Anyone ever use POR-15?
07-21-2007, 15:07
Did u use the etcher the POR company sells?
--- In WanderlodgeForum@yahoogroups.com, David Brady
> Not that I'm aware of. The phosphoric acid etcher does do a
> number on aluminum.
> David Brady
> '02 LXi, Smokey
> NC
> Scott Forman wrote:
> > Is there anything to keep it away from (electrical, etc)?
> > , David Brady
> > wrote:
> > > Definitely brush it on, just wear gloves and don't get any on
your
> > > hands. After it self-levels it'll look like you sprayed it. The
> > final
> > > finish is very similar to powder coating in appearance and
> > toughness.
> > > Those foam/sponge brushes are best, cheap bristle brushes leave
> > > bristles in the paint.
> > > David Brady
> > > '02 LXi, Smokey
> > > NC
> > > Scott Forman wrote:
> > > > Did u spray or brush it on? Is it very messy or about like any
> > other
> > > > paint?
> > > > , "Mike Hohnstein"
> > > > <MHOHNSTEIN@> wrote:
> > > > > Yup, it's good stuff. Used it many times to fix on older
truck
> > > > frames, resulting in serious value adding to the end product.
> > > > > MH
> > > > > ----- Original Message -----
> > > > > From: Leroy Eckert
> > > > > To: WanderlodgeForum@yahoogroups.com
> > > > > Sent: Saturday, July 21, 2007 8:25 PM
> > > > > Subject: Re: [WanderlodgeForum] Anyone ever use POR-15?
> > > > > I have used POR-15 for years. It is a great product. It
flows
> > out
> > > > nicely. You can paint over rust ( POR )or paint without the
rust
> > if
> > > > you Ospho, sandblast or etch steel. It needs something to
bite.
> > If it
> > > > is exposed to sunlight, it needs to be topcoated. I'll
guarantee
> > it
> > > > will never rust again if applied properly.
> > > > > Leroy Eckert
> > > > > 1990 WB-40"Smoke N Mirrors"
> > > > > Niceville, FL
> > > > > Royale Conversion
> > > > > From: Scott Forman
> > > > > Sent: Saturday, July 21, 2007 8:07 PM
> > > > > Subject: [WanderlodgeForum] Anyone ever use POR-15?
> > > > > Seems like a good product in design, wondering if it works.
> > > > Wanting to
> > > > > address surface oxidation under my bus. Anyone use it or
know
> > > > another
> > > > > better product?
> > > > > Scott Forman
> > > > > 86 PT38
> > > > > With a cruddy underside
> > > > > [Non-text portions of this message have been removed]
> > > > No virus found in this incoming message.
> > > > Checked by AVG Free Edition.
> > > > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release
Date:
> > 7/20/2007 4:39 PM
> > Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date:
7/20/2007 4:39 PM
07-21-2007, 15:09
number on aluminum.
David Brady
'02 LXi, Smokey
NC
> , David Brady
> > Definitely brush it on, just wear gloves and don't get any on your
> final
> toughness.
> > David Brady
> > '02 LXi, Smokey
> > NC
> other
> > > paint?
> > > , "Mike Hohnstein"
> > > > Yup, it's good stuff. Used it many times to fix on older truck
> > > > MH
> > > > From: Leroy Eckert
> > > > I have used POR-15 for years. It is a great product. It flows
> out
> > > nicely. You can paint over rust ( POR )or paint without the rust
> if
> > > you Ospho, sandblast or etch steel. It needs something to bite.
> If it
> > > is exposed to sunlight, it needs to be topcoated. I'll guarantee
> it
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > Royale Conversion
> > > > From: Scott Forman
> > > Wanting to
> > > > address surface oxidation under my bus. Anyone use it or know
> > > another
> > > > better product?
> > > > Scott Forman
> > > > 86 PT38
> 7/20/2007 4:39 PM
> Version: 7.5.476 / Virus Database: 269.10.11/909 - Release Date: 7/20/2007
4:39 PM
07-21-2007, 15:14
Yup, Good night already!
David Brady
'02 LXi, Smokey
NC
> number on aluminum.
> David Brady
> '02 LXi, Smokey
> NC
> > , David Brady
> > final
> > toughness.
> > > David Brady
> > > '02 LXi, Smokey
> > > NC
> > other
> > > > paint?
> > > > , "Mike Hohnstein"
> > > > > MH
> > > > > From: Leroy Eckert
> > out
> > if
> > If it
> > it
> > > > > Leroy Eckert
> > > > > Niceville, FL
> > > > > Royale Conversion
> > > > > From: Scott Forman
> > > > Wanting to
> > > > another
> > > > > better product?
> > > > > Scott Forman
> > > > > 86 PT38
> > 7/20/2007 4:39 PM
> 7/20/2007 4:39 PM
4:39 PM
07-21-2007, 15:14
What can I say, I like the nightlife!
> David Brady
> '02 LXi, Smokey
> NC
> > number on aluminum.
