Water pump
02-12-2008, 16:16
Post: #31
Water pump
I've been out of town for a few day and probable missed some of this thread.
What I did is eliminate the OEM pressure regulator/check valve combo unit, installing only a check valve on the coach fill side, and using a 50psi pressure regulator on the outer end of the fill hose (should use one when hooked to shore water connection); this resolved all the tank fill issues that I have experienced. Yes, the sporlan valve may get plugged but so far only once in 3+ year. The problem was the OEM regulator was plugging up and stopping the water flow. I have pictures of the unit I built, maybe a write up. Email me if you need more.
On Feb 12, 2008 6:22 PM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
I got a phone call from a member looking to bypass the electric tank
fill and install a fresh water tank fill port independent of the
sole shore water hookup. MarkD 1988pt40 said his tank takes forever
to fillup like there is a restriction some place. Curt and others
posted about this issue also. Then I remember Macy post the
term "Engineer" and realized there must be more to it.
I notice that tankfills on sob's are not dripless threaded on. I
wonder if this design is to keep the fill water hose pressure from
splitting the fresh water tank??????
I also wonder if the slow fresh water tank fill common with the
Wonderlodges is a design limit???? to keep the overflow above the
design limit of the input???????
I can see that with the 110 psi one inch meter at my yard I could
split a tank if the overfill could not keep up with the 30 gpm!!!
This is a consideration with modifying the fill setup
GregoryO'Connor
94ptRomolandCa
--- In "WanderlodgeForum%40yahoogroups.com", "Macy Neshati"
> Thanks Gregory, I have engineering looking into the backflow valve
location
> you suggested in this post.
> Travel safely
> Macy
> Macy Neshati
> www. completecoach.com www.thelegacyreturns.com
www.bluebirdcoachworks.com
> email: macy@...
> Cell: 951 836 6525 Office: 951 684 9585 Fax: 951 684 2023
> 1863 Service Court
> Riverside, CA 92507
Curt Sprenger
Anaheim Hills, CA
02-12-2008, 16:45
Post: #32
Water pump
Leroy:
Actually the pump is pumping, just in a circle from the pump back to the tank.
Bill 84 FC 35 SB "$quanderlodge"
Terrace, B.C. Canada
----- Original Message ----
To:
WanderlodgeForum@yahoogroups.com
Sent: Sunday, February 10, 2008 12:51:15 PM
Subject: Re: [WanderlodgeForum] water pump
One other thing to make sure it is clear how mine operates. If after filling the tank, turning off the water and disconnecting and storing the water hose you forget to place the fill switch in the off position, the pump will run and not pump water. I did that once and thought I had a bad pump until I figured it out. It made me feel a little dumb in front of the wife. She needed to use the head on the road.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Donald Spithaler wrote:
Does any one know an
answer to this question. I have a part ordered
for my Shur-Flo water pump & while waiting for it I took the pump out
& tied the in & out side of the water lines of the pump together & I
am on city water right now. After I fill my water tank I put the
switch in the position that you get water at the facet's if the pump
is turned on or it is on city water. Question? Does the water pump
being turned on open & close the sporlan valve or what control's the
valve?
Don Spithaler
89 SP 36'
Butler, PA Zephyrhills FL
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Ask a question on any topic and get answers from real people. Go to Yahoo! Answers.
02-12-2008, 16:52
Post: #33
Water pump
Hey guys, none of us get this dialed in to perfection...memory is TOO short...BEEN THERE, DONE THAT...too may times. What you state is absolutely correct.
On Feb 12, 2008 8:45 PM, Wilhelmus Schreurs <"tulipvendor50@yahoo.ca"> wrote:
Leroy:
To:
"WanderlodgeForum@yahoogroups.com"
Leroy Eckert
Dahlonega, GA
Royale Conversion
valve?
Don Spithaler
89 SP 36'
Curt Sprenger
Anaheim Hills, CA
02-13-2008, 01:16
Post: #34
Water pump
I have never chased the plumbing down and do not have a schematic for that part of the water system.
Consensus is that the water goes in circles with the switch in the fill position and the pump switch on. In that case the water must be running through the sporlan valve and back toward the pressure regulator also which apparently has a check valve to prevent water from squirting out the side of the bus assuming the shore water is disconnected, because nothing pressurizes. Is this correct? If shore water is filling the tank and the pump is running the pump is fighting against incoming shore water???? As well there must be another check valve in the pump output line to prevent back flow through the pump while filling the tank with the pump switch off.?????
If so, no one has to be concerned with trashing a pump because it is always wet????? I have a Jabsco which can be run dry without any problems. Can a Surflo be run dry without issues?
Thanks in advance for the
info.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Leroy:
Leroy Eckert
Dahlonega, GA
Royale Conversion
Does any one know an answer to this question. I have a part
ordered
valve?
Don Spithaler
89 SP 36'
Curt Sprenger
Anaheim Hills, CA
Never miss a thing. Make Yahoo your homepage.
02-13-2008, 10:40
Post: #35
Water pump
Hey Curt,
I'd like to see this, myself.
-Ryan
'86 PT-40 8V92
02-13-2008, 11:39
Post: #36
Water pump
Ryan,
I sent 4 pictures and a short note to your email address.
On Feb 13, 2008 2:40 PM, Ryan Wright <"ryanpwright@gmail.com"> wrote:
Hey Curt,
-Ryan
'86 PT-40 8V92
Curt Sprenger
Anaheim Hills, CA
