Water Leak
05-08-2005, 14:40
Water Leak
Just now getting around to my anual de winterizing program and
hooking up my water line as usual, every thing was going great. Been doing the same produre for many years (winterizing and dewinterizing) with NO PROBLEMS till now. Had presure at all point of need (toilet, wash bowel, shower, kitchen sink, etc.)from the city hook up...Went out side to start filling the water tank (throwing the switch in the hook up compentment area/ electric land line hook up area)... Went on with my business and was walking around the rear of the coach and noticed water leaking from the water heater area into the engine area / down the the ground (nature's plumbing law)....Thus, I went to the rear of the coach (inside) to the water heater area and there I noticed a steady small pin hole type spray of water on the brass vale (this looks to have means to devert city vs. water tank fill with, looks like a air line to this unit. It also tees in to the water heateralso. On the side of the unit where it is leaking, I am to the opinion some exposy or JB Weld might be the trick vs. taking the unit out and replacing it (last thing I want to do for finding the part and trying to get the coach ready for next weekend outing). It seems to be near a seem of the brass unit since screws are holding the cup cover type unit to the main body) but 1/16" or 1/8" from the seem with a pin type hole that I can hold my finger on it and it stops the source of leak. Leak is there no matter what position I have the switch in (City or Fill)---(Boy am I stong)!!! I gusess the winter freeze might of got this or my real question is, "is this round tpye hole it there by design and will I screw the unit up by pluging with water expoy or JB Weld to stop the leak source??? What would your take be on this little unkown leak? I am having some problems wondering that the leak is of a round type hole vs. a normal hair line crack that would be noticed from a winter type freeze problem (reason for my concern of plugging the leak source???) and what would the the proper fix be? I just love it when Murhy greets me on my time line!!!! WHY ME? Gregg New Castle, IN 85 PT40 |
05-08-2005, 14:44
Water Leak
Where your water heater controls (mine are in a trap door on the side of
the bed frame) are you will find the air pressure switch. Cycle it a couple of times and the leak should go off. I had the same problem a while ago. tom 1982 FC35 Vernon Center,NY At 02:40 AM 5/9/2005 +0000, you wrote: >Just now getting around to my anual de winterizing program and >hooking up my water line as usual, every thing was going great. Been >doing the same produre for many years (winterizing and dewinterizing) >with NO PROBLEMS till now. Had presure at all point of need (toilet, >wash bowel, shower, kitchen sink, etc.)from the city hook up...Went >out side to start filling the water tank (throwing the switch in the >hook up compentment area/ electric land line hook up area)... > >Went on with my business and was walking around the rear of the coach >and noticed water leaking from the water heater area into the engine >area / down the the ground (nature's plumbing law)....Thus, I went to >the rear of the coach (inside) to the water heater area and there I >noticed a steady small pin hole type spray of water on the brass vale >(this looks to have means to devert city vs. water tank fill with, >looks like a air line to this unit. It also tees in to the water >heateralso. On the side of the unit where it is leaking, I am to the >opinion some exposy or JB Weld might be the trick vs. taking the unit >out and replacing it (last thing I want to do for finding the part >and trying to get the coach ready for next weekend outing). It seems >to be near a seem of the brass unit since screws are holding the cup >cover type unit to the main body) but 1/16" or 1/8" from the seem >with a pin type hole that I can hold my finger on it and it stops the >source of leak. Leak is there no matter what position I have the >switch in (City or Fill)---(Boy am I stong)!!! I gusess the winter >freeze might of got this or my real question is, "is this round tpye >hole it there by design and will I screw the unit up by pluging with >water expoy or JB Weld to stop the leak source??? > >What would your take be on this little unkown leak? I am having some >problems wondering that the leak is of a round type hole vs. a normal >hair line crack that would be noticed from a winter type freeze >problem (reason for my concern of plugging the leak source???) and >what would the the proper fix be? I just love it when Murhy greets >me on my time line!!!! WHY ME? > >Gregg >New Castle, IN >85 PT40 > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
