Hot water heater popoff valve
08-13-2007, 06:49
Hey group,
Had my popoff valve popoff last weekend. Thing is it's set to popoff at 210 degrees. Wasn't sure if the valve was bad or the thermostats. Changed them both out. The valve was harder as door is small in closet. Weird thing is the valve doesn't have anyplace to drain except in the compartment it is located. Noticed water running down the engine. On my PT36 the water fill and electric are in a compartment all their own. I drilled a hole in the compartment upper area and then with an adapter to the new valve (old one was the problem), ran a hose that I cut off and put a barbed fitting on and screwed it to the opening I had cut out. Now, if it ever pops off again, at least the water will drain outside instead of in the compartment. Probably never happen again... Might want to take a look at yours to see where it would drain if it pops off. Bob Lawrence 84 PT36 Tacoma, Wa. |
08-13-2007, 13:37
Hi Bob,
On my PT40, the popoff valve for the water heater is fitted with an adapter that is attached to a drain hose (think it's heater hose) that fits through a hole in the floor of the compartment & drains into the area behind the radiator in the engine compartment. Then if for any reason the valve opens, all the hot water just sprays on to the ground. Looks like it was plumbed this way at the factory. Yours must be a one of a kind maybe? Sounds like you have a good solution now though. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Bob Lawrence wrote: > Hey group, > Had my popoff valve popoff last weekend. > Thing is it's set to popoff at 210 degrees. > Wasn't sure if the valve was bad or the thermostats. > Changed them both out. The valve was harder as door is small in closet. > Weird thing is the valve doesn't have anyplace to drain except in the > compartment it is located. Noticed water running down the engine. > On my PT36 the water fill and electric are in a compartment all their > own. > I drilled a hole in the compartment upper area and then with an adapter > to the new valve (old one was the problem), ran a hose that I cut off > and put a barbed fitting on and screwed it to the opening I had cut out. > Now, if it ever pops off again, at least the water will drain outside > instead of in the compartment. Probably never happen again... > Might want to take a look at yours to see where it would drain if it > pops off. > Bob Lawrence > 84 PT36 > Tacoma, Wa. > > [Non-text portions of this message have been removed] |
08-14-2007, 13:25
I wonder why mine wasn't fitted like yours?
Bob --- In WanderlodgeForum@yahoogroups.com, Terry Neal > > Hi Bob, > > On my PT40, the popoff valve for the water heater is fitted with an > adapter that is attached to a drain hose (think it's heater hose) that > fits through a hole in the floor of the compartment & drains into the > area behind the radiator in the engine compartment. Then if for any > reason the valve opens, all the hot water just sprays on to the ground. > Looks like it was plumbed this way at the factory. Yours must be a one > of a kind maybe? Sounds like you have a good solution now though. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > > > Bob Lawrence wrote: > > > Hey group, > > Had my popoff valve popoff last weekend. > > Thing is it's set to popoff at 210 degrees. > > Wasn't sure if the valve was bad or the thermostats. > > Changed them both out. The valve was harder as door is small in closet. > > Weird thing is the valve doesn't have anyplace to drain except in the > > compartment it is located. Noticed water running down the engine. > > On my PT36 the water fill and electric are in a compartment all their > > own. > > I drilled a hole in the compartment upper area and then with an adapter > > to the new valve (old one was the problem), ran a hose that I cut off > > and put a barbed fitting on and screwed it to the opening I had cut out. > > Now, if it ever pops off again, at least the water will drain outside > > instead of in the compartment. Probably never happen again... > > Might want to take a look at yours to see where it would drain if it > > pops off. > > Bob Lawrence > > 84 PT36 > > Tacoma, Wa. > > > > > > > > [Non-text portions of this message have been removed] > |
08-15-2007, 07:48
Hello Bob,
I suppose it is the old "build each one different" philosophy. We see this quite often based on feedback & info from the various forums. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Bob Lawrence wrote: > I wonder why mine wasn't fitted like yours? > Bob > > --- In WanderlodgeForum@yahoogroups.com > > > > > Hi Bob, > > > > On my PT40, the popoff valve for the water heater is fitted with an > > adapter that is attached to a drain hose (think it's heater hose) > that > > fits through a hole in the floor of the compartment & drains into > the > > area behind the radiator in the engine compartment. Then if for > any > > reason the valve opens, all the hot water just sprays on to the > ground. > > Looks like it was plumbed this way at the factory. Yours must be a > one > > of a kind maybe? Sounds like you have a good solution now though. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > > > Bob Lawrence wrote: > > > > > Hey group, > > > Had my popoff valve popoff last weekend. > > > Thing is it's set to popoff at 210 degrees. > > > Wasn't sure if the valve was bad or the thermostats. > > > Changed them both out. The valve was harder as door is small in > closet. > > > Weird thing is the valve doesn't have anyplace to drain except in > the > > > compartment it is located. Noticed water running down the engine. > > > On my PT36 the water fill and electric are in a compartment all > their > > > own. > > > I drilled a hole in the compartment upper area and then with an > adapter > > > to the new valve (old one was the problem), ran a hose that I cut > off > > > and put a barbed fitting on and screwed it to the opening I had > cut out. > > > Now, if it ever pops off again, at least the water will drain > outside > > > instead of in the compartment. Probably never happen again... > > > Might want to take a look at yours to see where it would drain if > it > > > pops off. > > > Bob Lawrence > > > 84 PT36 > > > Tacoma, Wa. > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] |
08-15-2007, 14:28
That's ok...with this group we can fix any problem or know where it
can be fixed...I know I have learned a lot. Bob > Hello Bob, > > I suppose it is the old "build each one different" philosophy. We see > this quite often based on feedback & info from the various forums. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > > > Bob Lawrence wrote: > > > I wonder why mine wasn't fitted like yours? > > Bob > > > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > > > Hi Bob, > > > > > > On my PT40, the popoff valve for the water heater is fitted with an > > > adapter that is attached to a drain hose (think it's heater hose) > > that > > > fits through a hole in the floor of the compartment & drains into > > the > > > area behind the radiator in the engine compartment. Then if for > > any > > > reason the valve opens, all the hot water just sprays on to the > > ground. > > > Looks like it was plumbed this way at the factory. Yours must be a > > one > > > of a kind maybe? Sounds like you have a good solution now though. > > > > > > Terry Neal > > > Bozeman, MT > > > 82PT40 6V92TA > > > 74FC34 6V53T > > > > > > > > > > > > Bob Lawrence wrote: > > > > > > > Hey group, > > > > Had my popoff valve popoff last weekend. > > > > Thing is it's set to popoff at 210 degrees. > > > > Wasn't sure if the valve was bad or the thermostats. > > > > Changed them both out. The valve was harder as door is small in > > closet. > > > > Weird thing is the valve doesn't have anyplace to drain except in > > the > > > > compartment it is located. Noticed water running down the engine. > > > > On my PT36 the water fill and electric are in a compartment all > > their > > > > own. > > > > I drilled a hole in the compartment upper area and then with an > > adapter > > > > to the new valve (old one was the problem), ran a hose that I cut > > off > > > > and put a barbed fitting on and screwed it to the opening I had > > cut out. > > > > Now, if it ever pops off again, at least the water will drain > > outside > > > > instead of in the compartment. Probably never happen again... > > > > Might want to take a look at yours to see where it would drain if > > it > > > > pops off. > > > > Bob Lawrence > > > > 84 PT36 > > > > Tacoma, Wa. > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > [Non-text portions of this message have been removed] > |
