Positively Riveting!
07-12-2007, 10:34
Today's project was the replacement of a number of rivets holding bay door
frames. I had a couple of frames that were fully loose on one side or the other, and a couple of others that I could rattle pretty good. I ended up doing both sides of one door, and the left side of two others. I chose white-painted rivets rather than plain, on the grounds that they will take touch-up painting better. It looks like several rivets have been replaced in the past; is this common? I suspect that the flexing slowly destroys the aluminum pop rivets, unlike the structural steel rivets. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
07-12-2007, 13:31
Tell us more please! What size rivets did you use? What rivet
gun? Where did you get the white rivets? I need to do a panel on my FC35. Thanks in advance! Thomas Eastham Houston, TX 83' FC35 SB 84' FC33 SB parting [Non-text portions of this message have been removed] |
07-12-2007, 13:49
I have a cheap, but effective, gun exactly like this one:
http://cgi.ebay.com/NEW-AIRCRAFT-POP-RIV...W0QQi\ temZ170128664322QQihZ007QQcategoryZ55809QQrdZ1QQcmdZViewItem or http://tinyurl.com/27adj7 Originally paid for some rivets on e-bay, but had my first bad experience - no product, no communications. Currently in PayPal claim/dispute over it. So, I paid only slightly more to buy these: http://www.speedwaymotors.com/p/1546,,_T....html\ ?itemNo=rivets or http://tinyurl.com/2d229u The rivets are 5/8 heads, same as what is already on the coach. Some of the rivets I replaced were split-legged, and some weren't - the split-legged may be original, but harder to come up with, and they aren't that much better in my opinion. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 7/12/2007 at 8:31 PM M Thomas Eastham wrote: >Tell us more please! What size rivets did you use? What rivet >gun? Where did you get the white rivets? I need to do a panel on >my FC35. > >Thanks in advance! > >Thomas Eastham >Houston, TX >83' FC35 SB >84' FC33 SB parting |
