Yanmar generator fuel usage
06-30-2007, 06:10
Anyone know what to expect on an hourly fuem usage from the Yanmar (PT)
generator?
Scott Forman
86 PT38
Memphis
06-30-2007, 06:17
Scott:
Yammar and Perkins are very similar engines. both have aprox the same
displacement and run at 1800 rpm's so the usage will be very close to what
the Perkins is.
>generator?
>Scott Forman
>86 PT38
>Memphis
06-30-2007, 09:58
From memory, I think the book says 1.2 GPH @ full load, .7 GPH at 50% load
(or something very close to that...). It's in your owners manual, if you have
one. If you really have a "need to know", I'll go pull the manual for
you....
Kevin McKeown\
Yorba Linda, CA
1986 38' PT
06-30-2007, 11:21
I have the numbers for the Power tech 10 KW in my coach -- which may
be close to your usage.
25% load - .256 gal hr
50% load - .412 gal hr
75% load - .912 gal hr
100% load - 1.00 gal hr
Dan
94 BB BMC 37' NM
(PT)
> generator?
> Scott Forman
> 86 PT38
> Memphis
06-30-2007, 11:38
Wow, that's pretty miserly, I hope mine is that efficient.
Scott
--- In WanderlodgeForum@yahoogroups.com, "ac7880"
may
> Dan
> 94 BB BMC 37' NM
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
Yanmar
> (PT)
> > generator?
> > Scott Forman
> > 86 PT38
> > Memphis
06-30-2007, 12:20
The 15 kw PowerTech generator in my coach uses about 1/2 to 3/4
gallon per hour depending on load (rated up to 1 gpm at 100% load).
So, yes, they're mostly pretty efficient.
El Sobrante CA
aeonix1@...
> Scott
> may
>> Dan
>> 94 BB BMC 37' NM
> Yanmar
>> (PT)
>>> generator?
>>> Scott Forman
>>> 86 PT38
>>> Memphis
> Yahoo! Groups Links
