'00 LXi Starter Batteries
08-07-2007, 03:55
We just returned from Maine to find the starter batteries too low to
start the engine. I know I can start the motor by using the emergency switch on the dash, but my question is, if I leave this switch on while the bus is stored, will the inverters keep both banks (house and starters) of batteries charged? Also, does anyone know how/if the generator battery is charged by the inverters? Thank you! Allen and Conny '00 LXi, "Lone Wolf" Tampa, FL |
08-07-2007, 04:00
Allen and Conny,
When the coach is plugged in, my understanding is that only the house batteries are being charged unless you have both banks selected on the dash. Then I believe all 10 are being charged. All are also charged by the alternator. Your manual is the ultimate authority on that. I had original batteries..and had to replace everything but my generator battery right after I bought the coach this spring. Went with all AGM's at 250/per. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: gulfquest@...: Tue, 7 Aug 2007 15:55:55 +0000Subject: [WanderlodgeForum] '00 LXi Starter Batteries We just returned from Maine to find the starter batteries too low to start the engine. I know I can start the motor by using the emergency switch on the dash, but my question is, if I leave this switch on while the bus is stored, will the inverters keep both banks (house and starters) of batteries charged? Also, does anyone know how/if the generator battery is charged by the inverters?Thank you!Allen and Conny'00 LXi, "Lone Wolf"Tampa, FL _________________________________________________________________ See what youâre getting intoâ¦before you go there http://newlivehotmail.com/?ocid=TXT_TAGH...eview_0507 [Non-text portions of this message have been removed] |
08-07-2007, 04:14
The chassis battery switch on the dash can be left on
when in storage. The converter will trickle charge the chassis battery properly, according to Bennie. On my coach the generator battery dash switch is a momentary switch which means that the gennie battery is not charged during storage. I purchased an Xantex Echo charger to charge the gennie battery from the converter. *http://tinyurl.com/yp48u2* David Brady '02 LXi, NC Allen & Conny wrote: > > We just returned from Maine to find the starter batteries too low to > start the engine. I know I can start the motor by using the emergency > switch on the dash, but my question is, if I leave this switch on > while the bus is stored, will the inverters keep both banks (house and > starters) of batteries charged? > > Also, does anyone know how/if the generator battery is charged by the > inverters? > > Thank you! > > Allen and Conny > '00 LXi, "Lone Wolf" > Tampa, FL > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.11.8/940 - Release Date: 8/6/2007 4:53 PM > [Non-text portions of this message have been removed] |
08-07-2007, 04:58
Thanks Brad! We bought our BB just 2 months ago and we are still
learning the systems. Our coach had 3 defective house gell cells upon delivery which were replaced during the PDI. I'm not sure the starters were checked though...I'll throw the switch tonight and see how they do. -Allen --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > > Allen and Conny, > When the coach is plugged in, my understanding is that only the house batteries are being charged unless you have both banks selected on the dash. Then I believe all 10 are being charged. All are also charged by the alternator. Your manual is the ultimate authority on that. I had original batteries..and had to replace everything but my generator battery right after I bought the coach this spring. Went with all AGM's at 250/per. Brad Barton 00LXiDFW bbartonwx@... > > > To: WanderlodgeForum@...: gulfquest@...: Tue, 7 Aug 2007 15:55:55 +0000Subject: [WanderlodgeForum] '00 LXi Starter Batteries > > > > > We just returned from Maine to find the starter batteries too low to start the engine. I know I can start the motor by using the emergency switch on the dash, but my question is, if I leave this switch on while the bus is stored, will the inverters keep both banks (house and starters) of batteries charged? Also, does anyone know how/if the generator battery is charged by the inverters?Thank you!Allen and Conny'00 LXi, "Lone Wolf"Tampa, FL > > > _________________________________________________________________ > See what you're getting intoâ¦before you go there > http://newlivehotmail.com/? ocid=TXT_TAGHM_migration_HM_viral_preview_0507 > > [Non-text portions of this message have been removed] > |
08-07-2007, 05:00
Thanks David! I knew you would know this one (you probably have the
answers to the filters and belts question I posted :-)) Where did you get the power for the Xantex in the genset battery compartment? -Allen --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > The chassis battery switch on the dash can be left on > when in storage. The converter will trickle charge the > chassis battery properly, according to Bennie. On my > coach the generator battery dash switch is a momentary > switch which means that the gennie battery is not charged > during storage. I purchased an Xantex Echo charger to > charge the gennie battery from the converter. > > *http://tinyurl.com/yp48u2* > > David Brady > '02 LXi, NC > > Allen & Conny wrote: > > > > We just returned from Maine to find the starter batteries too low to > > start the engine. I know I can start the motor by using the emergency > > switch on the dash, but my question is, if I leave this switch on > > while the bus is stored, will the inverters keep both banks (house and > > starters) of batteries charged? > > > > Also, does anyone know how/if the generator battery is charged by the > > inverters? > > > > Thank you! > > > > Allen and Conny > > '00 LXi, "Lone Wolf" > > Tampa, FL > > > > > > ----------------------------------------------------------------- ------- > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.11.8/940 - Release Date: 8/6/2007 4:53 PM > > > > > > [Non-text portions of this message have been removed] > |
08-07-2007, 06:15
Allen,
I tapped into the load center at the lower right dash. As far as filters, Rich's list is pretty impressive. I have one addition for the genny air filter: NAPA 2222 David Brady '02 LXi, NC |
08-08-2007, 07:56
Great! Thanks Dave!
--- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Allen, > > I tapped into the load center at the lower right dash. > > As far as filters, Rich's list is pretty impressive. I have > one addition for the genny air filter: > > NAPA 2222 > > David Brady > '02 LXi, NC > |
