Engine oil temp.
07-01-2007, 04:29
Engine oil temp.
When I bought my PT36 in April the engine oil temp guage was inop.
I have replaced that guage with a working one and I see the engine oil temp running at 230 degrees. I believe that is close to the upper limit. This temperature is reached driving local freeways with little congestion and no grades. Do I have something to be concerned about? You folks who have similiar engines, what is your normal engine oil temp? Coolant temp runs 185 to 195. Art Weatherly Riverside Ca. '85 PT36 |
07-01-2007, 05:06
Engine oil temp.
I just looked in my Detroit manual last night and found the oil range for my
8v92TAC engine. 200-250 for mine. If you know what engine and turbo you have I can look it up and tell you what it says for you engine. Was the new gauge the same index as the old gauge? If not, you need to replace the sender with a compatible version. As for actual temperatures, mine routinely runs 220 at 1950 rpm and 67 mph. As water temperature increases, so does the oil temp. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ---- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 01, 2007 11:29 AM Subject: [WanderlodgeForum] Engine oil temp. When I bought my PT36 in April the engine oil temp guage was inop. I have replaced that guage with a working one and I see the engine oil temp running at 230 degrees. I believe that is close to the upper limit. This temperature is reached driving local freeways with little congestion and no grades. Do I have something to be concerned about? You folks who have similiar engines, what is your normal engine oil temp? Coolant temp runs 185 to 195. Art Weatherly Riverside Ca. '85 PT36 [Non-text portions of this message have been removed] |
07-01-2007, 05:41
Engine oil temp.
The replacment guage is identical - same indexing, same ID numbers.
It came out of an '84 FC35 the previous owner of mine was parting out. Art Weatherly Riverside Ca. '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > I just looked in my Detroit manual last night and found the oil range for my 8v92TAC engine. 200-250 for mine. If you know what engine and turbo you have I can look it up and tell you what it says for you engine. > Was the new gauge the same index as the old gauge? If not, you need to replace the sender with a compatible version. As for actual temperatures, mine routinely runs 220 at 1950 rpm and 67 mph. As water temperature increases, so does the oil temp. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ---- > From: amweath > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, July 01, 2007 11:29 AM > Subject: [WanderlodgeForum] Engine oil temp. > > > When I bought my PT36 in April the engine oil temp guage was inop. > I have replaced that guage with a working one and I see the engine > oil temp running at 230 degrees. I believe that is close to the upper > limit. This temperature is reached driving local freeways with > little congestion and no grades. Do I have something to be concerned > about? You folks who have similiar engines, what is your normal engine > oil temp? Coolant temp runs 185 to 195. > > Art Weatherly > Riverside Ca. > '85 PT36 > > > > > > [Non-text portions of this message have been removed] > |
07-01-2007, 11:13
Engine oil temp.
My 8V92's usual oil temp is 230-235....water temp is around 190 +/- 5
degrees, even when under a load. If it starts to climb, I turn on the fan overide, and it comes right back down. Kevin Mc YL CA 86 38 pt 8v92 ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-01-2007, 12:10
Engine oil temp.
You can dial in ww2.tflx.com/tech/html and follow the trouble shooting guide for
Teleflex gauge systems and determine if the system is working properly. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 01, 2007 12:41 PM Subject: [WanderlodgeForum] Re: Engine oil temp. The replacment guage is identical - same indexing, same ID numbers. It came out of an '84 FC35 the previous owner of mine was parting out. Art Weatherly Riverside Ca. '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > I just looked in my Detroit manual last night and found the oil range for my 8v92TAC engine. 200-250 for mine. If you know what engine and turbo you have I can look it up and tell you what it says for you engine. > Was the new gauge the same index as the old gauge? If not, you need to replace the sender with a compatible version. As for actual temperatures, mine routinely runs 220 at 1950 rpm and 67 mph. As water temperature increases, so does the oil temp. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ---- > From: amweath > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, July 01, 2007 11:29 AM > Subject: [WanderlodgeForum] Engine oil temp. > > > When I bought my PT36 in April the engine oil temp guage was inop. > I have replaced that guage with a working one and I see the engine > oil temp running at 230 degrees. I believe that is close to the upper > limit. This temperature is reached driving local freeways with > little congestion and no grades. Do I have something to be concerned > about? You folks who have similiar engines, what is your normal engine > oil temp? Coolant temp runs 185 to 195. > > Art Weatherly > Riverside Ca. > '85 PT36 > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
07-02-2007, 02:42
Engine oil temp.
