Wheel tourqe
08-16-2007, 02:33
Wheel tourqe
Does anyone know the proper tourqe for my alluminum alcoa wheels? jim
sears 77FC. |
08-16-2007, 09:48
Wheel tourqe
From: jimbojcs To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 16, 2007 9:33 AM Subject: [WanderlodgeForum] Wheel tourqe 450# Jim Bob Loomas 1985 PT 36 Does anyone know the proper tourqe for my alluminum alcoa wheels? jim sears 77FC. [Non-text portions of this message have been removed] |
08-16-2007, 10:18
Wheel tourqe
Agree on the 450 pounds of torque, quoted dry, no lube.
Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "bloomas" > > > ----- Original Message ----- > From: jimbojcs > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 16, 2007 9:33 AM > Subject: [WanderlodgeForum] Wheel tourqe > 450# Jim > Bob Loomas 1985 PT 36 > > > Does anyone know the proper tourqe for my alluminum alcoa wheels? jim > sears 77FC. > > > > > > [Non-text portions of this message have been removed] > |
08-17-2007, 04:34
Wheel tourqe
Does anyone know if the newer wheel lug nuts with the flat wheel srface loosen
like the older lug nuts? Do they require the same amount of attention on the road? Dan Sunderland 05 450Lxi San Marcos, CA --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Agree on the 450 pounds of torque, quoted dry, no lube. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "bloomas" > > > > > > ----- Original Message ----- > > From: jimbojcs > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, August 16, 2007 9:33 AM > > Subject: [WanderlodgeForum] Wheel tourqe > > 450# Jim > > Bob Loomas 1985 PT 36 > > > > > > Does anyone know the proper tourqe for my alluminum alcoa wheels? jim > > sears 77FC. > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
08-17-2007, 04:57
Wheel tourqe
Noticed you have an 05 LXI and have not seen anyone else post with that
model. I am looking at one. Just wanted to know how you like it and any particular problems? Are there any changes to the coach you would like. Jerry Smith -------Original Message------- From: WanderlodgeForum@yahoogroups.com Date: 08/17/07 12:35:46 To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Wheel tourqe Does anyone know if the newer wheel lug nuts with the flat wheel srface loosen like the older lug nuts? Do they require the same amount of attention on the road? Dan Sunderland 05 450Lxi San Marcos, CA --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Agree on the 450 pounds of torque, quoted dry, no lube. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "bloomas" > > > > > > ----- Original Message ----- > > From: jimbojcs > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, August 16, 2007 9:33 AM > > Subject: [WanderlodgeForum] Wheel tourqe > > 450# Jim > > Bob Loomas 1985 PT 36 > > > > > > Does anyone know the proper tourqe for my alluminum alcoa wheels? jim > > sears 77FC. > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
08-17-2007, 07:58
Wheel tourqe
make sure your are not mixing hub piloted and stud piloted wheels
both types of wheels require special attention to torquing the lug nuts Stephen 7735fc Dupree valves Wanderlodge Vintage Parts --- In WanderlodgeForum@yahoogroups.com, "Dan and Cindy Sunderland" <86bluebird@...> wrote: > > Does anyone know if the newer wheel lug nuts with the flat wheel srface loosen like the > older lug nuts? Do they require the same amount of attention on the road? > > Dan Sunderland > 05 450Lxi > San Marcos, CA > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Agree on the 450 pounds of torque, quoted dry, no lube. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bloomas" > > > > > > > > > ----- Original Message ----- > > > From: jimbojcs > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, August 16, 2007 9:33 AM > > > Subject: [WanderlodgeForum] Wheel tourqe > > > 450# Jim > > > Bob Loomas 1985 PT 36 > > > > > > > > > Does anyone know the proper tourqe for my alluminum alcoa wheels? jim > > > sears 77FC. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
08-17-2007, 08:11
Wheel tourqe
FYI, the Alcoa web site has a pretty good review of the different
