water heater - r/r -
07-12-2007, 10:50
The electric heat supply to my water heater has stopped working. It is
an Atwood model, 10.5 gallons.
I have not taken it apart, but assume I will need to replace the whole
unit.
Is this a correct assumption, or per chance, can you replace just the
heating element on this unit?
Roger Webb
91WBWL
Cedar Rapids, IA
07-12-2007, 11:05
You can replace the heating unit or replace the whole unit
You will probably have to remove the heater from the coach to access
the element
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "rogerwwebb"
> unit.
> Roger Webb
> 91WBWL
> Cedar Rapids, IA
07-12-2007, 13:26
Roger depending on the age of the unit you might just be better off to put
in a new one.
> unit.
> Roger Webb
> 91WBWL
> Cedar Rapids, IA
Rob, Sue & Merlin Robinson
94 WLWB
07-13-2007, 10:02
In a message dated 7/13/2007 6:32:09 P.M. Mountain Standard Time,
bobandarlene@... writes:
Tacoma, Wa. (with 3 months left to be here before we fulltime otta
here.)
Bob, with just 3 months left- which way you guys headed?
83PT40
Livingston, Mt
************************************** Get a sneak peak of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour
07-13-2007, 11:19
Hello Roger,
I have an Atwood water heater in our coach that I installed to replace our
original. I've
found that the electric heater element trips out whenever water from the engine
exceeds
185 ºF. After consulting the factory, the way I remedy this situation is as
follows:
1. Shut off power to the heater.
2. Remove sheet metal screws from the square cover over the heating element.
3. Use a screwdriver to push in the red reset button buried in between the
electrical plugs
that supply power to the heater.
4. Replace the cover and restore power.
In the summer I close the hot water circulation off to the heater to prevent
this problem.
Long term fix...replace the Atwood heater with a better choice.
Regards, Eric in San Antonio
84FC35SBWL2
> unit.
> Roger Webb
> 91WBWL
> Cedar Rapids, IA
07-13-2007, 12:53
Or replace with a heater that has an automatic reset Force Ten Brand
Direct replacement for the Atwood
we have them
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson"
> Hello Roger,
replace our original. I've
the engine exceeds
situation is as follows:
element.
between the electrical plugs
prevent this problem.
> 84FC35SBWL2
It is
whole
> > unit.
> > Roger Webb
> > 91WBWL
> > Cedar Rapids, IA
07-13-2007, 13:02
Sent: Friday, July 13, 2007 7:53 PM
Subject: [WanderlodgeForum] Re: water heater - r/r -
This past April I replace my old water heater with the force ten.The harder
thing was to remove the old one.
Bob Loomas 1985 PT 36
we have them
Stephen 77fc35
> Hello Roger,
the engine exceeds
element.
> 84FC35SBWL2
It is
whole
> > unit.
> > Roger Webb
> > 91WBWL
> > Cedar Rapids, IA
07-13-2007, 13:25
Or, do like I did, shut off the hot water heater, drained it, and
installed a tankless water heater in the bay for unlimited hot water
use.
Now have the electric one as a backup. This water heater issue seems
to me to be the only thing that Bluebird didn't have a backup for.
Bob Lawrence
84 PT36
here.)
> From: Stephen Birtles
ten.The harder thing was to remove the old one.
Brand
> we have them
> Stephen 77fc35
07-13-2007, 13:43
Several of us have put in the Force Ten and are happy campers. Bruce, Randy,
myself and others have done the install and it is relatively easy.
> we have them
> Stephen 77fc35
> "Eric Johnson"
> > Hello Roger,
> the engine exceeds
> element.
> > 84FC35SBWL2
> "rogerwwebb"
> It is
> whole
> > > unit.
> > > Roger Webb
> > > 91WBWL
> > > Cedar Rapids, IA
94 WLWB
07-14-2007, 00:53
> Rodger, I have a 1980 SB, I had no hot water also. I tested the
element for continuty and found none. It was 1250 watt element, I
went to Home Depot and found a 120 volt,1500 watt element and an
adapter [bolt type to screw type] for less than 20 bucks. Beats the
price of a new WH by miles. I believe these elements are generic.
Just make sure you use the right voltage 120 or 240, and match up the
watts as close as possible. Good luck.
> Hello Roger,
from the engine exceeds
heating element.
to prevent this problem.
> 84FC35SBWL2
It is
whole
> > unit.
> > Roger Webb
> > 91WBWL
> > Cedar Rapids, IA
