How Hot is HOT
05-08-2005, 10:29
How Hot is HOT
Does anyone know at what temperature the engine temp alarm is to come
on at?
05-08-2005, 10:34
How Hot is HOT
Let me try this again... Does anyone know at what temperature the
engine waring buzzer is to come on in a 1983 3208T?
05-09-2005, 06:49
How Hot is HOT
Hi,
Your Yahoo! ID looks familiar but I don't recall who you are.
The buzzer and light are activated by a 210 degree sender on the front
of the engine in the same area as the 185 degree fan switch and the
sender for the temp gauge.
What this means operationally is that the gauge and buzzer/light
should agree that the engine is HOT and the fan should be on. The
thermostats should also be fully open at 195 +/- 2 degrees, if they
are the original CAT units.
As a technique, if you find yourself in a situation where you are
unable to pull over while overheating (likely, since I've found the
CAT will not normally overheat unless climbing a fairly steep grade),
turn on your chassis heaters by switching to the winter position (you
might want to pre-position the chassis thermostat to on, and the fans
to high), your front heaters, the aux pump, and even possibly start
the generator to shed the 12volt load onto the chargers and off of the
alternator.
Gary Miller
83 FC 33
Wauwatosa, WI
--- In WanderlodgeForum@yahoogroups.com, "bluebird3208"
05-09-2005, 10:06
How Hot is HOT
Thanks Gary
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gary Miller
Sent: Monday, May 09, 2005 11:49 AM
Subject: [WanderlodgeForum] Re: How Hot is HOT
Hi,
alternator.
Gary Miller
83 FC 33
Wauwatosa, WI
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
