No Water Pressure
07-04-2007, 09:15
No Water Pressure
I am still trying to get some water. I have checked out the pump. One
of the 1/2 inch nylon connectors was broken on the pump.I replaced that. When you switch the pump on it seems to have good pressure as water lashes out of the pump hose. BUT when I connect it all back up there is no water in any of the taps? I have bypassed one of the filters the metal filter with the valve on top. Still no water, can anyone help hoping to have a shower tonight! Hope you all have a safe and fun Independence Day. 1982 FC-35 "Perfect Weekend" currently in Crestline CA. |
07-04-2007, 09:25
No Water Pressure
Check your shore water "fill" switch, to be sure it's in the "off"
position? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. jmoorelewy wrote: > I am still trying to get some water. I have checked out the pump. One > of the 1/2 inch nylon connectors was broken on the pump.I replaced > that. When you switch the pump on it seems to have good pressure as > water lashes out of the pump hose. BUT when I connect it all back up > there is no water in any of the taps? I have bypassed one of the > filters the metal filter with the valve on top. Still no water, can > anyone help hoping to have a shower tonight! > > Hope you all have a safe and fun Independence Day. > > 1982 FC-35 "Perfect Weekend" currently in Crestline CA. > > |
07-04-2007, 10:38
No Water Pressure
The fill switch is set to off? Is there a relay I can check or clean
it sure seems like the system is switched off in some way. --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Check your shore water "fill" switch, to be sure it's in the "off" > position? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > jmoorelewy wrote: > > > I am still trying to get some water. I have checked out the pump. One > > of the 1/2 inch nylon connectors was broken on the pump.I replaced > > that. When you switch the pump on it seems to have good pressure as > > water lashes out of the pump hose. BUT when I connect it all back up > > there is no water in any of the taps? I have bypassed one of the > > filters the metal filter with the valve on top. Still no water, can > > anyone help hoping to have a shower tonight! > > > > Hope you all have a safe and fun Independence Day. > > > > 1982 FC-35 "Perfect Weekend" currently in Crestline CA. > > > > > |
07-04-2007, 19:03
No Water Pressure
The Sporlan Valve may have junk in it. There are write ups on the forums
on how to clean a Sporlan Valve. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. jmoorelewy wrote: > > The fill switch is set to off? Is there a relay I can check or clean > it sure seems like the system is switched off in some way. > > --- In WanderlodgeForum@yahoogroups.com > > > > > > Check your shore water "fill" switch, to be sure it's in the "off" > > position? > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > jmoorelewy wrote: > > > > > I am still trying to get some water. I have checked out the pump. One > > > of the 1/2 inch nylon connectors was broken on the pump.I replaced > > > that. When you switch the pump on it seems to have good pressure as > > > water lashes out of the pump hose. BUT when I connect it all back up > > > there is no water in any of the taps? I have bypassed one of the > > > filters the metal filter with the valve on top. Still no water, can > > > anyone help hoping to have a shower tonight! > > > > > > Hope you all have a safe and fun Independence Day. > > > > > > 1982 FC-35 "Perfect Weekend" currently in Crestline CA. > > > > > > > > > > |
07-05-2007, 04:19
No Water Pressure
Ok thanks for the help, I cleaned the Sporlan valve and the water
works now. I have three new problems: 1. No shower water, cant seem to even turn on the shower? There is very little movement in the controls. 2. The battery low voltage buzzer keeps going off. we are on shore power. 3. Ice maker, turned it on, it there a seperate tap for water to the ice maker. Thanks for all the help --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > The Sporlan Valve may have junk in it. There are write ups on the forums > on how to clean a Sporlan Valve. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > jmoorelewy wrote: > > > > > The fill switch is set to off? Is there a relay I can check or clean > > it sure seems like the system is switched off in some way. > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Check your shore water "fill" switch, to be sure it's in the "off" > > > position? > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > jmoorelewy wrote: > > > > > > > I am still trying to get some water. I have checked out the pump. One > > > > of the 1/2 inch nylon connectors was broken on the pump.I replaced > > > > that. When you switch the pump on it seems to have good pressure as > > > > water lashes out of the pump hose. BUT when I connect it all back up > > > > there is no water in any of the taps? I have bypassed one of the > > > > filters the metal filter with the valve on top. Still no water, can > > > > anyone help hoping to have a shower tonight! > > > > > > > > Hope you all have a safe and fun Independence Day. > > > > > > > > 1982 FC-35 "Perfect Weekend" currently in Crestline CA. > > > > > > > > > > > > > > > > |
07-05-2007, 05:35
No Water Pressure
My icemaker has a quarter inch plastic water line with a small T shutoff
valve. It is located under the sink which is next to the Icemaker On 05/07/07, jmoorelewy > > Ok thanks for the help, I cleaned the Sporlan valve and the water > works now. > > I have three new problems: > > 1. No shower water, cant seem to even turn on the shower? There is > very little movement in the controls. > > 2. The battery low voltage buzzer keeps going off. we are on shore power. > > 3. Ice maker, turned it on, it there a seperate tap for water to the > ice maker. > > Thanks for all the help > > --- In WanderlodgeForum@yahoogroups.com > Curt Sprenger > > > > > The Sporlan Valve may have junk in it. There are write ups on the > forums > > on how to clean a Sporlan Valve. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > jmoorelewy wrote: > > > > > > > > The fill switch is set to off? Is there a relay I can check or clean > > > it sure seems like the system is switched off in some way. > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > Check your shore water "fill" switch, to be sure it's in the "off" > > > > position? > > > > > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > jmoorelewy wrote: > > > > > > > > > I am still trying to get some water. I have checked out the > pump. One > > > > > of the 1/2 inch nylon connectors was broken on the pump.I replaced > > > > > that. When you switch the pump on it seems to have good > pressure as > > > > > water lashes out of the pump hose. BUT when I connect it all > back up > > > > > there is no water in any of the taps? I have bypassed one of the > > > > > filters the metal filter with the valve on top. Still no > water, can > > > > > anyone help hoping to have a shower tonight! > > > > > > > > > > Hope you all have a safe and fun Independence Day. > > > > > > > > > > 1982 FC-35 "Perfect Weekend" currently in Crestline CA. > > > > > > > > > > > > > > > > > > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
