trip odometer
07-25-2007, 08:08
trip odometer
Is there a source for the trip odometer? My coach has one above the drivers
window.
Teleflex number is 52545,
BB doesn't have one in stock.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
07-25-2007, 09:15
trip odometer
Fred, I would start here:
Joe Federsel
Technical Support
Teleflex Marine
Sarasota, FL
941-907-1000
techsupport@...
If the meter is like the gauges the number may have been changed. Mr. Federsel
should be able to give you the info. He will not sell direct but should be able
to give you a #pn and tell you where to buy. I got what I needed from West
Marine special order. When you find the info please post it and we will see if
Mike B will add it to the Teleflex chart I put together for the files.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
To: Wanderlodge@yahoogroups.com ; wanderlodgeforum@yahoogroups.com
Sent: Wednesday, July 25, 2007 3:08 PM
Subject: [WanderlodgeForum] trip odometer
window.
Fred & Jeanne Hulse
Morristown Arizona
07-25-2007, 14:24
trip odometer
Thank you Leroy.
Fred & Jeanne Hulse
Morristown Arizona
07-25-2007, 14:56
trip odometer
Since you mention the trip odometer, perhaps someone could explain
how it works. I notice that mine 'clicks' a new tenth of a mile even
when I'm not moving. It seems to have a mind of its own and never
seems to match the miles on the odometer inside the speedometer. (I
also note that a fast idle speed will often show 5 mph on the
speedometer, even when I'm parked.)
El Sobrante CA
aeonix1@...
> Joe Federsel
> Technical Support
> Teleflex Marine
> Sarasota, FL
> 941-907-1000
> techsupport@...
<snip>
07-25-2007, 15:23
trip odometer
Well, I do not know how the trip meter works or where it gets its data. I do
know that mine does not spool up on its own and is more accurate than the
odometer. I have checked both against the GPS and have found the following over
a short trip.
GPS miles-471
Trip meter-473
Odometer-481
The ole bus doesn't have as many miles as stated. I believe the GPS.
I do not have the speedometer problem either. Wish I knew how to help.
Leroy Eckert
Niceville, FL
Royale Conversion
Sent: Wednesday, July 25, 2007 9:56 PM
Subject: Re: [WanderlodgeForum] trip odometer
El Sobrante CA
aeonix1@...
> Joe Federsel
> Technical Support
> Teleflex Marine
> Sarasota, FL
> 941-907-1000
> techsupport@...
<snip>
07-27-2007, 15:33
trip odometer
Below is the reply from Teleflex regarding the trip odometer I was looking for.
Fred & Jeanne Hulse
Morristown Arizona
Hello Fred, this item is discontinued and never replaced. Sorry!
Joe Federsel
Technical Support
Teleflex Marine
Sarasota Florida
941/907-1000
941/907-1020 Fax
techsupport@...
Sent: Wednesday, July 25, 2007 10:29 PM
To: Techsupport
Subject: Teleflex trip odometer
Hi Joe
I am looking for a trip odometer Blue Bird used as original equipment in my 97
Wanderlodge.
They (Blue Bird) said the part # is 52545 but dont't stock it.
Can you refer me to a distributor that will supply this to me?
Thanks in advance.
Fred Hulse
Morristown Arizona
