Removing ceramic tile from a Bird.
07-11-2007, 10:07
Pete- unless your plywood is really damaged, a good floor patch will help
you in your wood installation, without the need for total wood subfloor replacement. Ernie Ekberg 83PT40 Livingston, Mt ---Flooring Bidness since 1972 ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-11-2007, 13:14
Getting ready to install a new floor. After some debate, we've picked
out a bamboo flooring -- solid strips that are glued or nailed down. (We'll glue 'em down.) Since the galley area tile is in a difficult configuration -- it's got a convex curve around the dining table -- we're pulling it up and going to simply run the bamboo throughout the area. Had the tile been in a more rectangular layout, we might have been inclined to leave it in place as it would have not been so difficult to install wood flooring nearby. For those with a later model 'bird, if you're thinking of taking out some of the tile flooring, here's what you're in for. The tile was glued with a very powerful (I'd guess an epoxy-type) adhesive to Wonderboard, a cement-like product used as underlay or wall backing behind better tile installations. The Wonderboard was, in turn, epoxy glued to the plywood sub-floor. (The glue was so powerful, that a layer of the plywood would come up with the Wonderboard/tile.) In addition, _several_ dozen screws were run through the Wonderboard into the sub-floor. About 9 sq. ft. of tile took about 6 hours (at my rate) to chisel off the sub-floor. Next, I'll have to cut out that section of sub-floor (that runs under the kitchen counter) as it is simply too fouled with the remains of the Wonderboard and glue -- and the gouges made when chiseling the tile with a pry bar. I have to admit, that the Blue Bird craftsmanship in laying this tile was excellent. I don't think the tile would ever have worked loose on its own -- ever. As for the carpet -- it was a pretty typical installation. Tack strips bounding transitions to other flooring (the tile) and staples along the edges. Different pieces/colors of carpet were joined with heat activated carpet tape. In pulling up the carpet, I was mildly surprised at the number of stains and obvious quantities of moisture that had soaked the carpet over the years. While the colors are a little faded and less vibrant than a new carpet, it actually had held up rather well considering the amount of use -- and abuse -- it got. I'm not seeking any help at this point, but this description is to help others who might be contemplating a similar upgrade. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... [Non-text portions of this message have been removed] |
07-12-2007, 03:34
Pete I think that sub floor is marine grade plywood really resistant to
moisture. I took my 12" X 12" oak in the kitchen up & patched the floor. I predrilled my oak & used a real small trim screw to scerw in through the tongue of the oak. I've had it down for a year & still doing good. Don 89 SP 36' Butler, PA One sub-floor board, directly in front of the galley, still has considerable quantities of the Wonderboard and epoxy bonded to it. Had it been a matter of merely filling a few depressions, the floor patch would be OK ... indeed, I plan to use a floor patch material on some gouges to a sub-floor board by the refrigerator. However, the raised combination of the cement-like Wonderboard remains plus the epoxy-type adhesive on the board would probably require many more hours of scraping to remove. It seems easier to simply cut out the half-board and replace it. (I hope the sub-floor isn't glued to the supporting structure underneath.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-12-2007, 04:50
We had to replace the plywood in Towanda- not a fun project. I'm surprised
the wonderboard was glued. Mine was screwed. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-12-2007, 05:30
considerable quantities of the Wonderboard and epoxy bonded to it. Had it been a matter of merely filling a few depressions, the floor patch would be OK ... indeed, I plan to use a floor patch material on some gouges to a sub-floor board by the refrigerator. However, the raised combination of the cement-like Wonderboard remains plus the epoxy-type adhesive on the board would probably require many more hours of scraping to remove. It seems easier to simply cut out the half-board and replace it. (I hope the sub-floor isn't glued to the supporting structure underneath.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 11, 2007, at 7:07 PM, erniecarpet@... wrote: > Pete- unless your plywood is really damaged, a good floor patch > will help > you in your wood installation, without the need for total wood > subfloor > replacement. [Non-text portions of this message have been removed] |
07-12-2007, 06:01
In a message dated 7/12/2007 2:47:42 P.M. Mountain Standard Time,
jwasnewski@... writes: It makes a lot of dust. That's the worst part. It will take quite a while to clean up after all the demo work. I get to work in a plastic 5th wheel with 17 slideouts. Stepped on the first step and thought the thing was going to tip over- but- their money is green Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-12-2007, 06:28
I'd personally get a grinder, belt sander or whatever it took to to
get it off rather than cut through the sub-floor. But it's your Bird... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > One sub-floor board, directly in front of the galley, still has > considerable quantities of the Wonderboard and epoxy bonded to it. > Had it been a matter of merely filling a few depressions, the floor > patch would be OK ... indeed, I plan to use a floor patch material on > some gouges to a sub-floor board by the refrigerator. However, the > raised combination of the cement-like Wonderboard remains plus the > epoxy-type adhesive on the board would probably require many more > hours of scraping to remove. It seems easier to simply cut out the > half-board and replace it. (I hope the sub-floor isn't glued to the > supporting structure underneath.) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jul 11, 2007, at 7:07 PM, erniecarpet@... wrote: > > > Pete- unless your plywood is really damaged, a good floor patch > > will help > > you in your wood installation, without the need for total wood > > subfloor > > replacement. > > > > [Non-text portions of this message have been removed] > |
07-12-2007, 09:32
I guess the installer was a belt and suspenders type of guy. It was
screwed _and_ glued. No fun getting it up. =============================================== Pete Masterson, Author of Book Design and Production: A Guide for Authors and Publishers Aeonix1@... Aeonix Publishing Group http://www.aeonix.com =============================================== On Jul 12, 2007, at 1:50 PM, erniecarpet@... wrote: > We had to replace the plywood in Towanda- not a fun project. I'm > surprised > the wonderboard was glued. Mine was screwed. > > Ernie Ekberg > 83PT40 > Livingston, Mt > [Non-text portions of this message have been removed] |
07-12-2007, 09:47
TCA specs call for Wonderful Board or equivalent to be installed using latex
fortified thinset or better and screwed every 8 inches. Tape and mud the joints before tile installation. It's good to know they followed the spec. You can rent a chipping hammer with a 3" blade and remove it fairly quickly. It makes a lot of dust. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 12, 2007 4:32 PM Subject: Re: [WanderlodgeForum] Re: Removing ceramic tile from a Bird. I guess the installer was a belt and suspenders type of guy. It was screwed _and_ glued. No fun getting it up. =============================================== Pete Masterson, Author of Book Design and Production: A Guide for Authors and Publishers Aeonix1@... Aeonix Publishing Group http://www.aeonix.com =============================================== On Jul 12, 2007, at 1:50 PM, erniecarpet@... wrote: > We had to replace the plywood in Towanda- not a fun project. I'm > surprised > the wonderboard was glued. Mine was screwed. > > Ernie Ekberg > 83PT40 > Livingston, Mt > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-12-2007, 10:17
Yea, ain't that the truth. We are lucky. Those 5ers are iffy at best.
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 12, 2007 5:01 PM Subject: Re: [WanderlodgeForum] Re: Removing ceramic tile from a Bird. In a message dated 7/12/2007 2:47:42 P.M. Mountain Standard Time, jwasnewski@... writes: It makes a lot of dust. That's the worst part. It will take quite a while to clean up after all the demo work. I get to work in a plastic 5th wheel with 17 slideouts. Stepped on the first step and thought the thing was going to tip over- but- their money is green Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
