cat 3208 fuel leak
07-31-2007, 10:47
cat 3208 fuel leak
I am collecting fuel oil in my engine valley "center of the block"
Just got done removing and replacing the fuel injector pump and couldn't find anything wrong. I checked the weep hole and it has a hose that would take any excess fuel and dump it out the hose. At this point i am stumped! There is nothing else on the bottom of the pump that could leak. I have checked all the lines and looked for fuel that could be traveling from another area but everything above the pump is dry. Anyone out there had this problem? jim |
07-31-2007, 12:22
cat 3208 fuel leak
You need to talk to Mike Honstein
On 31/07/07, jimbojcs > > I am collecting fuel oil in my engine valley "center of the block" > Just got done removing and replacing the fuel injector pump and > couldn't find anything wrong. I checked the weep hole and it has a > hose that would take any excess fuel and dump it out the hose. At this > point i am stumped! There is nothing else on the bottom of the pump > that could leak. I have checked all the lines and looked for fuel that > could be traveling from another area but everything above the pump is > dry. Anyone out there had this problem? jim > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
07-31-2007, 13:07
cat 3208 fuel leak
What year Bird??? Where are you located???
Clean the area of all fuel deposits., use shop rags , paper towels , clean with carb or brake cleaner, These solvents are really flamable Check all fuel lines from the injector pump to the injectors. Did you remove and replace the entire injector pump???? The throttle rod seal is another high probability. I placed a repair procedure in the files, for this seal repair. Try this at your own risk...... Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "jimbojcs" wrote: > > I am collecting fuel oil in my engine valley "center of the block" > Just got done removing and replacing the fuel injector pump and > couldn't find anything wrong. I checked the weep hole and it has a > hose that would take any excess fuel and dump it out the hose. At this > point i am stumped! There is nothing else on the bottom of the pump > that could leak. I have checked all the lines and looked for fuel that > could be traveling from another area but everything above the pump is > dry. Anyone out there had this problem? jim > |
07-31-2007, 15:44
cat 3208 fuel leak
All good points. Usually it take repeated use of the brake clean can and close
observation to find stubborn leaks. Real tough ones might require dye and the ol' black light and a mirror. MH ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 31, 2007 7:07 PM Subject: [WanderlodgeForum] Re: cat 3208 fuel leak What year Bird??? Where are you located??? Clean the area of all fuel deposits., use shop rags , paper towels , clean with carb or brake cleaner, These solvents are really flamable Check all fuel lines from the injector pump to the injectors. Did you remove and replace the entire injector pump???? The throttle rod seal is another high probability. I placed a repair procedure in the files, for this seal repair. Try this at your own risk...... Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "jimbojcs" wrote: > > I am collecting fuel oil in my engine valley "center of the block" > Just got done removing and replacing the fuel injector pump and > couldn't find anything wrong. I checked the weep hole and it has a > hose that would take any excess fuel and dump it out the hose. At this > point i am stumped! There is nothing else on the bottom of the pump > that could leak. I have checked all the lines and looked for fuel that > could be traveling from another area but everything above the pump is > dry. Anyone out there had this problem? jim > [Non-text portions of this message have been removed] |
04-11-2021, 23:01
(This post was last modified: 04-11-2021 23:02 by cuttn4fun.)
RE: cat 3208 fuel leak
New member here searching for information on the 3208 i have. It is leaking diesel and thought it was throttle rod. Got that all replaced and still leaking. Took it apart to find it leaking at the spot circled in red.fuel is just bubbling up from the spot with the yellow dot under the small cover. Any help is greatly appreciated.
