turn signals (fuse?)
08-11-2007, 07:58
Hi group
haven't been on in a long while.
Had the bird to a shop in Medford yesterday, replaced a solednoid for
the levelers, checked the steering box bolts (one was nearly off) and
to see why the air horns quit.
Anyway to make a long story short I now have NO turn signals.....
readying for a trip (working for SE Publications doing RV site maps).
Sure hate to have to go back to Medford monday.....felt a little
skinned by the labor charges and time spent... after hours of making
sure there was air etc. (they told me I needed new horns- I asked them
if the horns were getting juice, they finally humored me and got up on
top to check, they were. Turned out the connections inside the back of
the horn just needed cleaning), also wanted the retarder greased and
the guy spend 20 minutes and couldn't find it. I showed him where it
was (zerk fitting).
I was also charged 1.1 hours of labor to clean battery terminals &
check fluid......the guys clock in and out of each job. One of them
went for a test drive with another mechanic and was gone a long time.
Beings it was after hours by the time I left the service manager was
already gone so I couldn't talk to him about the labor hours....
Had all turn signals when I went and it was after hours by the time I
hit the road...later realized I had no turn signals....
Wondering if there is a fuse or plug somewhere I can check.
Blast!
Thanks
Rose Mary
82 FC Side Bath
JP's White Bird
Oregon
08-11-2007, 08:30
Rose Mary,
My fuses for the turn signals are located right in front of your
right knee(when in the drivers seat). I have had that fuse pop twice
in 4 years.
Also, the flasher unit is in front of your left knee, mine was the
diameter of a half dollar and about 1 1/2" long mounted to the dash
by a spring clamp(sorta like the spring clamp you would hang a mop
or broom handle).
My 85PT40 has 2 fuses by right knee. 1 was for flashers, haven't had
any experience with the other fuse.
Jay Darst
85PT40 (Prevost sold and delivered)
Springfield/Sullivan, IL
--- In WanderlodgeForum@yahoogroups.com, "Rose Mary"
> Hi group
for
maps).
making
them
up on
back of
it
> was (zerk fitting).
time.
was
time I
> Blast!
> Thanks
> Rose Mary
> 82 FC Side Bath
> JP's White Bird
> Oregon
08-11-2007, 08:39
Rose Mary was the shop Robert's Motors of Medford?
On 11/08/07, Rose Mary wrote:
> Hi group
> was (zerk fitting).
> Blast!
> Thanks
> Rose Mary
> 82 FC Side Bath
> JP's White Bird
> Oregon
Rob, Sue & Merlin Robinson
94 WLWB
08-11-2007, 09:08
yes, Roberts Motors have been there before but wasn't too impressed
this time around.
Rose Mary
> > Hi group
> > was (zerk fitting).
> > Blast!
> > Thanks
> > Rose Mary
> > 82 FC Side Bath
> > JP's White Bird
> > Oregon
> 94 WLWB
08-11-2007, 10:03
Rose Mary if it wouldn't be too inconvient or possible too nosy, could you
elaborate on exactly what you had done. The reason I ask is that for several
years now we (forum members) have been recommending Roberts as a good spot
for service. If you could enlighten us to exactly what was done in your
service and what parts were replaced it might change a few minds. I sure
hope not thought because I've had some good work done there.
> this time around.
> Rose Mary
> "Rob Robinson"
> > > Hi group
> > > was (zerk fitting).
> > > Blast!
> > > Thanks
> > > Rose Mary
> > > 82 FC Side Bath
> > > JP's White Bird
> > > Oregon
> > 94 WLWB
94 WLWB
08-12-2007, 02:45
What the mechanic will probably tell you after a couple hours is that you were
just low on turn signal fluid.
08-12-2007, 11:48
ha! ha! sounds about right.
Anyway turn signals issue still unresolved. Have the front off and
have looked under the dash with a mirror and flashlight. Just can't
seem to find a fuse or flasher.....
Anyone with an 82 FC 35 side bath that can tell me where theirs is
located sure would appreciate it.
Don't want to take another 6 hr drive to and fro to that shop for
this...after the $500 I dropped there Friday for labor hours,(which I
fell was a rip for what was done... even tho the signals all worked
before I went there.....
If one light bulb were bad it wouldn't make the whole circuit quit
would it, I mean even the lights on the dash for the turn signals,
I'm thinking flasher????
thanks for your help
Rose Mary
82 FC 35
JP's White Bird
Oregon
--- In WanderlodgeForum@yahoogroups.com, Tommy Standard
that you were just low on turn signal fluid.
08-12-2007, 12:10
Rose Mary,
Turn Signals...Are you saying there is a bulb or more that do not light up?
If so, replace it/them, and let's hear what happens.
> Rose Mary
> 82 FC 35
> JP's White Bird
> Oregon
> Tommy Standard
Curt Sprenger
Anaheim Hills, CA
08-12-2007, 12:20
Curt
I just send you an email before checking back here....
the turn signals all worked before the visit to the shop Friday.
Anyway, no turn signal lights, as well as no lights on the dash for
the turn signals. Could a burnt out bulb make it all stop?
thanks
Rose Mary
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Rose Mary,
light up?
> > Rose Mary
> > 82 FC 35
> > JP's White Bird
> > Oregon
> > --- In
> > Tommy Standard
> Curt Sprenger
> Anaheim Hills, CA
08-12-2007, 12:27
Rose Mary - Are you in the northwest right now? Come on up to Port
Townsend next weekend and we'll find the problem. I know there's a
space 'cause there was a cancellation.
Bob Griesel
> Curt
> thanks
> Rose Mary
> > Rose Mary,
> light up?
can't
is
for
(which I
worked
quit
signals,
> > > Rose Mary
> > > 82 FC 35
> > > JP's White Bird
> > > Oregon
> > > --- In
> WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > > Tommy Standard
is
> > Curt Sprenger
> > Anaheim Hills, CA
