Trip to PA
07-05-2007, 02:52
Trip to PA
Hi all,
I have just returned from a trip to southern PA, having to climb a few mountains... I was experiencing high oil temps in the 250* range, just a guess as the Gage reads 230* and then 320* it was somewhere in the middle... with the water temps in the 190's... pyro temps running @ 950*... I am running 5-40 delvac synthetic... I would think that the temps would be lower with the synthetic... Is it possible the oil cooler could not be working properly??? I have been turning the fan override on when the water temp gets to 190* which brings the oil temps down slowly... What are all your opinions as to a fix??? Also, while parked at a CG with the jacks lowered and set up for a couple of days the left rear jack had completely returned to its nesting position... What would cause this to happen??? All responses appreciated Sea Ya Larry NYC 84 35FCSB ________________________________________________________________________________\ ____ Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center. http://autos.yahoo.com/green_center/ [Non-text portions of this message have been removed] |
07-05-2007, 04:41
Trip to PA
i was under the impression that synthetic oils would not necessarily run cooler
but continue to perform their function at higher temperatures? What are the CAT parameters for oil temperature on your engine? You have piston oil coolers so I would think that with a steady pyrometer reading of 950, you would see pretty high oil temperatures. I don't know how the CAT oil cooler system works, but my Mercedes has a thermostat in the oil cooling system that opens when the oil reaches a temperature which requires cooling. Are these temperatures a new development? Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Larry > > Hi all, > I have just returned from a trip to southern PA, having to climb a few mountains... I was experiencing high oil temps in the 250* range, just a guess as the Gage reads 230* and then 320* it was somewhere in the middle... with the water temps in the 190's... pyro temps running @ 950*... I am running 5-40 delvac synthetic... I would think that the temps would be lower with the synthetic... Is it possible the oil cooler could not be working properly??? I have been turning the fan override on when the water temp gets to 190* which brings the oil temps down slowly... What are all your opinions as to a fix??? > Also, while parked at a CG with the jacks lowered and set up for a couple of days the left rear jack had completely returned to its nesting position... What would cause this to happen??? > All responses appreciated > > Sea Ya > Larry > NYC > 84 35FCSB > > > > > ________________________________________________________________________________\ ____ > Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center. > http://autos.yahoo.com/green_center/ > > [Non-text portions of this message have been removed] > |
07-05-2007, 06:07
Trip to PA
Hi Kerry,
I will have to go to the blue box to get the temperatures that Cat recommends... I will do that this evening... I think I will open the Cat book to see how the cooler works... The temps have been consistant with my use of the bus... Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 5, 2007 12:41:28 PM Subject: [WanderlodgeForum] Re: Trip to PA i was under the impression that synthetic oils would not necessarily run cooler but continue to perform their function at higher temperatures? What are the CAT parameters for oil temperature on your engine? You have piston oil coolers so I would think that with a steady pyrometer reading of 950, you would see pretty high oil temperatures. I don't know how the CAT oil cooler system works, but my Mercedes has a thermostat in the oil cooling system that opens when the oil reaches a temperature which requires cooling. Are these temperatures a new development? Kerry 82 FC 35 Denver --- In WanderlodgeForum@ yahoogroups. com, Larry > > Hi all, > I have just returned from a trip to southern PA, having to climb a few mountains... I was experiencing high oil temps in the 250* range, just a guess as the Gage reads 230* and then 320* it was somewhere in the middle... with the water temps in the 190's... pyro temps running @ 950*... I am running 5-40 delvac synthetic... I would think that the temps would be lower with the synthetic... Is it possible the oil cooler could not be working properly??? I have been turning the fan override on when the water temp gets to 190* which brings the oil temps down slowly... What are all your opinions as to a fix??? > Also, while parked at a CG with the jacks lowered and set up for a couple of days the left rear jack had completely returned to its nesting position... What would cause this to happen??? > All responses appreciated > > Sea Ya > Larry > NYC > 84 35FCSB > > > > > ____________ _________ _________ _________ _________ _________ _ > Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center. > http://autos. yahoo.com/ green_center/ > > [Non-text portions of this message have been removed] > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a { text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc { background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o {font-size:0;} .MsoNormal { margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> ________________________________________________________________________________\ ____ Looking for earth-friendly autos? Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. http://autos.yahoo.com/green_center/ [Non-text portions of this message have been removed] |