05-08-2005, 14:55
Water Leak
Tom:
Thanks for the reply...I'll try that and that seems to make sence since I notice the air line conected to this unit... I'll have to start the coach up and build up the air and cycle the air switch as you mentioned.... I'll do this tomorrow after work and before I go pluging the round type hole....I just feel the hole is there for a reason and the air switch just might of been left in the wrong position from my winterizing procedure. Thanks.... Any other thoughts from the group before I go and screw the unit up...HE HE!! Gregg New Castle,IN 85 PT40 ----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Sunday, May 08, 2005 9:44 PM Subject: Re: [WanderlodgeForum] Water Leak Where your water heater controls (mine are in a trap door on the side of the bed frame) are you will find the air pressure switch. Cycle it a couple of times and the leak should go off. I had the same problem a while ago. tom 1982 FC35 Vernon Center,NY At 02:40 AM 5/9/2005 +0000, you wrote: >Just now getting around to my anual de winterizing program and >hooking up my water line as usual, every thing was going great. Been >doing the same produre for many years (winterizing and dewinterizing) >with NO PROBLEMS till now. Had presure at all point of need (toilet, >wash bowel, shower, kitchen sink, etc.)from the city hook up...Went >out side to start filling the water tank (throwing the switch in the >hook up compentment area/ electric land line hook up area)... > >Went on with my business and was walking around the rear of the coach >and noticed water leaking from the water heater area into the engine >area / down the the ground (nature's plumbing law)....Thus, I went to >the rear of the coach (inside) to the water heater area and there I >noticed a steady small pin hole type spray of water on the brass vale >(this looks to have means to devert city vs. water tank fill with, >looks like a air line to this unit. It also tees in to the water >heateralso. On the side of the unit where it is leaking, I am to the >opinion some exposy or JB Weld might be the trick vs. taking the unit >out and replacing it (last thing I want to do for finding the part >and trying to get the coach ready for next weekend outing). It seems >to be near a seem of the brass unit since screws are holding the cup >cover type unit to the main body) but 1/16" or 1/8" from the seem >with a pin type hole that I can hold my finger on it and it stops the >source of leak. Leak is there no matter what position I have the >switch in (City or Fill)---(Boy am I stong)!!! I gusess the winter >freeze might of got this or my real question is, "is this round tpye >hole it there by design and will I screw the unit up by pluging with >water expoy or JB Weld to stop the leak source??? > >What would your take be on this little unkown leak? I am having some >problems wondering that the leak is of a round type hole vs. a normal >hair line crack that would be noticed from a winter type freeze >problem (reason for my concern of plugging the leak source???) and >what would the the proper fix be? I just love it when Murhy greets >me on my time line!!!! WHY ME? > >Gregg >New Castle, IN >85 PT40 > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-08-2005, 14:58
Water Leak
Mine has a threaded hole in the bottom of the valve. I am going to see if
it should have a plug. I have got the technical literature for the valve in the coach and will check on it tomorrow. Maybe someone else knows. tom 1982 FC35 Vernon Center,NY At 09:55 PM 5/8/2005 -0500, you wrote: >Tom: > >Thanks for the reply...I'll try that and that seems to make sence since I >notice the air line conected to this unit... > >I'll have to start the coach up and build up the air and cycle the air >switch as you mentioned.... > >I'll do this tomorrow after work and before I go pluging the round type >hole....I just feel the hole is there for a reason and the air switch just >might of been left in the wrong position from my winterizing procedure. > >Thanks.... > >Any other thoughts from the group before I go and screw the unit up...HE HE!! > >Gregg >New Castle,IN >85 PT40 > ----- Original Message ----- > From: Tom Warner > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, May 08, 2005 9:44 PM > Subject: Re: [WanderlodgeForum] Water Leak > > > Where your water heater controls (mine are in a trap door on the side of > the bed frame) are you will find the air pressure switch. Cycle it a > couple > of times and the leak should go off. I had the same problem a while ago. > > tom > 1982 FC35 > Vernon Center,NY > > At 02:40 AM 5/9/2005 +0000, you wrote: > >Just now getting around to my anual de winterizing program and > >hooking up my water line as usual, every thing was going great. Been > >doing the same produre for many years (winterizing and dewinterizing) > >with NO PROBLEMS till now. Had presure at all point of need (toilet, > >wash bowel, shower, kitchen sink, etc.)from the city hook up...Went > >out side to start filling the water tank (throwing the switch in the > >hook up compentment area/ electric land line hook up area)... > > > >Went on with my business and was walking around the rear of the coach > >and noticed water leaking from the water heater area into the engine > >area / down the the ground (nature's plumbing law)....Thus, I went to > >the rear of the coach (inside) to the water heater area and there I > >noticed a steady small pin hole type spray of water on the brass vale > >(this looks to have means to devert city vs. water tank fill with, > >looks like a air line to this unit. It also tees in to the water > >heateralso. On the side of the unit where it is leaking, I am to the > >opinion some exposy or JB Weld might be the trick vs. taking the unit > >out and replacing it (last thing I want to do for finding the part > >and trying to get the coach ready for next weekend outing). It seems > >to be near a seem of the brass unit since screws are holding the cup > >cover type unit to the main body) but 1/16" or 1/8" from the seem > >with a pin type hole that I can hold my finger on it and it stops the > >source of leak. Leak is there no matter what position I have the > >switch in (City or Fill)---(Boy am I stong)!!! I gusess the winter > >freeze might of got this or my real question is, "is this round tpye > >hole it there by design and will I screw the unit up by pluging with > >water expoy or JB Weld to stop the leak source??? > > > >What would your take be on this little unkown leak? I am having some > >problems wondering that the leak is of a round type hole vs. a normal > >hair line crack that would be noticed from a winter type freeze > >problem (reason for my concern of plugging the leak source???) and > >what would the the proper fix be? I just love it when Murhy greets > >me on my time line!!!! WHY ME? > > > >Gregg > >New Castle, IN > >85 PT40 > > > > > > > > > >---------- > >Yahoo! Groups Links > > * To visit your group on the web, go to: > > * > > > <<http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/\ WanderlodgeForum/>http://groups.yahoo.com/group/WanderlodgeForum/ > > > > > * > > * To unsubscribe from this group, send an email to: > > * > > > odgeForum-unsubscribe@yahoogroups.com > > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > >------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > ><http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/\ WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
05-09-2005, 01:10
Water Leak
Hi Greg:
The valve your describing is a three way valve and it's only purpose is to introduce air into the system at the bottom of the water heater to blow out the water lines and heater for winterizing. With the air off the shuttle ( spring loaded opposite end) closes and water is directed from the sporlan to your freshwater tank or city water. The shuttle in the valve will stick open with calcium or whatever in the seat and allow water to escape through the pin hole that is supposed to allow the air to bleed off from the valve when the air switch is closed. There should be 4 screws holding the end cap on the valve, I have had to remove the cap and with needle nose pliers, move the shuttle back and forth to free it up. Some times this works, but I have had to remove the valve ( royal pain to get to) and take it apart, clean and lube the valve then re install it. By using JB or something else, you will defeat the purpose of the valve and not really gain anything because it wont hold long term and may actually start introducing air into your water system from the Coach air. Good luck Safe travels, Ralph Fullenwider Dream_35_Team '85FC35 in Oklahoma Ralph's RV Solutions At 02:40 AM 5/9/2005 +0000, you wrote: >Just now getting around to my anual de winterizing program and >hooking up my water line as usual, every thing was going great. Been >doing the same produre for many years (winterizing and dewinterizing) >with NO PROBLEMS till now. Had presure at all point of need (toilet, >wash bowel, shower, kitchen sink, etc.)from the city hook up...Went >out side to start filling the water tank (throwing the switch in the >hook up compentment area/ electric land line hook up area)... > >Went on with my business and was walking around the rear of the coach >and noticed water leaking from the water heater area into the engine >area / down the the ground (nature's plumbing law)....Thus, I