> > David Brady
> > '02 LXi, Smokey
> > NC
> > > , David Brady
your
The
> > > final
> > > toughness.
leave
> > > > David Brady
> > > > '02 LXi, Smokey
> > > > NC
any
> > > other
> > > > > paint?
> > > > > , "Mike
Hohnstein"
truck
product.
> > > > > > MH
> > > > > > From: Leroy Eckert
flows
> > > out
rust
> > > if
bite.
> > > If it
guarantee
> > > it
> > > > > > Leroy Eckert
> > > > > > Niceville, FL
> > > > > > Royale Conversion
> > > > > > From: Scott Forman
works.
> > > > > Wanting to
know
> > > > > another
> > > > > > better product?
> > > > > > Scott Forman
> > > > > > 86 PT38
Date:
> > > 7/20/2007 4:39 PM
Date:
> > 7/20/2007 4:39 PM
7/20/2007 4:39 PM
07-21-2007, 15:44
Yup, it's good stuff. Used it many times to fix on older truck frames,
MH
I have used POR-15 for years. It is a great product. It flows out nicely. You
can paint over rust ( POR )or paint without the rust if you Ospho, sandblast or
etch steel. It needs something to bite. If it is exposed to sunlight, it needs
to be topcoated. I'll guarantee it will never rust again if applied properly.
Leroy Eckert
Niceville, FL
Royale Conversion
Seems like a good product in design, wondering if it works. Wanting to
address surface oxidation under my bus. Anyone use it or know another
better product?
Scott Forman
86 PT38
07-21-2007, 16:51
Done it both wayz, spray requires masking, somewhat. Brush works OK too. Keep
in mind my experience has been on vintage dump trucks.
However, it makes them look impressive and I usually get top buck when selling
time comes.
MH
Sent: Saturday, July 21, 2007 8:54 PM
Subject: [WanderlodgeForum] Re: Anyone ever use POR-15?
Did u spray or brush it on? Is it very messy or about like any other
paint?
> MH
> From: Leroy Eckert
nicely. You can paint over rust ( POR )or paint without the rust if
you Ospho, sandblast or etch steel. It needs something to bite. If it
is exposed to sunlight, it needs to be topcoated. I'll guarantee it
> Leroy Eckert
> Niceville, FL
> Royale Conversion
> From: Scott Forman
Wanting to
another
> better product?
> Scott Forman
> 86 PT38
07-21-2007, 16:56
Wanting to
another
> better product?
> Scott Forman
> 86 PT38
I used it on my Thunderbird under the rocker area's and inside on the
floor pan. It works great and I even used it to patch a couple of
rust out holes using fiber glass screening material. This stuff is a
little expensive but works great!
But if you are going to do the whole underneath of your rig than I
would suggest you might spray on some type of rust inhibitor and then
spray with a good undercoating! I did this with my Dodge and it
worked out just fine.
07-21-2007, 19:55
I always remove the flaky rust before treating although I do not believe it is
required.
Leroy Eckert
Niceville, FL
Sent: Saturday, July 21, 2007 9:29 PM
Is prep required to go over a rusty surface?
> Leroy Eckert
> Niceville, FL
> Royale Conversion
> From: Scott Forman
Wanting to
another
> better product?
> Scott Forman
> 86 PT38
07-21-2007, 22:52
I have used POR-15 for several projects on the bus. It is an exceptional
product that produces a hard glossy finish that is very chip resistant and easy
to clean. BUT... in order to get the results that are possible from it
requires a lot of preparatory work. All loose rust must be removed requiring
scrappin
g wire brushing etc. Then the metal preparatory solution, actually an acid
etcher, needs to be applied, allowed to work and then thoroughly rinsed off in
order to stop the acid action. The surface to be painted must be dry. Make
sure that you wear gloves as POR -15 is difficult to remove from your skin.
Your results will be great with if you follow the directions. POR 15 is not an
inexpensive product for large projects like an entire bus chassis.
I have been painting/repainting the chassis of my bus small sections and
have had good results from a product called Hammerite. The preparation process
is far less complicated. I have been removing all the loose rust, cleaning all
the grease and oil from the surface to be covered with solvents then brush
painting it on. The product has shown excellent adherence to the chassis and
has been holding up well. The acid etching process required for POR-15 is not
required. The best part is that Hammerite costs about one forth as much as
POR-15.
I am not suggesting that Hammerite is a better product than POR-15. In fact
it is not. But to be practical, if you are repainting an entire chassis as it
sits, that is, with the all the electrical, wiring, hoses and accessories
still attached, and are working under the bus. Then acid etching and complete
rust removal is not possible. I recommend the less expensive, easier route. I
think you will probably be satisfied with the results.
Steve Anderson
79 FC 35
Poulsbo, Wa.
In a message dated 7/21/2007 6:08:13 PM Pacific Daylight Time,
sforman@... writes:
better product?
Scott Forman
86 PT38
************************************** Get a sneak peek of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour
07-22-2007, 01:07
Where can you buy this? A regular paint store or does it have to be bought?
Does Home Depot or Lowe's handle it?
Ron Thompson -Waller, Tx.
1995 WLWB 42'Blue Bird
(cockyfox@...)
