Got her Off
08-25-2007, 17:51
Got her Off
I managed to get the steering wheel off. Jims suggestions plus maybe
some help from the penitrating oil. Now, can you tell me what I need to know to order a replacement? This wheel is about 21 inches in diameter and I'd like to drop back an inch or two other then that I have no real strong preference but I'll need to know the specifics which respect internal dementions etc. Again the help is greatly appreciated. John Heckman central Pa 1973 FC |
08-25-2007, 22:48
Got her Off
http://www.vipwheels.com
you have to measure the diameter and number of splines on the shaft before you call IF it is the same as the later model coaches the center is a BB1 you just pick out the steering wheel you want and they will add the center Stephen 77fc35 owner of Dupree Valves and Wanderlodge Vintage Parts --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > I managed to get the steering wheel off. Jims suggestions plus maybe > some help from the penitrating oil. Now, can you tell me what I need > to know to order a replacement? This wheel is about 21 inches in > diameter and I'd like to drop back an inch or two other then that I > have no real strong preference but I'll need to know the specifics > which respect internal dementions etc. Again the help is greatly > appreciated. > John Heckman > central Pa > 1973 FC > |
08-25-2007, 23:45
Got her Off
Stephen, Thanks for the info. The diameter appears to be 7/8 inch
as close as I can measure with a ruler and there are 36 teeth on the spline gear. That sound like a BB1? John Heckman Central Pa 1973 FC > > http://www.vipwheels.com > you have to measure the diameter and number of splines on the shaft > before you call > IF it is the same as the later model coaches the center is a BB1 > you just pick out the steering wheel you want and they will add the > center > > Stephen 77fc35 > owner of Dupree Valves and Wanderlodge Vintage Parts > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > I managed to get the steering wheel off. Jims suggestions plus maybe > > some help from the penitrating oil. Now, can you tell me what I need > > to know to order a replacement? This wheel is about 21 inches in > > diameter and I'd like to drop back an inch or two other then that I > > have no real strong preference but I'll need to know the specifics > > which respect internal dementions etc. Again the help is greatly > > appreciated. > > John Heckman > > central Pa > > 1973 FC > > > |
08-26-2007, 01:09
Got her Off
Yup, Stephen's right on the money for this commonly asked question.
The information on VIP Wheels is also in the Parts Database and in the Parts Links. Just FYI. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > http://www.vipwheels.com > you have to measure the diameter and number of splines on the shaft > before you call > IF it is the same as the later model coaches the center is a BB1 > you just pick out the steering wheel you want and they will add the > center > > Stephen 77fc35 > owner of Dupree Valves and Wanderlodge Vintage Parts > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > I managed to get the steering wheel off. Jims suggestions plus maybe > > some help from the penitrating oil. Now, can you tell me what I need > > to know to order a replacement? This wheel is about 21 inches in > > diameter and I'd like to drop back an inch or two other then that I > > have no real strong preference but I'll need to know the specifics > > which respect internal dementions etc. Again the help is greatly > > appreciated. > > John Heckman > > central Pa > > 1973 FC > > > |
08-26-2007, 01:24
Got her Off
Ask for a factory 2nd. I have yet to find the blemish on mine that
caused it to be a 2nd. Fine steering wheels. Gary Miller 83 FC 33 - For Sale Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Yup, Stephen's right on the money for this commonly asked question. > The information on VIP Wheels is also in the Parts Database and in the > Parts Links. Just FYI. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > http://www.vipwheels.com > > you have to measure the diameter and number of splines on the shaft > > before you call > > IF it is the same as the later model coaches the center is a BB1 > > you just pick out the steering wheel you want and they will add the > > center > > > > Stephen 77fc35 > > owner of Dupree Valves and Wanderlodge Vintage Parts > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > I managed to get the steering wheel off. Jims suggestions plus maybe > > > some help from the penitrating oil. Now, can you tell me what I need > > > to know to order a replacement? This wheel is about 21 inches in > > > diameter and I'd like to drop back an inch or two other then that I > > > have no real strong preference but I'll need to know the specifics > > > which respect internal dementions etc. Again the help is greatly > > > appreciated. > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > |
08-26-2007, 02:00
Got her Off
Thanks very much, I plan to get on it Monday morning first thing and
get one ordered. John Heckman Shippensburg Pa 1973 FC > > Ask for a factory 2nd. I have yet to find the blemish on mine that > caused it to be a 2nd. > > Fine steering wheels. > > Gary Miller > 83 FC 33 - For Sale > Milwaukee area > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > Yup, Stephen's right on the money for this commonly asked question. > > The information on VIP Wheels is also in the Parts Database and in > the > > Parts Links. Just FYI. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > > > > http://www.vipwheels.com > > > you have to measure the diameter and number of splines on the > shaft > > > before you call > > > IF it is the same as the later model coaches the center is a BB1 > > > you just pick out the steering wheel you want and they will add > the > > > center > > > > > > Stephen 77fc35 > > > owner of Dupree Valves and Wanderlodge Vintage Parts > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > > wrote: > > > > > > > > I managed to get the steering wheel off. Jims suggestions plus > maybe > > > > some help from the penitrating oil. Now, can you tell me what > I need > > > > to know to order a replacement? This wheel is about 21 inches > in > > > > diameter and I'd like to drop back an inch or two other then > that I > > > > have no real strong preference but I'll need to know the > specifics > > > > which respect internal dementions etc. Again the help is > greatly > > > > appreciated. > > > > John Heckman > > > > central Pa > > > > 1973 FC > > > > > > > > > > |