07-05-2007, 09:22
Trip to PA
Larry,
For your information and others: Sounds like you MAY be slightly high. I just ran the I-77 route this week from Florida to Erie, Pa area with an 87FC35 turbo 300. Going up the 6%-7% grades (that one that is 7 miles long is a killer), I ran max oil temps of 220 on the long climbs with water temps going up to 200 Max (just over 200 the fan kicked in) then the fan quickly brought the water to 170. The oil temperature reduction takes several minutes after the water temp drops. That was always the scenario and probably normal. The fan ran constantly on only the real long grades. Pyro was at 900 on the long grades, never over 900. Usually went up to 700 on shorter grades. Most of my driving the water was at 170 with oil at 190 ( 65mph and 2300 RPM ). By the way, on most grades I was able to keep at least 45mph with only the 7 miler knocking me slightly below 40. I'm using Rotella 10-30 and change VERY often. Don Mohney 87FC35 Jensen Beach > |
07-05-2007, 10:49
Trip to PA
Hey Larry,
I think you mean 15 W 40, My understanding of syn is that it can handle a higher temp.heat, but you may not notice a reduction in the running temp reading. I use the old dino technology in the 3208 15W40 Rotella. My oil temp seemed to run high, until I replaced the oil temp gage and the matching sensor. All is well now 20* /30* higher than coolant temp. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Hi all, > I have just returned from a trip to southern PA, having to climb a few mountains... I was experiencing high oil temps in the 250* range, just a guess as the Gage reads 230* and then 320* it was somewhere in the middle... with the water temps in the 190's... pyro temps running @ 950*... I am running 5-40 delvac synthetic... I would think that the temps would be lower with the synthetic... Is it possible the oil cooler could not be working properly??? I have been turning the fan override on when the water temp gets to 190* which brings the oil temps down slowly... What are all your opinions as to a fix??? > Also, while parked at a CG with the jacks lowered and set up for a couple of days the left rear jack had completely returned to its nesting position... What would cause this to happen??? > All responses appreciated > > Sea Ya > Larry > NYC > 84 35FCSB > > > > > ______________________________________________________________________ ______________ > Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center. > http://autos.yahoo.com/green_center/ > > [Non-text portions of this message have been removed] > |
07-05-2007, 15:11
Trip to PA
Hi Bill,
Yes, you are right I did realize and sent a correction... I will look into the gage and sender, also... Thanks Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 5, 2007 6:49:51 PM Subject: [WanderlodgeForum] Re: Trip to PA Hey Larry, I think you mean 15 W 40, My understanding of syn is that it can handle a higher temp.heat, but you may not notice a reduction in the running temp reading. I use the old dino technology in the 3208 15W40 Rotella. My oil temp seemed to run high, until I replaced the oil temp gage and the matching sensor. All is well now 20* /30* higher than coolant temp. Bill 88 FC Michigan --- In WanderlodgeForum@ yahoogroups. com, Larry wrote: > > Hi all, > I have just returned from a trip to southern PA, having to climb a few mountains... I was experiencing high oil temps in the 250* range, just a guess as the Gage reads 230* and then 320* it was somewhere in the middle... with the water temps in the 190's... pyro temps running @ 950*... I am running 5-40 delvac synthetic... I would think that the temps would be lower with the synthetic... Is it possible the oil cooler could not be working properly??? I have been turning the fan override on when the water temp gets to 190* which brings the oil temps down slowly... What are all your opinions as to a fix??? > Also, while parked at a CG with the jacks lowered and set up for a couple of days the left rear jack had completely returned to its nesting position... What would cause this to happen??? > All responses appreciated > > Sea Ya > Larry > NYC > 84 35FCSB > > > > > ____________ _________ _________ _________ _________ _________ _ ____________ __ > Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center. > http://autos. yahoo.com/ green_center/ > > [Non-text portions of this message have been removed] > ________________________________________________________________________________\ ____ Luggage? GPS? Comic books? Check out fitting gifts for grads at Yahoo! Search http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz [Non-text portions of this message have been removed] |
