Overhead load center questions
08-26-2007, 07:21
I'm trying to get my rear camera working. It worked when I picked up
my coach in April. In the overhead load center (above the driver) is a row of circuit breakers whose power is provided by an adjacent solenoid. This solenoid is energised by turning on the ignition key. These breaker are for the dash A/C controls, rear camera trigger, and various indicator lights. The solenoid is energised by the key. However, turning the key off does not release it. It doesn't realeas untill the master power switch is turned off. Are these supposed to be self latching solenoids? I wouldn't think so. Otherwise, too many things stay enabled even though the key is off. By the way, I did find the camera problem. A broken wire in the rear overhead. Have yet to solder it - on my way to do it now. Art Weatherly Riverside Ca '85 PT36 |
08-26-2007, 11:08
many solenoid need major amps/volts to open but less to stay open.
maybe your ign switch is going bad and the only time it pass no power is when the input power to the ign switch is shut down with the master power. all other times it is bleeding enough to maintain the solenoid open but not enough to open a closed solenoid???????????? OR,,, bad solenoid. I would check the solenoid signal post (where wire from ign switch attach to sol.) with a good multimeter with the ign switch off. then, remove the ign wire at the solenoid and see if there is power ;at the solenoid signal post or the ;end of the removed wire from the ign switch. if power at the signal post it may be the solenoid is internally screwed?????????? 'Self latching solenoid'?? is there such a thing??? Greg 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > I'm trying to get my rear camera working. It worked when I picked up > my coach in April. In the overhead load center (above the driver) > is a row of circuit breakers whose power is provided by an adjacent > solenoid. This solenoid is energised by turning on the ignition key. > These breaker are for the dash A/C controls, rear camera trigger, and > various indicator lights. The solenoid is energised by the key. > However, turning the key off does not release it. It doesn't realeas > untill the master power switch is turned off. Are these supposed to > be self latching solenoids? I wouldn't think so. Otherwise, too many > things stay enabled even though the key is off. > > By the way, I did find the camera problem. A broken wire in the rear > overhead. Have yet to solder it - on my way to do it now. > > Art Weatherly > Riverside Ca > '85 PT36 > |
08-26-2007, 12:28
Art,
From the sound of it, someone has wired something that is feeding back power from the solenoid output to the solenoid coil. Once energized it will not release. I hate to say it, but 'happy hunting". You will need to determine what new device or new connection is connected to the line from the ignition switch to the relay coil. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > many solenoid need major amps/volts to open but less to stay open. > maybe your ign switch is going bad and the only time it pass no power > is when the input power to the ign switch is shut down with the > master power. all other times it is bleeding enough to maintain the > solenoid open but not enough to open a closed solenoid???????????? > > OR,,, bad solenoid. I would check the solenoid signal post (where > wire from ign switch attach to sol.) with a good multimeter with > the ign switch off. then, remove the ign wire at the solenoid and see > if there is power ;at the solenoid signal post or the ;end of the > removed wire from the ign switch. if power at the signal post it may > be the solenoid is internally screwed?????????? > > 'Self latching solenoid'?? is there such a thing??? > Greg > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "amweath" > wrote: > > > > I'm trying to get my rear camera working. It worked when I picked up > > my coach in April. In the overhead load center (above the driver) > > is a row of circuit breakers whose power is provided by an adjacent > > solenoid. This solenoid is energised by turning on the ignition key. > > These breaker are for the dash A/C controls, rear camera trigger, > and > > various indicator lights. The solenoid is energised by the key. > > However, turning the key off does not release it. It doesn't realeas > > untill the master power switch is turned off. Are these supposed to > > be self latching solenoids? I wouldn't think so. Otherwise, too many > > things stay enabled even though the key is off. > > > > By the way, I did find the camera problem. A broken wire in the > rear > > overhead. Have yet to solder it - on my way to do it now. > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > |
08-27-2007, 02:53
Thank you all for your responses. What I heard was the solenoid is
not supposed to stay up. Now I know what to look for. I've never heard of a self-latching solenoid either - self latching relays, yes. Art Weatherly Riverside Ca '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > many solenoid need major amps/volts to open but less to stay open. > maybe your ign switch is going bad and the only time it pass no power > is when the input power to the ign switch is shut down with the > master power. all other times it is bleeding enough to maintain the > solenoid open but not enough to open a closed solenoid???????????? > > OR,,, bad solenoid. I would check the solenoid signal post (where > wire from ign switch attach to sol.) with a good multimeter with > the ign switch off. then, remove the ign wire at the solenoid and see > if there is power ;at the solenoid signal post or the ;end of the > removed wire from the ign switch. if power at the signal post it may > be the solenoid is internally screwed?????????? > > 'Self latching solenoid'?? is there such a thing??? > Greg > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "amweath" > wrote: > > > > I'm trying to get my rear camera working. It worked when I picked up > > my coach in April. In the overhead load center (above the driver) > > is a row of circuit breakers whose power is provided by an adjacent > > solenoid. This solenoid is energised by turning on the ignition key. > > These breaker are for the dash A/C controls, rear camera trigger, > and > > various indicator lights. The solenoid is energised by the key. > > However, turning the key off does not release it. It doesn't realeas > > untill the master power switch is turned off. Are these supposed to > > be self latching solenoids? I wouldn't think so. Otherwise, too many > > things stay enabled even though the key is off. > > > > By the way, I did find the camera problem. A broken wire in the > rear > > overhead. Have yet to solder it - on my way to do it now. > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > |
