Interior Panels
08-21-2007, 06:48
Interior Panels
In the on going efforts to spruce up the ole bus I have turned my
attention to the interior panels. I am speaking of the off-white vinyl paneling that is common to all of the older BB's found on the sides and ceilings of the coaches. Any pointers as to how to clean up or renew them. Mine are not real bad but I am wondering how to make them look as nice as possible. Anyone ever try to paint them? If so how did that work out and what did you use? John Heckman Central Pa 1973 FC "The Big Napper" |
08-21-2007, 07:29
Interior Panels
John,
A good vinyl cleaner will work. Then a good vinyl dressing. Worked for me. On 8/21/07, bubblerboy64 > > In the on going efforts to spruce up the ole bus I have turned my > attention to the interior panels. I am speaking of the off-white > vinyl paneling that is common to all of the older BB's found on the > sides and ceilings of the coaches. Any pointers as to how to clean > up or renew them. Mine are not real bad but I am wondering how to > make them look as nice as possible. Anyone ever try to paint them? > If so how did that work out and what did you use? > > John Heckman > Central Pa > 1973 FC > "The Big Napper" > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
08-21-2007, 07:59
Interior Panels
Curt, I've tried stuff like 409 and Fantastic and although they have
certainly helped I would like to do a little better then what I have been able to accomplish with those products. Have any specific recommendations? I guess too the issue is how hard to scrub before you are doing damage. My coach is 35 years old and for its age its in rather nice shape but I would like to get this interior as clean and fresh looking as I can. John > > John, > > A good vinyl cleaner will work. Then a good vinyl dressing. Worked for me. > > On 8/21/07, bubblerboy64 > > > > In the on going efforts to spruce up the ole bus I have turned my > > attention to the interior panels. I am speaking of the off-white > > vinyl paneling that is common to all of the older BB's found on the > > sides and ceilings of the coaches. Any pointers as to how to clean > > up or renew them. Mine are not real bad but I am wondering how to > > make them look as nice as possible. Anyone ever try to paint them? > > If so how did that work out and what did you use? > > > > John Heckman > > Central Pa > > 1973 FC > > "The Big Napper" > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
08-21-2007, 08:14
Interior Panels
John,
I buy products from an automotive detail supply store. MARK V is the company that makes the supplies. Using the MARK V vinyl cleaner and a soft scrub brush I was able to clean the vinyl in our previous 'Bird, a 1974 FC and did the same process to our 87PT. I'd spray on the cleaner, scrub with brush, and terry towels to wipe the cleaner/dirt off. Then I went back over the vinyl washing with clear water only. Then applied the MARK V vinyl dressing. On 8/21/07, bubblerboy64 > > Curt, I've tried stuff like 409 and Fantastic and although they have > certainly helped I would like to do a little better then what I have > been able to accomplish with those products. Have any specific > recommendations? I guess too the issue is how hard to scrub before > you are doing damage. My coach is 35 years old and for its age its in > rather nice shape but I would like to get this interior as clean and > fresh looking as I can. John > > > > John, > > > > A good vinyl cleaner will work. Then a good vinyl dressing. Worked > for me. > > > > On 8/21/07, bubblerboy64 > > > > > > In the on going efforts to spruce up the ole bus I have turned > my > > > attention to the interior panels. I am speaking of the off-white > > > vinyl paneling that is common to all of the older BB's found on > the > > > sides and ceilings of the coaches. Any pointers as to how to clean > > > up or renew them. Mine are not real bad but I am wondering how to > > > make them look as nice as possible. Anyone ever try to paint them? > > > If so how did that work out and what did you use? > > > > > > John Heckman > > > Central Pa > > > 1973 FC > > > "The Big Napper" > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
08-21-2007, 12:12
Interior Panels
From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 21, 2007 1:48 PM Subject: [WanderlodgeForum] Interior Panels On the interior walls you can remove the panels and use carpet. Bob Loomas 1985 PT 36 with carpet interior walls In the on going efforts to spruce up the ole bus I have turned my attention to the interior panels. I am speaking of the off-white vinyl paneling that is common to all of the older BB's found on the sides and ceilings of the coaches. Any pointers as to how to clean up or renew them. Mine are not real bad but I am wondering how to make them look as nice as possible. Anyone ever try to paint them? If so how did that work out and what did you use? John Heckman Central Pa 1973 FC "The Big Napper" [Non-text portions of this message have been removed] |
08-21-2007, 12:37
Interior Panels
You can paint them using Dupli-color vinyl and fabric spray available at any
good parts store. They will look brand new when you are finished. Numerous colors are available. Leroy Eckert 1990 WB-40"Smoke N Mirrors' Niceville, FL Royale Conversion ----- Original Message ----- From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 21, 2007 2:59 PM Subject: [WanderlodgeForum] Re: Interior Panels Curt, I've tried stuff like 409 and Fantastic and although they have certainly helped I would like to do a little better then what I have been able to accomplish with those products. Have any specific recommendations? I guess too the issue is how hard to scrub before you are doing damage. My coach is 35 years old and for its age its in rather nice shape but I would like to get this interior as clean and fresh looking as I can. John > > John, > > A good vinyl cleaner will work. Then a good vinyl dressing. Worked for me. > > On 8/21/07, bubblerboy64 > > > > In the on going efforts to spruce up the ole bus I have turned my > > attention to the interior panels. I am speaking of the off-white > > vinyl paneling that is common to all of the older BB's found on the > > sides and ceilings of the coaches. Any pointers as to how to clean > > up or renew them. Mine are not real bad but I am wondering how to > > make them look as nice as possible. Anyone ever try to paint them? > > If so how did that work out and what did you use? > > > > John Heckman > > Central Pa > > 1973 FC > > "The Big Napper" > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
08-21-2007, 12:46
Interior Panels
I can't seem to remember everything at once. Getting old. Be aware that 409 can
scratch certain paints and corian. I used it to clean bugs from the leading edge of my aircraft wings years ago. I have never purchased another bottle. Leroy Eckert 1990 WB-40"Smoke N Mirrors' Niceville, FL Royale Conversion ----- Original Message ----- From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 21, 2007 2:59 PM Subject: [WanderlodgeForum] Re: Interior Panels Curt, I've tried stuff like 409 and Fantastic and although they have certainly helped I would like to do a little better then what I have been able to accomplish with those products. Have any specific recommendations? I guess too the issue is how hard to scrub before you are doing damage. My coach is 35 years old and for its age its in rather nice shape but I would like to get this interior as clean and fresh looking as I can. John > > John, > > A good vinyl cleaner will work. Then a good vinyl dressing. Worked for me. > > On 8/21/07, bubblerboy64 > > > > In the on going efforts to spruce up the ole bus I have turned my > > attention to the interior panels. I am speaking of the off-white > > vinyl paneling that is common to all of the older BB's found on the > > sides and ceilings of the coaches. Any pointers as to how to clean > > up or renew them. Mine are not real bad but I am wondering how to > > make them look as nice as possible. Anyone ever try to paint them? > > If so how did that work out and what did you use? > > > > John Heckman > > Central Pa > > 1973 FC > > "The Big Napper" > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
08-21-2007, 12:59
Interior Panels
Clean them good with a vinyl cleaner, then use 303 Protectant on them.
Best stuff around that I have found. We use it on hot tub covers. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Leroy Eckert wrote: > I can't seem to remember everything at once. Getting old. Be aware > that 409 can scratch certain paints and corian. I used it to clean > bugs from the leading edge of my aircraft wings years ago. I have > never purchased another bottle. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors' > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: bubblerboy64 > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, August 21, 2007 2:59 PM > Subject: [WanderlodgeForum] Re: Interior Panels > > Curt, I've tried stuff like 409 and Fantastic and although they have > certainly helped I would like to do a little better then what I have > been able to accomplish with those products. Have any specific > recommendations? I guess too the issue is how hard to scrub before > you are doing damage. My coach is 35 years old and for its age its in > rather nice shape but I would like to get this interior as clean and > fresh looking as I can. John > > > > John, > > > > A good vinyl cleaner will work. Then a good vinyl dressing. Worked > for me. > > > > On 8/21/07, bubblerboy64 > > > > > > In the on going efforts to spruce up the ole bus I have turned > my > > > attention to the interior panels. I am speaking of the off-white > > > vinyl paneling that is common to all of the older BB's found on > the > > > sides and ceilings of the coaches. Any pointers as to how to clean > > > up or renew them. Mine are not real bad but I am wondering how to > > > make them look as nice as possible. Anyone ever try to paint them? > > > If so how did that work out and what did you use? > > > > > > John Heckman > > > Central Pa > > > 1973 FC > > > "The Big Napper" > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
08-21-2007, 13:37
Interior Panels
If you can find it we use Benalex to clean vinyl and other surfaces in
the shop Stephen 77fc35 Dupree Valves Wanderlodge Vintage Parts --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Curt, I've tried stuff like 409 and Fantastic and although they have > certainly helped I would like to do a little better then what I have > been able to accomplish with those products. Have any specific > recommendations? I guess too the issue is how hard to scrub before > you are doing damage. My coach is 35 years old and for its age its in > rather nice shape but I would like to get this interior as clean and > fresh looking as I can. John > > > > John, > > > > A good vinyl cleaner will work. Then a good vinyl dressing. Worked > for me. > > > > On 8/21/07, bubblerboy64 > > > > > > In the on going efforts to spruce up the ole bus I have turned > my > > > attention to the interior panels. I am speaking of the off-white > > > vinyl paneling that is common to all of the older BB's found on > the > > > sides and ceilings of the coaches. Any pointers as to how to clean > > > up or renew them. Mine are not real bad but I am wondering how to > > > make them look as nice as possible. Anyone ever try to paint them? > > > If so how did that work out and what did you use? > > > > > > John Heckman > > > Central Pa > > > 1973 FC > > > "The Big Napper" > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > |
08-22-2007, 06:51
Interior Panels
In order to paint them, you would first have to clean the walls and ceiling. We
did that and liked the results so well we didn't need to paint. We used a product called "Magic Eraser" on the difficult areas. Worked well. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 21, 2007 11:48 AM Subject: [WanderlodgeForum] Interior Panels In the on going efforts to spruce up the ole bus I have turned my attention to the interior panels. I am speaking of the off-white vinyl paneling that is common to all of the older BB's found on the sides and ceilings of the coaches. Any pointers as to how to clean up or renew them. Mine are not real bad but I am wondering how to make them look as nice as possible. Anyone ever try to paint them? If so how did that work out and what did you use? John Heckman Central Pa 1973 FC "The Big Napper" [Non-text portions of this message have been removed] |
