you will be done. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > VERY wet San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > Hello.... I hope someone can help.... > > > > 84 PT40 generator stuck open .... hydraulic leak from piston that > > pushes & pulls the generator tray open & closed.... how... or where do > > I add hydraulic fluid so that I can get the generator to slide back > in??? > > > > Many.... many much appreciated thanks in advance.... family is > > supposed to be leaving town in the morning to attend a funeral.... > > > > Thank You > > Brian > > > |
06-28-2007, 23:24
This is a sort of related response to the forth coming repair job.
I have found that a digital camera is the best mechanics friend you could have. Take pictures, with a flash for detail, of whatever it is you are going to repair in its unrepaired state. That way when you get ready to reassemble everything and get into trouble remembering how it all goes together, you can refer to the pictures. I have used my camera many times on different things that I have repaired and found it to be a blessing. Got me out of trouble many times. You can't take too many pictures either. Take them at every stage of the repair. Regards, Ron Thompson Waller, Tx. 1995 42' BB mbulriss <mbulriss@...> wrote: Brian, Sorry to hear about the funeral. Re the gen set hydraulic leak: Been there, done that. The seal is blown. NO big deal. Adding more fluid is pointless right now. To get going NOW, you just need to crawl under there and just pull the cotter key that holds in the pin on the back of the genset hydraulic ram. Then pull the pin and push the genset tray back in by hand (You may have to lift the genset ram up to clear the frame cross rail). When all the way in, lock the handset bar in the front. Make very sure it is secure and stays locked! You're good to go now. When you get back, you will then need to replace the seals in the ram. About a 20 minute job. To get the correct seals, unscrew the clevis end, on the end of the ram you disconnected and remove it. Then remove the cap on the end of the ram with a pair of water pump pliers. As I recall, there is a "wiper" seal in the cap and a hydraulic fluid seal in the cap. Take them to a good hydraulic shop to match up the replacements and reinstall them the way you took them out. Put everything back together and THEN add the hydraulic fluid (actually Dexron ATF) to the reservoir under the steps. Cycle the syetm a couple of times and you will be done. Mike Bulriss 1991 WB40 "Texas Minivan" VERY wet San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > Hello.... I hope someone can help.... > > 84 PT40 generator stuck open .... hydraulic leak from piston that > pushes & pulls the generator tray open & closed.... how... or where do > I add hydraulic fluid so that I can get the generator to slide back in??? > > Many.... many much appreciated thanks in advance.... family is > supposed to be leaving town in the morning to attend a funeral.... > > Thank You > Brian > Ron Thompson Waller, Tx. 1995 42' Blue Bird [Non-text portions of this message have been removed] |
06-29-2007, 01:58
You are most welcome Brian. Remember to keep a good eye on the genset
locking bar to make sure it stays solidly locked. You could even put a bungee cord on it for extra peace of mind! If the genset slide bar lock comes unlocked with the ram disconnected, there is nothing to keep the genset tray from sliding out on a stop. NOT a good deal! ;^) Mike Bulriss 1991 WB40 "Texas Minivan" Soggy San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > OK.... I couldn't wait till the morning! > > I just did what you mentioned.... I did have to remove both pins... > slide the RAM out of the way.. and presto! I slid the generator into > position and it is locked and ready to go! > > again.... THANK YOU SO MUCH! > > I really have not been able to participate in this forum and > contribute to it's content as I could have.... self employeed .... > family of 6 .... we are also foster parents.... and a wanderlodge > newbe....... > > I will make time in the future to return to this forum that in only a > few interactions with my questions... had made such a positive and > supportive effect on our families well being! > > Thank You > > Brian! > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Brian, > > > > Sorry to hear about the funeral. > > > > Re the gen set hydraulic leak: > > Been there, done that. The seal is blown. NO big deal. Adding more > > fluid is pointless right now. To get going NOW, you just need to > > crawl under there and just pull the cotter key that holds in the pin > > on the back of the genset hydraulic ram. Then pull the pin and push > > the genset tray back in by hand (You may have to lift the genset ram > > up to clear the frame cross rail). When all the way in, lock the > > handset bar in the front. Make very sure it is secure and stays > > locked! You're good to go now. > > > > When you get back, you will then need to replace the seals in the ram. > > About a 20 minute job. To get the correct seals, unscrew the clevis > > end, on the end of the ram you disconnected and remove it. Then > > remove the cap on the end of the ram with a pair of water pump pliers. > > As I recall, there is a "wiper" seal in the cap and a hydraulic fluid > > seal in the cap. Take them to a good hydraulic shop to match up the > > replacements and reinstall them the way you took them out. Put > > everything back together and THEN add the hydraulic fluid (actually > > Dexron ATF) to the reservoir under the steps. Cycle the syetm a > > couple of times and you will be done. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > VERY wet San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > > > Hello.... I hope someone can help.... > > > > > > 84 PT40 generator stuck open .... hydraulic leak from piston that > > > pushes & pulls the generator tray open & closed.... how... or where do > > > I add hydraulic fluid so that I can get the generator to slide back > > in??? > > > > > > Many.... many much appreciated thanks in advance.... family is > > > supposed to be leaving town in the morning to attend a funeral.... > > > > > > Thank You > > > Brian > > > > > > |
06-29-2007, 04:47
Mike...my 86 PT38 doesn't have a manual lock bar. Should it? I have
wondered what the "safety" was if the ram failed... Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > You are most welcome Brian. Remember to keep a good eye on the genset > locking bar to make sure it stays solidly locked. You could even put > a bungee cord on it for extra peace of mind! If the genset slide bar > lock comes unlocked with the ram disconnected, there is nothing to > keep the genset tray from sliding out on a stop. NOT a good deal! ;^) > > Mike Bulriss > 1991 WB40 "Texas Minivan" > Soggy San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > OK.... I couldn't wait till the morning! > > > > I just did what you mentioned.... I did have to remove both pins... > > slide the RAM out of the way.. and presto! I slid the generator into > > position and it is locked and ready to go! > > > > again.... THANK YOU SO MUCH! > > > > I really have not been able to participate in this forum and > > contribute to it's content as I could have.... self employeed .... > > family of 6 .... we are also foster parents.... and a wanderlodge > > newbe....... > > > > I will make time in the future to return to this forum that in only a > > few interactions with my questions... had made such a positive and > > supportive effect on our families well being! > > > > Thank You > > > > Brian! > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > > > Brian, > > > > > > Sorry to hear about the funeral. > > > > > > Re the gen set hydraulic leak: > > > Been there, done that. The seal is blown. NO big deal. Adding more > > > fluid is pointless right now. To get going NOW, you just need to > > > crawl under there and just pull the cotter key that holds in the pin > > > on the back of the genset hydraulic ram. Then pull the pin and push > > > the genset tray back in by hand (You may have to lift the genset ram > > > up to clear the frame cross rail). When all the way in, lock the > > > handset bar in the front. Make very sure it is secure and stays > > > locked! You're good to go now. > > > > > > When you get back, you will then need to replace the seals in the ram. > > > About a 20 minute job. To get the correct seals, unscrew the clevis > > > end, on the end of the ram you disconnected and remove it. Then > > > remove the cap on the end of the ram with a pair of water pump pliers. > > > As I recall, there is a "wiper" seal in the cap and a hydraulic fluid > > > seal in the cap. Take them to a good hydraulic shop to match up the > > > replacements and reinstall them the way you took them out. Put > > > everything back together and THEN add the hydraulic fluid (actually > > > Dexron ATF) to the reservoir under the steps. Cycle the syetm a > > > couple of times and you will be done. > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > VERY wet San Antonio, TX > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" wrote: > > > > > > > > Hello.... I hope someone can help.... > > > > > > > > 84 PT40 generator stuck open .... hydraulic leak from piston that > > > > pushes & pulls the generator tray open & closed.... how... or > where do > > > > I add hydraulic fluid so that I can get the generator to slide back > > > in??? > > > > > > > > Many.... many much appreciated thanks in advance.... family is > > > > supposed to be leaving town in the morning to attend a funeral.... > > > > > > > > Thank You > > > > Brian > > > > > > > > > > |
06-29-2007, 06:03
Scott,
I don't known the answer to that. I thought all the early/mid 80s with hydraulic rams had the manual lock. Looks like I was wrong in that assumption. Someone with another 86 will have to address your question. Seems like if the ram failed stuck out and you had to disconnect it to continue on a trip, you would need a chain/strap or come-along to hold the tray in place safely without a manual lock? Hmmmm, I'm going to crawl under the 91 this weekend and take a quick look at how that tray extender works, assuming the rain stops. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX - now *really* humid! --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Mike...my 86 PT38 doesn't have a manual lock bar. Should it? I have > wondered what the "safety" was if the ram failed... > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > You are most welcome Brian. Remember to keep a good eye on the > genset > > locking bar to make sure it stays solidly locked. You could even > put > > a bungee cord on it for extra peace of mind! If the genset slide > bar > > lock comes unlocked with the ram disconnected, there is nothing to > > keep the genset tray from sliding out on a stop. NOT a good > deal! ;^) > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > Soggy San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > > > OK.... I couldn't wait till the morning! > > > > > > I just did what you mentioned.... I did have to remove both > pins... > > > slide the RAM out of the way.. and presto! I slid the generator > into > > > position and it is locked and ready to go! > > > > > > again.... THANK YOU SO MUCH! > > > > > > I really have not been able to participate in this forum and > > > contribute to it's content as I could have.... self employeed .... > > > family of 6 .... we are also foster parents.... and a wanderlodge > > > newbe....... > > > > > > I will make time in the future to return to this forum that in > only a > > > few interactions with my questions... had made such a positive and > > > supportive effect on our families well being! > > > > > > Thank You > > > > > > Brian! > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > > > > > Brian, > > > > > > > > Sorry to hear about the funeral. > > > > > > > > Re the gen set hydraulic leak: > > > > Been there, done that. The seal is blown. NO big deal. > Adding more > > > > fluid is pointless right now. To get going NOW, you just need > to > > > > crawl under there and just pull the cotter key that holds in > the pin > > > > on the back of the genset hydraulic ram. Then pull the pin and > push > > > > the genset tray back in by hand (You may have to lift the > genset ram > > > > up to clear the frame cross rail). When all the way in, lock > the > > > > handset bar in the front. Make very sure it is secure and stays > > > > locked! You're good to go now. > > > > > > > > When you get back, you will then need to replace the seals in > the ram. > > > > About a 20 minute job. To get the correct seals, unscrew the > clevis > > > > end, on the end of the ram you disconnected and remove it. Then > > > > remove the cap on the end of the ram with a pair of water pump > pliers. > > > > As I recall, there is a "wiper" seal in the cap and a > hydraulic fluid > > > > seal in the cap. Take them to a good hydraulic shop to match > up the > > > > replacements and reinstall them the way you took them out. Put > > > > everything back together and THEN add the hydraulic fluid > (actually > > > > Dexron ATF) to the reservoir under the steps. Cycle the syetm a > > > > couple of times and you will be done. > > > > > > > > Mike Bulriss > > > > 1991 WB40 "Texas Minivan" > > > > VERY wet San Antonio, TX > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > wrote: > > > > > > > > > > Hello.... I hope someone can help.... > > > > > > > > > > 84 PT40 generator stuck open .... hydraulic leak from piston > that > > > > > pushes & pulls the generator tray open & closed.... how... or > > where do > > > > > I add hydraulic fluid so that I can get the generator to > slide back > > > > in??? > > > > > > > > > > Many.... many much appreciated thanks in advance.... family is > > > > > supposed to be leaving town in the morning to attend a > funeral.... > > > > > > > > > > Thank You > > > > > Brian > > > > > > > > > > > > > > > |
06-29-2007, 08:22
On 6/29/07, mbulriss <mbulriss@...> wrote:
> > Scott, > > I don't known the answer to that. I thought all the early/mid 80s > with hydraulic rams had the manual lock. Looks like I was wrong in > that assumption. Someone with another 86 will have to address your > question. Scott, '86 PT-40 here. I have a lock. Big black lever on the front. I would expect you should have one, too. Do you have the corresponding dash light?? I have a red light on the dash that will come on if the gen tray is unlocked. The digitel will also complain about it. I'd find out why you don't have one - previous owner modification is my guess - and get it fixed. I'd imagine this is a critical safety feature to keep the genset in the coach. You'd hate to lose the entire unit into the back of a compact if you had to come to a quick stop and the hydraulics decided not to hold it. -Ryan '86 PT-40 8V92 Tri-Cities, WA |