went to >the rear of the coach (inside) to the water heater area and there I >noticed a steady small pin hole type spray of water on the brass vale >(this looks to have means to devert city vs. water tank fill with, >looks like a air line to this unit. It also tees in to the water >heateralso. On the side of the unit where it is leaking, I am to the >opinion some exposy or JB Weld might be the trick vs. taking the unit >out and replacing it (last thing I want to do for finding the part >and trying to get the coach ready for next weekend outing). It seems >to be near a seem of the brass unit since screws are holding the cup >cover type unit to the main body) but 1/16" or 1/8" from the seem >with a pin type hole that I can hold my finger on it and it stops the >source of leak. Leak is there no matter what position I have the >switch in (City or Fill)---(Boy am I stong)!!! I gusess the winter >freeze might of got this or my real question is, "is this round tpye >hole it there by design and will I screw the unit up by pluging with >water expoy or JB Weld to stop the leak source??? > >What would your take be on this little unkown leak? I am having some >problems wondering that the leak is of a round type hole vs. a normal >hair line crack that would be noticed from a winter type freeze >problem (reason for my concern of plugging the leak source???) and >what would the the proper fix be? I just love it when Murhy greets >me on my time line!!!! WHY ME? > >Gregg >New Castle, IN >85 PT40 > > |
05-10-2005, 14:34
Water Leak
Ralph:
Great help from you and various members of the group..... I made sure no water pressure was on the check valve and proceeded with the air activation (on and off cycle 3-4 times or so) after bringing the coach above 80psi + as I normally do for the winterization and also cycle the hot water tank air fill switch too. After putting the switch back to their normal positions. I then hooked the water supply line (hose) up and bleed all air in the water lines at their stations till solid water ran out (toilet, sink, tube, & kitchen sink) & checked the 3 way valve and found no leak on the air input side.....YEA!!! I then proceeded doing the water tank fill up and started the pump (still using the old Par Pump that came with the coach / till she gives out and then I get the current version to replace it--but for now she still works).....I am now checking for all leaks and filling the ice maker up (cycle) and I need to check the washer/dryer, but that will have to wait for another day....I got to get to bed for work starts early for me.... I very much thank you and various other member of the forum for the various thoughts and idea of what to look out for and some day I'll probaby need to repair or replace the 3 way valve unit. I'll probaby be ok for now (this item is just for us winter boys). I guess there got some type of dirt, etc. on the check valve and it didn't get closed from the winterization and Murphy was waiting on me for the suprise.... Regards Gregg Kizer New Castle, IN KB9BG (ham call letters) 85 40PT PS I am glad I didn't have to do the dismantal process...... ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 09, 2005 8:10 AM Subject: Re: [WanderlodgeForum] Water Leak Hi Greg: The valve your describing is a three way valve and it's only purpose is to introduce air into the system at the bottom of the water heater to blow out the water lines and heater for winterizing. With the air off the shuttle ( spring loaded opposite end) closes and water is directed from the sporlan to your freshwater tank or city water. The shuttle in the valve will stick open with calcium or whatever in the seat and allow water to escape through the pin hole that is supposed to allow the air to bleed off from the valve when the air switch is closed. There should be 4 screws holding the end cap on the valve, I have had to remove the cap and with needle nose pliers, move the shuttle back and forth to free it up. Some times this works, but I have had to remove the valve ( royal pain to get to) and take it apart, clean and lube the valve then re install it. By using JB or something else, you will defeat the purpose of the valve and not really gain anything because it wont hold long term and may actually start introducing air into your water system from the Coach air. Good luck Safe travels, Ralph Fullenwider Dream_35_Team '85FC35 in Oklahoma Ralph's RV Solutions At 02:40 AM 5/9/2005 +0000, you wrote: >Just now getting around to my anual de winterizing program and >hooking up my water line as usual, every thing was going great. Been >doing the same produre for many years (winterizing and dewinterizing) >with NO PROBLEMS till now. Had presure at