Retarder for PT36
08-06-2007, 03:31
Retarder for PT36
I will give you a layman's explanation (as I've been told) of how the
retarder works.... It is a integral to the transmission, where when activated, forces transmission fluid into a compressor-fan type of device, putting trans fluid backwards through the trans, creating drag, thus slowing the vehicle. The downside is since the trans fluid in the retarder is creating drag (friction), the trans fluid absorbs the heat very rapidly thusly you have to keep a close eye on the trans retarder temp, and the trans fluid temp. If it is overheated, it looses it's lubricity, and ability to dissipate heat, with the potential of damaging the trans. The trans fluid cools down quickly once it heats up, and the faster you can get the fluid through the coolers/trans, the better (lower gear, spinning up the RPM's). I use the retarder all the time, even when driving around town, but I always keep one eye on the retarder temp, and one on the road ahead. Secret is NOT to go too fast....use the retarder on down hills to slow you down, and use the service brakes and the retarder alternately to keep your speed well below what you would deem safe in a car. The dashboard Retarder rocker on/off switch either turns the system on or off, and the lever you move up and down modulates the amount of braking (full down max, all the way up minimal) I know....it's a layman's explanation...if you want something more technical, refer to your Allison book, or your BB Blue Book if you have 'em. Best of luck.... Kevin McKeown Yorba Linda, CA 1986 38' PT ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-06-2007, 03:48
Retarder for PT36
Can anyone give a discription of the retarder on my coach. I know that
it is a function of the transmission, has an operating lever on the left side of the dash, and an on/off switch on the left side. I don't think mine is working. Could it be electrical? Art Weatherly Riverside Ca '85 PT36 |
08-06-2007, 06:10
Retarder for PT36
Art,
A sure way to test is to turn retarder switch on, excelerate to 30 -40 mph and depress retarder handle only to slow the coach. Howard T., Sowega, 86 PT40 ----- Original Message ----- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 06, 2007 11:48 AM Subject: [WanderlodgeForum] Retarder for PT36 Can anyone give a discription of the retarder on my coach. I know that it is a function of the transmission, has an operating lever on the left side of the dash, and an on/off switch on the left side. I don't think mine is working. Could it be electrical? Art Weatherly Riverside Ca '85 PT36 ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.476 / Virus Database: 269.11.2/931 - Release Date: 8/1/2007 4:53 PM [Non-text portions of this message have been removed] |
08-06-2007, 13:45
Retarder for PT36
Simply put the retarder reverses the oil flow striking the stator and tries to
stop it from turning, this is all done in the torque converter not the transmission. normal driving when you apply the brake th e retarder works also, if you pull the handle the switch must be on to work, WHAT THE TRANSMISSION TEMP IT WILL GET AWQAY FROM YOU.i > > From: "amweath" > Date: 2007/08/06 Mon AM 11:48:47 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Retarder for PT36 > > Can anyone give a discription of the retarder on my coach. I know that > it is a function of the transmission, has an operating lever on the > left side of the dash, and an on/off switch on the left side. > > I don't think mine is working. Could it be electrical? > > Art Weatherly > Riverside Ca > '85 PT36 > > > |
08-06-2007, 14:02
Retarder for PT36
I hope they put an actuator light on those metallic retarders. I nearly set my
84FC on fire in Flagstaff, Arizona because I forgot and left it on. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: putneyflash@...: Mon, 6 Aug 2007 21:45:21 -0400Subject: Re: [WanderlodgeForum] Retarder for PT36 Simply put the retarder reverses the oil flow striking the stator and tries to stop it from turning, this is all done in the torque converter not the transmission. normal driving when you apply the brake th e retarder works also, if you pull the handle the switch must be on to work, WHAT THE TRANSMISSION TEMP IT WILL GET AWQAY FROM YOU.i> > From: "amweath" 2007/08/06 Mon AM 11:48:47 EDT> To: WanderlodgeForum@yahoogroups.com> Subject: [WanderlodgeForum] Retarder for PT36> > Can anyone give a discription of the retarder on my coach. I know that> it is a function of the transmission, has an operating lever on the> left side of the dash, and an on/off switch on the left side. > > I don't think mine is working. Could it be electrical?> > Art Weatherly> Riverside Ca> '85 PT36> > > _________________________________________________________________ Messenger Café â open for fun 24/7. Hot games, cool activities served daily. Visit now. http://cafemessenger.com?ocid=TXT_TAGLM_AugWLtagline [Non-text portions of this message have been removed] |
