Flooring
07-01-2007, 04:57
Flooring
Pete- bring your coach up here. I have been installing since 1972. We can
glue your cork or let her float. Done it both ways.
83PT40
Livingston, Mt
07-01-2007, 04:58
Flooring
Kerry- yes. Currently we- Bim Burt and I are installing floorcovering in his
91WLWB.
83PT40
Livingston, Mt
07-01-2007, 05:42
Flooring
I'm considering replacing the flooring (at least in the forward area)
with cork flooring material. It comes in glue down and floating
varieties. It strikes me that glued floor would be the proper choice
for this application -- but does floating floor work? Also, (if
there's any flooring experts on the list) if I like a floating-type
floor, can it be glued in place. While the idea of the floating floor
is to allow it to expand and contract with temperature changes, will
the relatively small area (less than 200 square feet) of the coach
have much need for expansion?
Any comments will be appreciated.
(Also, any recommendations for an installer?)
El Sobrante CA
aeonix1@...
07-01-2007, 05:55
Flooring
Isn't Ernie a floor man?
Kerry
82 FC 35
Denver
> Pete Masterson
> El Sobrante CA
> aeonix1@...
07-01-2007, 09:45
Flooring
It can be installed both ways. Bluebird floors are rock solid and if the product
does not butt to the exterior walls expansion, contraction and deflection should
not be a problem. My personal preference would be to glue it down.
Leroy Eckert
1990WB-40"Smoke N Mirrors"
Niceville, FL
To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com
Sent: Sunday, July 01, 2007 12:42 PM
Subject: [WanderlodgeForum] Flooring
El Sobrante CA
aeonix1@...
07-01-2007, 10:08
Flooring
Hi Ginger- cork is great. Absorbs sound, and looks classy at the same time.
Wears well, also. Of course, with any material you install, the best
preventative against dirt is a good throw rug, either on the ground, or just as
you
step in the coach. Don't forget- this is a natural material, and like wool,
will have variations in color.
83PT40
Livingston, Mt
07-01-2007, 10:40
Flooring
Ernie,
I really like the look of cork. How do you feel about it in an RV
as compared with other hard materials?
Ginger
BB wannabee
We can
> Ernie Ekberg
> 83PT40
> Livingston, Mt
http://www.aol.com.
07-01-2007, 13:07
Flooring
I floated the hardwood floors in our previous 'Bird, worked fine. The
wood was glued to a thin rubber sheeting. I don't recall the name of the
rubber product, but if anyone is interested I'll stop by the store and
ask.
Curt Sprenger
Anaheim Hills, Calif.
> the product does not butt to the exterior walls expansion, contraction
> and deflection should not be a problem. My personal preference would
> be to glue it down.
> Leroy Eckert
> Niceville, FL
> From: Pete Masterson
> Pete Masterson
> El Sobrante CA
> aeonix1@...
07-01-2007, 14:34
Flooring
Cork is flexible material, great for a motorhome imo. It can also be resurfaced
if necessary. Sand is not your friend. That goes for carpet, wood, laminate,
engineered wood, cork, marble and over a long period of time granite. Porcelain
tile is pretty @#$% tough but difficult to deal with at installation.
Texture and color variations in natural material are part of the beauty of the
end result.
If one wants a floor without character, Home Depot University carries it.
Leroy Eckert
1990 WB-40 "Smoke N Mirrors'
Niceville, FL
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
Sent: Sunday, July 01, 2007 9:08 PM
Subject: Re: [WanderlodgeForum] Re: Flooring
as you
83PT40
Livingston, Mt
07-01-2007, 20:12
Flooring
I had some granite cut to fit my entry steps. Too slick, my poodles would
not step on the stuff. It looked good- but removed it and installed black rubber
treads. With the stainless risers, looks very stylish.
83PT40
Livingston, Mt