all point of need (toilet, >wash bowel, shower, kitchen sink, etc.)from the city hook up...Went >out side to start filling the water tank (throwing the switch in the >hook up compentment area/ electric land line hook up area)... > >Went on with my business and was walking around the rear of the coach >and noticed water leaking from the water heater area into the engine >area / down the the ground (nature's plumbing law)....Thus, I went to >the rear of the coach (inside) to the water heater area and there I >noticed a steady small pin hole type spray of water on the brass vale >(this looks to have means to devert city vs. water tank fill with, >looks like a air line to this unit. It also tees in to the water >heateralso. On the side of the unit where it is leaking, I am to the >opinion some exposy or JB Weld might be the trick vs. taking the unit >out and replacing it (last thing I want to do for finding the part >and trying to get the coach ready for next weekend outing). It seems >to be near a seem of the brass unit since screws are holding the cup >cover type unit to the main body) but 1/16" or 1/8" from the seem >with a pin type hole that I can hold my finger on it and it stops the >source of leak. Leak is there no matter what position I have the >switch in (City or Fill)---(Boy am I stong)!!! I gusess the winter >freeze might of got this or my real question is, "is this round tpye >hole it there by design and will I screw the unit up by pluging with >water expoy or JB Weld to stop the leak source??? > >What would your take be on this little unkown leak? I am having some >problems wondering that the leak is of a round type hole vs. a normal >hair line crack that would be noticed from a winter type freeze >problem (reason for my concern of plugging the leak source???) and >what would the the proper fix be? I just love it when Murhy greets >me on my time line!!!! WHY ME? > >Gregg >New Castle, IN >85 PT40 > > ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
03-14-2006, 10:34
Water Leak
New member here, bought my first wanderlodge a few months back and
everything seamed to be going good until the last trip. I noticed water coming from under the fridge area. Possible water leak?? any ideas would be great. Rob Land O' Lakes,FL. 82 FC |
03-14-2006, 12:59
Water Leak
Oh, dear.. what fun.
Well my 81 FC Just had to have all its copper removed. -I did it myself. Check out my pics on some of the work done: http://autos.ph.groups.yahoo.com/group/W...rowse/4c94 All the pipes go under there. Cold, water pump, and Hot. So take your pick.. Let me know if you need any help, I have been there, done that. I should be able to help when you find out which one it is.-Or actually it could be water running from somewhere else coming out under the fridge. (water tank,ect) Stephen 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Rob Sent: Tuesday, March 14, 2006 5:34 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Water leak New member here, bought my first wanderlodge a few months back and everything seamed to be going good until the last trip. I noticed water coming from under the fridge area. Possible water leak?? any ideas would be great. Rob Land O' Lakes,FL. 82 FC [Non-text portions of this message have been removed] |
03-14-2006, 14:32
Water Leak
Could be from lots of places. The water tank is under the streetside
bed, open those top panels and look around for your leak. Next remove the drawer and pegboard under the sink, look at your water pump, filter, plumbing. Might find it there. The panel under the 'Fridge is only held on by two screws, probably the easiest place to start looking. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Rob" wrote: > > New member here, bought my first wanderlodge a few months back and > everything seamed to be going good until the last trip. I noticed water > coming from under the fridge area. Possible water leak?? any ideas > would be great. > Rob > Land O' Lakes,FL. > 82 FC > |
03-14-2006, 15:16
Water Leak
How much water? I don't know if the fridge has a drip pan or not,
but The lines run from the tank under the bed to the pump under the sink. I would look there first. Many of people seem to be buying buses from up north that have cracked pipe (not crack pipe) issues. I don't know if that is the case here or not.. I HOPE NOT!! Thanks Bruce Campbell Clearwater, FL 83'FC 35 SB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, "Rob" wrote: > > New member here, bought my first wanderlodge a few months back and > everything seamed to be going good until the last trip. I noticed water > coming from under the fridge area. Possible water leak?? any ideas > would be great. > Rob > Land O' Lakes,FL. > 82 FC > |
