Alarm On 1982 PT40?
07-09-2007, 07:59
Alarm On 1982 PT40?
In a message dated 7/9/2007 4:31:51 P.M. Mountain Standard Time,
ryanpwright@... writes:
Sweet! My first successful assist here. ;-) I finally know enough
about this old bus to begin to help others.
-Ryan
AHHHHHH- that's why the forum was created!!!
83PT40
Livingston, Mt
07-09-2007, 10:53
Alarm On 1982 PT40?
Hello:
I just enterned my '82 PT-40 and turned on the master battery switch
and a very loud alarm started sounding. The alarm is above the kitchen
sink and is black and about the size of a silver dollar.
Any idea what this alarm is, and why its going off? Everthing seemsok...
As always I apprecate your help greatly.
Kevin Ford
'82 PT-40
Richmond Tx.
07-09-2007, 10:56
Alarm On 1982 PT40?
Did your "burglar alarm" get set accidentally? Not sure if your coach
has it, but if so, turn it off on the main dash. Should be a switch
that says "burglar alarm" or some such.
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
On 7/9/07, Kevin Ford wrote:
> Hello:
> Kevin Ford
> '82 PT-40
> Richmond Tx.
07-09-2007, 11:06
Alarm On 1982 PT40?
I do not know about yours specifically. Idea. Mine has a fridge and LP gas alarm
in the overhead panel above the zap oven.
When you said master battery switch, are you talking about an electronics
master?
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Monday, July 09, 2007 5:53 PM
Subject: [WanderlodgeForum] Alarm On 1982 PT40?
Hello:
Kevin Ford
'82 PT-40
Richmond Tx.
07-09-2007, 11:12
Alarm On 1982 PT40?
Ok I found it. There is a alarm button that has been installed at the
drivers seat (looks like someone installed it). Anyway I got to
thinking about that and went out and messed with that switch and that
fixed it.
Thanks Ryan for your help.
Kevin
coach
> -Ryan
> '86 PT-40 8V92
> Tri-Cities, WA
> > Hello:
switch
kitchen
seemsok...
> > Kevin Ford
> > '82 PT-40
> > Richmond Tx.
07-09-2007, 11:16
Alarm On 1982 PT40?
Thanks Leroy I found it. (I think this was a special installed alarm
by the previous owner)
Kevin
LP gas alarm in the overhead panel above the zap oven.
electronics master?
> Leroy Eckert
> Niceville, FL
> From: Kevin Ford
> Hello:
switch
kitchen
seemsok...
> Kevin Ford
> '82 PT-40
> Richmond Tx.
07-09-2007, 11:30
Alarm On 1982 PT40?
-Ryan
> fixed it.
> Kevin
