Air Pressure Problem
05-08-2005, 06:23
Hello again all,
Well now that all the planets are back in alignment (my travel has slowed down, the weather is nice, some honeydoo's are completed) I am back to this problem. I imagine all of you were on the right track but let me try to describe it a little better. At the bottom of the cylinder is a small philips head screw that secures a rubber washer to a round cap about the size of a coke bottle cap (new style, not the old one we had to use a bottle opener for) I put that in just in case any of you are old enough to remember bottle openers. This cap has a triangular shape base and is attached to a nut about 2 inches across by three small philips head screws. My question is do I need to unscrew the big nut? From the air dryer chalenged not so big nut. Charles Unscrew the part(4 screws) and take it to NAPA and get a new purge valve kit Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix AD-2 air dryer. tom 1982 FC35 Ab ----- Original Message ----- From: To: Sent: Sunday, March 13, 2005 1:33 PM Subject: [Wanderlodge] Air Pressure Problem > > > Hi All, > > > > Just cranked up the bird (83 FC 35) and the air pressure doesn't come up. > I have traced the problem to a vertical cylinder next to the drive shaft > about midway of the coach. The air is escaping around a rubber washer > secured by a small Philips head screw at the bottom of the cylinder. > Should I just replace the rubber washer or is this a larger problem? > > > > Thanks, > > > > Charles > > 83 FC 35 > > Stone Mountain GA > |
05-08-2005, 06:48
Still the same fix as the first time you asked back in March. Remove the
complete purge valve from the bottom and get a new kit and replace it. See below the last time I posted this. Tom 1982 FC35 Vernon Center,NY At 02:23 PM 5/8/2005 -0400, you wrote: >Hello again all, > >Well now that all the planets are back in alignment (my travel has slowed >down, the weather is nice, some honeydoo's are completed) I am back to this >problem. I imagine all of you were on the right track but let me try to >describe it a little better. At the bottom of the cylinder is a small >philips head screw that secures a rubber washer to a round cap about the >size of a coke bottle cap (new style, not the old one we had to use a bottle >opener for) I put that in just in case any of you are old enough to remember >bottle openers. This cap has a triangular shape base and is attached to a >nut about 2 inches across by three small philips head screws. My question >is do I need to unscrew the big nut? > > From the air dryer chalenged not so big nut. > > >Charles > > >Unscrew the part(4 screws) and take it to NAPA and get a new purge valve kit >Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix >AD-2 air dryer. > >tom >1982 FC35 >Ab >----- Original Message ----- >From: >To: >Sent: Sunday, March 13, 2005 1:33 PM >Subject: [Wanderlodge] Air Pressure Problem > > > > > > > > Hi All, > > > > > > > > Just cranked up the bird (83 FC 35) and the air pressure doesn't come up. > > I have traced the problem to a vertical cylinder next to the drive shaft > > about midway of the coach. The air is escaping around a rubber washer > > secured by a small Philips head screw at the bottom of the cylinder. > > Should I just replace the rubber washer or is this a larger problem? > > > > > > > > Thanks, > > > > > > > > Charles > > > > 83 FC 35 > > > > Stone Mountain GA > > > > > > > >Yahoo! Groups Links > > > > |
05-08-2005, 07:20
Tom,
I want to make sure we are talking about the same thing. This cylinder is virtical, at the bottom below the cylinder itself is what I assume is the purge valve. It has what I think is an air line going into it and also an electrical lead. The three screws attach the leaking cap and three bolts attach the lower part (pruge valve) I think to the cylinder. I don't see four screws anywhere. Do you think it is the same thing maybe just a different mounting arrangement? Charles ----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Sunday, May 08, 2005 2:48 PM Subject: Re: [WanderlodgeForum] Air Pressure Problem Still the same fix as the first time you asked back in March. Remove the complete purge valve from the bottom and get a new kit and replace it. See below the last time I posted this. Tom 1982 FC35 Vernon Center,NY At 02:23 PM 5/8/2005 -0400, you wrote: >Hello again all, > >Well now that all the planets are back in alignment (my travel has slowed >down, the weather is nice, some honeydoo's are completed) I am back to this >problem. I imagine all of you were on the right track but let me try to >describe it a little better. At the bottom of the cylinder is a small >philips head screw that secures