Filter List for '95 WL with DD Series 60 engine
06-30-2007, 05:27
As a couple of folks requested, following is the filter list for the
'95 (and probably several later years) with the Detroit Diesel Series
60 engine and the PowerTech 15kw generator. This will align if you
apply a fixed width font such as Courier.
PowerTech PTS MH-15 Generator (with Kubota Engine)
(Powertech part no) NAPA WIX Fram
Oil filter 70000-32091 1191 51191 3569
Fuel Filter 70000-43081 3390 33390 N/A
Air Filter 70000-11080 6296 46296
OEM: Donaldson DuraLite Air Cleaner ECC (type), Part # C65002
Oil: Use 10w30 oil. Takes 2.4 gallons plus oil filter.
Use an appropriate heavy duty Diesel type.
Detroit Diesel Series 60 Engine
Racor (Model 1000FG) Use element 2020TM -- 10 micron.
DD# AC-Delco WIX
Fuel Filter (spin-on type)
Primary 25014275 TP915D 22-25 micron 33118
Secondary 25014342 TP916D 6-8 micron 33120
Oil Filter 25414505 PF2100 51971
Requires 2 per change
Oil: Use 15w40. (Do not use single weight oils).
Capacity 26 quarts to low mark
32 quarts to full mark
40 quarts when oil filters are changed.
Note: NAPA part numbers are usually the same as the last four digits
of the WIX number.
El Sobrante CA
aeonix1@...
06-30-2007, 06:08
Pete, thanks for that filter list. You are a man of your word and you can't ask
for anything better.
Ron Thompson
Waller, Tx.
1995 42' Wanderlodge
Bluebird, WBDA
Pete Masterson wrote: As a
DD# AC-Delco WIX
of the WIX number.
El Sobrante CA
aeonix1@...
Ron Thompson
Waller, Tx.
1995 42' Blue Bird
