balancing tires
07-07-2007, 06:28
balancing tires
I know this gets talked about from time to time -- with suggestions
to use BBs, golf balls, special sand, etc. but I'd like to hear opinions on how to best balance the tires on my coach. I've misplaced the email, but someone mentioned a thing that goes behind the wheel that dynamically balances the tire. During our recent 3-month trip, I noticed that the front tires, in particular, don't seem very well balanced. The bad part is that the out-of-balance vibration seems to be worst at 55-60 mph -- which is a speed I seem to spend a fair amount of time driving. =============================================== Pete Masterson, Author of Book Design and Production: A Guide for Authors and Publishers Aeonix1@... Aeonix Publishing Group http://www.aeonix.com =============================================== [Non-text portions of this message have been removed] |
07-07-2007, 08:06
balancing tires
That speed is also where vibrations show up for wheels out of round.
I'd check that out. You can do this by jacking up the front end and spinning the wheels by hand. Place a small supported stick where it will just touch the tread of the tire, spin it. If there are gaps or it drags hard and stops the wheel, you have your answer. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > I know this gets talked about from time to time -- with suggestions > to use BBs, golf balls, special sand, etc. but I'd like to hear > opinions on how to best balance the tires on my coach. > > I've misplaced the email, but someone mentioned a thing that goes > behind the wheel that dynamically balances the tire. > > During our recent 3-month trip, I noticed that the front tires, in > particular, don't seem very well balanced. The bad part is that the > out-of-balance vibration seems to be worst at 55-60 mph -- which is a > speed I seem to spend a fair amount of time driving. > > =============================================== > Pete Masterson, Author of > Book Design and Production: A Guide for Authors and Publishers > Aeonix1@... > Aeonix Publishing Group http://www.aeonix.com > =============================================== > > > > > [Non-text portions of this message have been removed] > |
