VIP Steering Wheel Size
08-28-2007, 12:44
Ahhh. The old steering wheel size debate.
If your power steering goes out, and you're moving, my experience is that the adrenaline is high, and the steering wheel being a couple inches smaller in diameter doesn't matter much because slight changes aren't that hard to make. City driving will be out of the question in any case, regardless of steering wheel size. What is important is preventing the power steering failure in the first place (which is extremely rare, by the way). Have a good belt on it, have a good pump (no leaks), and you may want to install a vent in the reservoir since it should have one and likely doesn't if it's an FC in the '83 to '86 range (don't know about PT's). Fluid expands when it's hot and if there's no vent, it hurts the seals and oozes at the hose connections. Flat tire? Had those too. Wheel size is not important, they're very controllable if you don't panic and over-correct. Again, prevention is key, run good tires. This experience comes from helping Jeff buy old FC's and get them home for restoration. Eventially, we wised up and just replaced all the tires b4 heading home. Gary Miller 83 FC 33 - For Sale Milwaukee area |
08-28-2007, 13:31
I actually drove my FC without power steering on one trip...quite an
experience. I had the original white plastic steering wheen and was glad to have every inch of leverage it provided. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > > Ahhh. The old steering wheel size debate. > > If your power steering goes out, and you're moving, my experience is > that the adrenaline is high, and the steering wheel being a couple > inches smaller in diameter doesn't matter much because slight changes > aren't that hard to make. City driving will be out of the question > in any case, regardless of steering wheel size. > > What is important is preventing the power steering failure in the > first place (which is extremely rare, by the way). Have a good belt > on it, have a good pump (no leaks), and you may want to install a > vent in the reservoir since it should have one and likely doesn't if > it's an FC in the '83 to '86 range (don't know about PT's). Fluid > expands when it's hot and if there's no vent, it hurts the seals and > oozes at the hose connections. > > Flat tire? Had those too. Wheel size is not important, they're very > controllable if you don't panic and over-correct. Again, prevention > is key, run good tires. > > This experience comes from helping Jeff buy old FC's and get them > home for restoration. Eventially, we wised up and just replaced all > the tires b4 heading home. > > Gary Miller > 83 FC 33 - For Sale > Milwaukee area > |
08-28-2007, 13:45
Gary,
I agree on the power steering maintenance. As the old saying goes, 'an ounce of prevention is worth a pound of cure'. But I did have a PS failure on my Jeep Grand Cherokee on a hair-pin exit ramp once and it scared the cra# out of me. I have taken a lesson from that experience and tend to take exits much slower than I used to. The reality is, however, that I am trying to justify the expense vs the reward. The fnacy steering wheels are a bit pricey. Gardner 78FC33 (with a 'Big Wheel' ![]() --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > > Ahhh. The old steering wheel size debate. > > If your power steering goes out, and you're moving, my experience is > that the adrenaline is high, and the steering wheel being a couple > inches smaller in diameter doesn't matter much because slight changes > aren't that hard to make. City driving will be out of the question > in any case, regardless of steering wheel size. > > What is important is preventing the power steering failure in the > first place (which is extremely rare, by the way). Have a good belt > on it, have a good pump (no leaks), and you may want to install a > vent in the reservoir since it should have one and likely doesn't if > it's an FC in the '83 to '86 range (don't know about PT's). Fluid > expands when it's hot and if there's no vent, it hurts the seals and > oozes at the hose connections. > > Flat tire? Had those too. Wheel size is not important, they're very > controllable if you don't panic and over-correct. Again, prevention > is key, run good tires. > > This experience comes from helping Jeff buy old FC's and get them > home for restoration. Eventially, we wised up and just replaced all > the tires b4 heading home. > > Gary Miller > 83 FC 33 - For Sale > Milwaukee area > |