a rubber washer to a round cap about the >size of a coke bottle cap (new style, not the old one we had to use a bottle >opener for) I put that in just in case any of you are old enough to remember >bottle openers. This cap has a triangular shape base and is attached to a >nut about 2 inches across by three small philips head screws. My question >is do I need to unscrew the big nut? > > From the air dryer chalenged not so big nut. > > >Charles > > >Unscrew the part(4 screws) and take it to NAPA and get a new purge valve kit >Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix >AD-2 air dryer. > >tom >1982 FC35 >Ab >----- Original Message ----- >From: >To: >Sent: Sunday, March 13, 2005 1:33 PM >Subject: [Wanderlodge] Air Pressure Problem > > > > > > > > Hi All, > > > > > > > > Just cranked up the bird (83 FC 35) and the air pressure doesn't come up. > > I have traced the problem to a vertical cylinder next to the drive shaft > > about midway of the coach. The air is escaping around a rubber washer > > secured by a small Philips head screw at the bottom of the cylinder. > > Should I just replace the rubber washer or is this a larger problem? > > > > > > > > Thanks, > > > > > > > > Charles > > > > 83 FC 35 > > > > Stone Mountain GA > > > > > > > >Yahoo! Groups Links > > > > ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-08-2005, 07:24
i lkie to remove the air dyer from the coach,take it inside,put it on a
table and work on it.i don't think that nut unscrews,i think its on there to clock the end for hose alignment..randydupree93wb ----- Original Message ----- From: To: Sent: Sunday, May 08, 2005 2:23 PM Subject: [WanderlodgeForum] Air Pressure Problem > Hello again all, > > Well now that all the planets are back in alignment (my travel has slowed > down, the weather is nice, some honeydoo's are completed) I am back to > this > problem. I imagine all of you were on the right track but let me try to > describe it a little better. At the bottom of the cylinder is a small > philips head screw that secures a rubber washer to a round cap about the > size of a coke bottle cap (new style, not the old one we had to use a > bottle > opener for) I put that in just in case any of you are old enough to > remember > bottle openers. This cap has a triangular shape base and is attached to a > nut about 2 inches across by three small philips head screws. My question > is do I need to unscrew the big nut? > > From the air dryer chalenged not so big nut. > > > Charles > > > Unscrew the part(4 screws) and take it to NAPA and get a new purge valve > kit > Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix > AD-2 air dryer. > > tom > 1982 FC35 > Ab > ----- Original Message ----- > From: > To: > Sent: Sunday, March 13, 2005 1:33 PM > Subject: [Wanderlodge] Air Pressure Problem > > >> >> >> Hi All, >> >> >> >> Just cranked up the bird (83 FC 35) and the air pressure doesn't come >> up. >> I have traced the problem to a vertical cylinder next to the drive shaft >> about midway of the coach. The air is escaping around a rubber washer >> secured by a small Philips head screw at the bottom of the cylinder. >> Should I just replace the rubber washer or is this a larger problem? >> >> >> >> Thanks, >> >> >> >> Charles >> >> 83 FC 35 >> >> Stone Mountain GA >> > > > > > > Yahoo! Groups Links > > > > > > > |
05-08-2005, 08:33
Hi Charles:
There is a large hex looking body that unscrews from the lid. The purge valve is in there. Some times it takes mounting the lid gently in a vice and tapping the wrench connected to the hex below the lid to get it to separate then it just un screws. Then you will need a large blade screw driver and a 7/16" socket to remove the purge valve with. Good luck Safe travels, Ralph Fullenwider Dream_35_Team '85FC35 in Oklahoma Ralph's RV Solutions At 03:20 PM 5/8/2005 -0400, you wrote: >Tom, > >I want to make sure we are talking about the same thing. This cylinder is >virtical, at the bottom below the cylinder itself is what I assume is the >purge valve. It has what I think is an air line going into it and also an >electrical lead. The three screws attach the leaking cap and three bolts >attach the lower part (pruge valve) I think to the cylinder. I don't see >four screws anywhere. Do you think it is the same thing maybe just a >different mounting arrangement? > >Charles > ----- Original Message ----- > From: Tom Warner > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, May 08, 2005 2:48 PM > Subject: Re: [WanderlodgeForum] Air Pressure Problem > > > Still the same fix as the first time you asked back in March. Remove the > complete purge valve from the bottom and get a new kit and replace it. See > below the last