Art,
I cleaned my radiators and it has brought down my temps abt. 7 degrees on avgerage. Howard T., Ga., 86 PT40 > > From: "amweath" > Date: 2007/07/01 Sun PM 12:29:44 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Engine oil temp. > > When I bought my PT36 in April the engine oil temp guage was inop. > I have replaced that guage with a working one and I see the engine > oil temp running at 230 degrees. I believe that is close to the upper > limit. This temperature is reached driving local freeways with > little congestion and no grades. Do I have something to be concerned > about? You folks who have similiar engines, what is your normal engine > oil temp? Coolant temp runs 185 to 195. > > > Art Weatherly > Riverside Ca. > '85 PT36 > > > |
07-02-2007, 03:04
Engine oil temp.
Thanks everyone for your responses. I feel much more comfortable now
with the temps I'm running. Art Weatherly Riverside Ca. '85 PT36 |
07-02-2007, 03:09
Engine oil temp.
Howard
You said radiators, plural. Is there another one besides the main engine and generator radiator. Art Weatherly Riverside Ca. '85 PT36 --- In WanderlodgeForum@yahoogroups.com, > > Art, > I cleaned my radiators and it has brought down my temps abt. 7 degrees on avgerage. > Howard T., Ga., 86 PT40 > > > > > > From: "amweath" > > Date: 2007/07/01 Sun PM 12:29:44 EDT > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Engine oil temp. > > > > When I bought my PT36 in April the engine oil temp guage was inop. > > I have replaced that guage with a working one and I see the engine > > oil temp running at 230 degrees. I believe that is close to the upper > > limit. This temperature is reached driving local freeways with > > little congestion and no grades. Do I have something to be concerned > > about? You folks who have similiar engines, what is your normal engine > > oil temp? Coolant temp runs 185 to 195. > > > > > > Art Weatherly > > Riverside Ca. > > '85 PT36 > > > > > > > |
07-02-2007, 09:30
Engine oil temp.
Art,
One for the transmission mounted on engine side of main engine radiator. I pressure washed with a good brand of cleaner being careful not to damage hoses or radiators. Howard T., Sowega., 86 PT40 > > From: "amweath" > Date: 2007/07/02 Mon AM 11:09:03 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Engine oil temp. > > Howard > > You said radiators, plural. Is there another one besides the main > engine and generator radiator. > > Art Weatherly > Riverside Ca. > '85 PT36 > --- In WanderlodgeForum@yahoogroups.com, > > > > Art, > > I cleaned my radiators and it has brought down my temps abt. 7 > degrees on avgerage. > > Howard T., Ga., 86 PT40 > > > > > > > > > > From: "amweath" > > > Date: 2007/07/01 Sun PM 12:29:44 EDT > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Engine oil temp. > > > > > > When I bought my PT36 in April the engine oil temp guage was > inop. > > > I have replaced that guage with a working one and I see the > engine > > > oil temp running at 230 degrees. I believe that is close to the > upper > > > limit. This temperature is reached driving local freeways with > > > little congestion and no grades. Do I have something to be > concerned > > > about? You folks who have similiar engines, what is your normal > engine > > > oil temp? Coolant temp runs 185 to 195. > > > > > > > > > Art Weatherly > > > Riverside Ca. > > > '85 PT36 > > > > > > > > > > > > > > > |