07-06-2007, 04:04
Trip to PA
I could be wrong but I thought that synthetic oil created less friction between
moving metal parts. Less friction should equal less heat build up. Howard T., So-We-Ga, 86 PT40 > > From: "davidkerryedwards" > Date: 2007/07/05 Thu PM 12:41:28 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Trip to PA > > i was under the impression that synthetic oils would not necessarily run cooler but > continue to perform their function at higher temperatures? What are the CAT parameters > for oil temperature on your engine? You have piston oil coolers so I would think that with > a steady pyrometer reading of 950, you would see pretty high oil temperatures. > I don't know how the CAT oil cooler system works, but my Mercedes has a thermostat in > the oil cooling system that opens when the oil reaches a temperature which requires > cooling. > Are these temperatures a new development? > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, Larry > > > > Hi all, > > I have just returned from a trip to southern PA, having to climb a few mountains... I was > experiencing high oil temps in the 250* range, just a guess as the Gage reads 230* and > then 320* it was somewhere in the middle... with the water temps in the 190's... pyro > temps running @ 950*... I am running 5-40 delvac synthetic... I would think that the > temps would be lower with the synthetic... Is it possible the oil cooler could not be > working properly??? I have been turning the fan override on when the water temp gets to > 190* which brings the oil temps down slowly... What are all your opinions as to a fix??? > > Also, while parked at a CG with the jacks lowered and set up for a couple of days the left > rear jack had completely returned to its nesting position... What would cause this to > happen??? > > All responses appreciated > > > > Sea Ya > > Larry > > NYC > > 84 35FCSB > > > > > > > > > > > ________________________________________________________________________________\ ____ > > Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto > Green Center. > > http://autos.yahoo.com/green_center/ > > > > [Non-text portions of this message have been removed] > > > > > > |
07-06-2007, 13:02
Trip to PA
Maybe I shouldn't add my 2 cents worth, being a new Bird guy and
all. But, I really got into preformance VW engines at one time. The guru of that era (probably still is) Gene Berg tested various oils by keeping track of how many races he could get out of a given oil. Synthetics didn't work for him. He was burning rod bearings with synthetics and theorized the synthetic oil was not absorbing heat in the bearing and carrying it away. Brad Bloxham 1978 FC 3208NA Idaho Falls.--- In WanderlodgeForum@yahoogroups.com, > > I could be wrong but I thought that synthetic oil created less friction between moving metal parts. Less friction should equal less heat build up. > Howard T., So-We-Ga, 86 PT40 > > > > > From: "davidkerryedwards" > > Date: 2007/07/05 Thu PM 12:41:28 EDT > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Trip to PA > > > > i was under the impression that synthetic oils would not necessarily run cooler but > > continue to perform their function at higher temperatures? What are the CAT parameters > > for oil temperature on your engine? You have piston oil coolers so I would think that with > > a steady pyrometer reading of 950, you would see pretty high oil temperatures. > > I don't know how the CAT oil cooler system works, but my Mercedes has a thermostat in > > the oil cooling system that opens when the oil reaches a temperature which requires > > cooling. > > Are these temperatures a new development? > > > > Kerry > > 82 FC 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > > > > > Hi all, > > > I have just returned from a trip to southern PA, having to climb a few mountains... I was > > experiencing high oil temps in the 250* range, just a guess as the Gage reads 230* and > > then 320* it was somewhere in the middle... with the water temps in the 190's... pyro > > temps running @ 950*... I am running 5-40 delvac synthetic... I would think that the > > temps would be lower with the synthetic... Is it possible the oil cooler could not be > > working properly??? I have been turning the fan override on when the water temp gets to > > 190* which brings the oil temps down slowly... What are all your opinions as to a fix??? > > > Also, while parked at a CG with the jacks lowered and set up for a couple of days the left > > rear jack had completely returned to its nesting position... What would cause this to > > happen??? > > > All responses appreciated > > > > > > Sea Ya > > > Larry > > > NYC > > > 84 35FCSB > > > > > > > > > > > > > > > > > ______________________________________________________________________ ______________ > > > Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto > > Green Center. > > > http://autos.yahoo.com/green_center/ > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > |
