Water control valve for icemaker on 82 FC?
07-03-2007, 06:00
Can anyone tell me where the water control valve is for the icemaker on an 82
FC? I've never used the icemaker and decided to use it on my next trip. I can see the plastic line behind the panel at the bottom of the icemaker but I can't see where the line goes behind the icemaker or under the sink. I assume there is a valve to control the water supply. Kerry 82 FC 35 Denver |
07-03-2007, 15:53
My 82 has no valve. There is a tee connection under the sink area where the
plastic line is tied in. The line goes under the floor and comes up behind the ice maker. To get the ice maker going turn it on and put a little water in the ice tray. If everything works, the ice will start coming out automatically. Jim 82 FC From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Tuesday, July 03, 2007 11:01 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Water control valve for icemaker on 82 FC? Can anyone tell me where the water control valve is for the icemaker on an 82 FC? I've never used the icemaker and decided to use it on my next trip. I can see the plastic line behind the panel at the bottom of the icemaker but I can't see where the line goes behind the icemaker or under the sink. I assume there is a valve to control the water supply. Kerry 82 FC 35 Denver [Non-text portions of this message have been removed] |
