Hot water heater popoff valve
08-13-2007, 06:49
Hey group,
Had my popoff valve popoff last weekend.
Thing is it's set to popoff at 210 degrees.
Wasn't sure if the valve was bad or the thermostats.
Changed them both out. The valve was harder as door is small in closet.
Weird thing is the valve doesn't have anyplace to drain except in the
compartment it is located. Noticed water running down the engine.
On my PT36 the water fill and electric are in a compartment all their
own.
I drilled a hole in the compartment upper area and then with an adapter
to the new valve (old one was the problem), ran a hose that I cut off
and put a barbed fitting on and screwed it to the opening I had cut out.
Now, if it ever pops off again, at least the water will drain outside
instead of in the compartment. Probably never happen again...
Might want to take a look at yours to see where it would drain if it
pops off.
Bob Lawrence
84 PT36
Tacoma, Wa.
08-13-2007, 13:37
Hi Bob,
On my PT40, the popoff valve for the water heater is fitted with an
adapter that is attached to a drain hose (think it's heater hose) that
fits through a hole in the floor of the compartment & drains into the
area behind the radiator in the engine compartment. Then if for any
reason the valve opens, all the hot water just sprays on to the ground.
Looks like it was plumbed this way at the factory. Yours must be a one
of a kind maybe? Sounds like you have a good solution now though.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
Bob Lawrence wrote:
> Hey group,
> own.
> pops off.
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
08-14-2007, 13:25
I wonder why mine wasn't fitted like yours?
Bob
--- In WanderlodgeForum@yahoogroups.com, Terry Neal wrote:
> Hi Bob,
that
any
ground.
one
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> Bob Lawrence wrote:
> > Hey group,
closet.
their
> > own.
adapter
off
cut out.
outside
it
> > pops off.
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
08-15-2007, 07:48
Hello Bob,
I suppose it is the old "build each one different" philosophy. We see
this quite often based on feedback & info from the various forums.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
> Bob
> , Terry Neal wrote:
> > Hi Bob,
> that
> the
> any
> ground.
> one
> > Terry Neal
> > Bozeman, MT
> > 82PT40 6V92TA
> > 74FC34 6V53T
> > Bob Lawrence wrote:
> > > Hey group,
> closet.
> the
> their
> > > own.
> adapter
> off
> cut out.
> outside
> it
> > > pops off.
> > > Bob Lawrence
> > > 84 PT36
> > > Tacoma, Wa.
08-15-2007, 14:28
That's ok...with this group we can fix any problem or know where it
can be fixed...I know I have learned a lot.
Bob
> Hello Bob,
see
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> > Bob
> > , Terry Neal
> > > Hi Bob,
with an
hose)
> > that
into
> > the
> > any
> > ground.
be a
> > one
though.
> > > Terry Neal
> > > Bozeman, MT
> > > 82PT40 6V92TA
> > > 74FC34 6V53T
> > > Bob Lawrence wrote:
> > > > Hey group,
in
> > closet.
except in
> > the
engine.
all
> > their
> > > > own.
an
> > adapter
cut
> > off
had
> > cut out.
> > outside
drain if
> > it
> > > > pops off.
> > > > Bob Lawrence
> > > > 84 PT36
> > > > Tacoma, Wa.
