Was: Help with generator problem Now:18 year old recall?
05-07-2005, 14:14
Bob,
Thanks for that input. It's really hard to believe that you got a
factory recall on an 18 year old vehicle! Unbelievable.
83 PT40 "Stagecoach" - looking for new home
91 PT40 "Texas Minivan" - not home yet
San Antonio, Texas
--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`"
> Andy-Jeff,
> > > Just before I sold my 84 1/2 pt40 back in 02 I got a recall
> letter from BB about the transfer switch. It stated that they realized
> this switch was positioned in the wrong place and was subject to
> getting wet.(water coming in open window) They further stated that they
> would take a look and repair and replace damaged switch's plus make
> them water proof. All that was required was to bring them back to the
> factory..No charge..... Bob 93pt40 illinois
> > > I took the transfer switch out and found it submerged in water. I
> > > drilled a hole in the bottom of the case to drain the water. It
> has
> > > been this way for quite some time. The switch assy. is corroded
> > > beyond use. I will call BB on Monday to see if they have a
> > > replacement. Are there any options for a replacement from another
> > > source?
> > > Thank you for your time.
> > > Andy