time I posted this. > > Tom > 1982 FC35 > Vernon Center,NY > > At 02:23 PM 5/8/2005 -0400, you wrote: > >Hello again all, > > > >Well now that all the planets are back in alignment (my travel has slowed > >down, the weather is nice, some honeydoo's are completed) I am back to > this > >problem. I imagine all of you were on the right track but let me try to > >describe it a little better. At the bottom of the cylinder is a small > >philips head screw that secures a rubber washer to a round cap about the > >size of a coke bottle cap (new style, not the old one we had to use a > bottle > >opener for) I put that in just in case any of you are old enough to > remember > >bottle openers. This cap has a triangular shape base and is attached to a > >nut about 2 inches across by three small philips head screws. My question > >is do I need to unscrew the big nut? > > > > From the air dryer chalenged not so big nut. > > > > > >Charles > > > > > >Unscrew the part(4 screws) and take it to NAPA and get a new purge > valve kit > >Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix > >AD-2 air dryer. > > > >tom > >1982 FC35 > >Ab > >----- Original Message ----- > >From: > >To: > >Sent: Sunday, March 13, 2005 1:33 PM > >Subject: [Wanderlodge] Air Pressure Problem > > > > > > > > > > > > > Hi All, > > > > > > > > > > > > Just cranked up the bird (83 FC 35) and the air pressure doesn't > come up. > > > I have traced the problem to a vertical cylinder next to the drive > shaft > > > about midway of the coach. The air is escaping around a rubber washer > > > secured by a small Philips head screw at the bottom of the cylinder. > > > Should I just replace the rubber washer or is this a larger problem? > > > > > > > > > > > > Thanks, > > > > > > > > > > > > Charles > > > > > > 83 FC 35 > > > > > > Stone Mountain GA > > > > |
05-08-2005, 09:56
Ralph, YOU THE MAN
The hex body came off with everything still mounted on the coach. Took it apart. Some gunk inside. The O rings still look in good shape but thats not uncommon. Will get the kit this week. Thanks, Charles ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Sunday, May 08, 2005 4:33 PM Subject: Re: [WanderlodgeForum] Air Pressure Problem Hi Charles: There is a large hex looking body that unscrews from the lid. The purge valve is in there. Some times it takes mounting the lid gently in a vice and tapping the wrench connected to the hex below the lid to get it to separate then it just un screws. Then you will need a large blade screw driver and a 7/16" socket to remove the purge valve with. Good luck Safe travels, Ralph Fullenwider Dream_35_Team '85FC35 in Oklahoma Ralph's RV Solutions At 03:20 PM 5/8/2005 -0400, you wrote: >Tom, > >I want to make sure we are talking about the same thing. This cylinder is >virtical, at the bottom below the cylinder itself is what I assume is the >purge valve. It has what I think is an air line going into it and also an >electrical lead. The three screws attach the leaking cap and three bolts >attach the lower part (pruge valve) I think to the cylinder. I don't see >four screws anywhere. Do you think it is the same thing maybe just a >different mounting arrangement? > >Charles > ----- Original Message ----- > From: Tom Warner > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, May 08, 2005 2:48 PM > Subject: Re: [WanderlodgeForum] Air Pressure Problem > > > Still the same fix as the first time you asked back in March. Remove the > complete purge valve from the bottom and get a new kit and replace it. See > below the last time I posted this. > > Tom > 1982 FC35 > Vernon Center,NY > > At 02:23 PM 5/8/2005 -0400, you wrote: > >Hello again all, > > > >Well now that all the planets are back in alignment (my travel has slowed > >down, the weather is nice, some honeydoo's are completed) I am back to > this > >problem. I imagine all of you were on the right track but let me try to > >describe it a little better. At the bottom of the cylinder is a small > >philips head screw that secures a rubber washer to a round cap about the > >size of a coke bottle cap (new style, not the old one we had to use a > bottle > >opener for) I put that in just in case any of you are old enough to > remember > >bottle openers. This cap has a triangular shape base and is attached to a > >nut about 2 inches across by three small philips head screws. My question > >is do I need to unscrew the big nut? > > > > From the air dryer chalenged not so big nut. > > > > > >Charles > > > > > >Unscrew the part(4 screws) and take it to NAPA and get a new purge > valve kit > >Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix > >AD-2 air dryer. > > > >tom > >1982 FC35 > >Ab > >----- Original