types of wheels and nuts and the appropriate torque settings for each of them. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX - soggy and very humid once again..... where last night's trek home from the office was quite interesting - not! -- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > make sure your are not mixing hub piloted and stud piloted wheels > both types of wheels require special attention to torquing the lug nuts > Stephen 7735fc > Dupree valves > Wanderlodge Vintage Parts > > --- In WanderlodgeForum@yahoogroups.com, "Dan and Cindy Sunderland" > <86bluebird@> wrote: > > > > Does anyone know if the newer wheel lug nuts with the flat wheel > srface loosen like the > > older lug nuts? Do they require the same amount of attention on the > road? > > > > Dan Sunderland > > 05 450Lxi > > San Marcos, CA > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > > > Agree on the 450 pounds of torque, quoted dry, no lube. > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bloomas" > > > > > > > > > > > > ----- Original Message ----- > > > > From: jimbojcs > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, August 16, 2007 9:33 AM > > > > Subject: [WanderlodgeForum] Wheel tourqe > > > > 450# Jim > > > > Bob Loomas 1985 PT 36 > > > > > > > > > > > > Does anyone know the proper tourqe for my alluminum alcoa > wheels? jim > > > > sears 77FC. > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > |
08-17-2007, 16:57
Wheel tourqe
Hi Jerry
Yes we purchased it in April. We are still trying to work the kinks out of it. Love the bird. Dan Sunderland 05 450Lxi San Marcos, CA --- In WanderlodgeForum@yahoogroups.com, "JERRY SMITH" <medpro@...> wrote: > > Noticed you have an 05 LXI and have not seen anyone else post with that > model. I am looking at one. Just wanted to know how you like it and any > particular problems? Are there any changes to the coach you would like. > > Jerry Smith > > -------Original Message------- > > From: WanderlodgeForum@yahoogroups.com > Date: 08/17/07 12:35:46 > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Wheel tourqe > > Does anyone know if the newer wheel lug nuts with the flat wheel srface > loosen like the > older lug nuts? Do they require the same amount of attention on the road? > > Dan Sunderland > 05 450Lxi > San Marcos, CA > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Agree on the 450 pounds of torque, quoted dry, no lube. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bloomas" > > > > > > > > > ----- Original Message ----- > > > From: jimbojcs > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, August 16, 2007 9:33 AM > > > Subject: [WanderlodgeForum] Wheel tourqe > > > 450# Jim > > > Bob Loomas 1985 PT 36 > > > > > > > > > Does anyone know the proper tourqe for my alluminum alcoa wheels? jim > > > sears 77FC. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > [Non-text portions of this message have been removed] > |
08-18-2007, 00:58
Wheel tourqe
O.K......450 pounds tourqe. Guess i need a bigger tourqe wrench. thanks
guys. --------------------------------- Need a vacation? Get great deals to amazing places on Yahoo! Travel. [Non-text portions of this message have been removed] |
08-18-2007, 05:20
Wheel tourqe
Thanks for the reply. I assume just the usual minor problems you have with
any coach, nothing major. Jerry Smith -------Original Message------- From: WanderlodgeForum@yahoogroups.com Date: 08/18/07 00:58:12 To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Wheel tourqe Hi Jerry Yes we purchased it in April. We are still trying to work the kinks out of it. Love the bird. Dan Sunderland 05 450Lxi San Marcos, CA --- In WanderlodgeForum@yahoogroups.com, "JERRY SMITH" <medpro@...> wrote: > > Noticed you have an 05 LXI and have not seen anyone else post with that > model. I am looking at one. Just wanted to know how you like it and any > particular problems? Are there any changes to the coach you would like. > > Jerry Smith > > -------Original Message------- > > From: WanderlodgeForum@yahoogroups.com > Date: 08/17/07 12:35:46 > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Wheel tourqe > > Does anyone know if the newer wheel lug nuts with the flat wheel srface > loosen like the > older lug nuts? Do they require the same amount of attention on the road? > > Dan Sunderland > 05 450Lxi > San Marcos, CA > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Agree on the 450 pounds of torque, quoted dry, no lube. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bloomas" > > > > > > > > > ----- Original Message ----- > > > From: jimbojcs > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, August 16, 2007 9:33 AM > > > Subject: [WanderlodgeForum] Wheel tourqe > > > 450# Jim > > > Bob Loomas 1985 PT 36 > > > > > > > > > Does anyone know the proper tourqe for my alluminum alcoa wheels? jim > > > sears 77FC. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
