Watts Quick-connect
07-17-2007, 07:53
Watts Quick-connect
Folks,
I'm gearing up to plumb my aqua-hot and stumbled across Watts connectors at the local ACE hdwr store: http://www.watts.com/pro/_products.asp?catId=71 These fittings can fully rotate under pressure and allow for easy disconnect and reuse. They are good for 100psi at 180 deg F. The connectors work for PEX, CPVC, or Copper; for example, a T connector can connect all 3 of these materials on any end of the T. Anyone have any experience using these in a Motorhome application? David Brady '02 LXi, Smokey NC |
07-17-2007, 09:47
Watts Quick-connect
From: David Brady To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 17, 2007 2:53 PM Subject: [WanderlodgeForum] Watts Quick-connect Davit Do they have built in check valves so you do not dump the system if they are disconnected? Bob Loomas 1985 PT 36 Folks, I'm gearing up to plumb my aqua-hot and stumbled across Watts connectors at the local ACE hdwr store: http://www.watts.com/pro/_products.asp?catId=71 These fittings can fully rotate under pressure and allow for easy disconnect and reuse. They are good for 100psi at 180 deg F. The connectors work for PEX, CPVC, or Copper; for example, a T connector can connect all 3 of these materials on any end of the T. Anyone have any experience using these in a Motorhome application? David Brady '02 LXi, Smokey NC [Non-text portions of this message have been removed] |
07-17-2007, 10:18
Watts Quick-connect
Not that I know of Bob, but they do have quick-connect
ball valves. David B '02 LXi, Smokey NC bloomas wrote: > > > ----- Original Message ----- > From: David Brady > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, July 17, 2007 2:53 PM > Subject: [WanderlodgeForum] Watts Quick-connect > Davit Do they have built in check valves so you do not dump the system > if they are disconnected? > Bob Loomas 1985 PT 36 > > Folks, > > I'm gearing up to plumb my aqua-hot and stumbled > across Watts connectors at the local ACE hdwr store: > > http://www.watts.com/pro/_products.asp?catId=71 > <http://www.watts.com/pro/_products.asp?catId=71> > > These fittings can fully rotate under pressure and allow > for easy disconnect and reuse. They are good for 100psi > at 180 deg F. The connectors work for PEX, CPVC, > or Copper; for example, a T connector can connect > all 3 of these materials on any end of the T. Anyone have > any experience using these in a Motorhome application? > > David Brady > '02 LXi, Smokey > NC > > [Non-text portions of this message have been removed] > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.8/904 - Release Date: 7/16/2007 5:42 PM > [Non-text portions of this message have been removed] |