Message ----- > >From: > >To: > >Sent: Sunday, March 13, 2005 1:33 PM > >Subject: [Wanderlodge] Air Pressure Problem > > > > > > > > > > > > > Hi All, > > > > > > > > > > > > Just cranked up the bird (83 FC 35) and the air pressure doesn't > come up. > > > I have traced the problem to a vertical cylinder next to the drive > shaft > > > about midway of the coach. The air is escaping around a rubber washer > > > secured by a small Philips head screw at the bottom of the cylinder. > > > Should I just replace the rubber washer or is this a larger problem? > > > > > > > > > > > > Thanks, > > > > > > > > > > > > Charles > > > > > > 83 FC 35 > > > > > > Stone Mountain GA > > > > ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-13-2005, 12:31
Have you replaced the air governor on the compressor under the dog
house? It signals the purge valve to dump, and is likely the root cause. Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, > Ralph, YOU THE MAN > > The hex body came off with everything still mounted on the coach. Took it apart. Some gunk inside. The O rings still look in good shape but thats not uncommon. Will get the kit this week. > > Thanks, > > Charles > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, May 08, 2005 4:33 PM > Subject: Re: [WanderlodgeForum] Air Pressure Problem > > > Hi Charles: > > There is a large hex looking body that unscrews from the lid. The purge > valve is in there. Some times it takes mounting the lid gently in a vice > and tapping the wrench connected to the hex below the lid to get it to > separate then it just un screws. Then you will need a large blade screw > driver and a 7/16" socket to remove the purge valve with. > > Good luck > > Safe travels, > > Ralph Fullenwider > Dream_35_Team > '85FC35 in Oklahoma > Ralph's RV Solutions > > > At 03:20 PM 5/8/2005 -0400, you wrote: > >Tom, > > > >I want to make sure we are talking about the same thing. This cylinder is > >virtical, at the bottom below the cylinder itself is what I assume is the > >purge valve. It has what I think is an air line going into it and also an > >electrical lead. The three screws attach the leaking cap and three bolts > >attach the lower part (pruge valve) I think to the cylinder. I don't see > >four screws anywhere. Do you think it is the same thing maybe just a > >different mounting arrangement? > > > >Charles > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, May 08, 2005 2:48 PM > > Subject: Re: [WanderlodgeForum] Air Pressure Problem > > > > > > Still the same fix as the first time you asked back in March. Remove the > > complete purge valve from the bottom and get a new kit and replace it. See > > below the last time I posted this. > > > > Tom > > 1982 FC35 > > Vernon Center,NY > > > > At 02:23 PM 5/8/2005 -0400, you wrote: > > >Hello again all, > > > > > >Well now that all the planets are back in alignment (my travel has slowed > > >down, the weather is nice, some honeydoo's are completed) I am back to > > this > > >problem. I imagine all of you were on the right track but let me try to > > >describe it a little better. At the bottom of the cylinder is a small > > >philips head screw that secures a rubber washer to a round cap about the > > >size of a coke bottle cap (new style, not the old one we had to use a > > bottle > > >opener for) I put that in just in case any of you are old enough to > > remember > > >bottle openers. This cap has a triangular shape base and is attached to a > > >nut about 2 inches across by three small philips head screws. My question > > >is do I need to unscrew the big nut? > > > > > > From the air dryer chalenged not so big nut. > > > > > > > > >Charles > > > > > > > > >Unscrew the part(4 screws) and take it to NAPA and get a new purge > > valve kit > > >Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix > > >AD-2 air dryer. > > > > > >tom > > >1982 FC35 > > >Ab > > >----- Original Message ----- > > >From: > > >To: > > >Sent: Sunday, March 13, 2005 1:33 PM > > >Subject: [Wanderlodge] Air Pressure Problem > > > > > > > > > > > > > > > > > > Hi All, > > > > > > > > > > > > > > > > Just cranked up the bird (83 FC 35) and the air pressure doesn't > > come up. > > > > I have traced the problem to a vertical cylinder next to the drive > > shaft > > > > about midway of the coach. The air is escaping around a rubber washer > > > > secured by a small Philips head screw at the bottom of the cylinder. > > > > Should I just replace the rubber washer or is this a larger problem? > > > > > > > > > > > > > > > > Thanks, > > > > > > > > > > > > > > > > Charles > > > > > > > > 83 FC 35 > > > > > > > > Stone Mountain GA > > > > > > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
