Bulk Oil Tank on 2000 lxi
08-30-2007, 04:28
Time to change the oil and filters again. I'm wondering if the bulk
tank oil will do. I've always kept it full and in the past 4 yrs. have
only drawn 4 or 5 qts. from it. I'm wondering if I should use it up
for the change and then refill it with some fresh oil.
luckyron1 in sunny MN
08-30-2007, 05:03
For each oil change I first use up the oil in the bulk tank, then refill.
Curt Sprenger
Anaheim Hills, CA
08-30-2007, 12:37
You can use it, but you will need more. It is not adequate to fill
your sump.
R.E. (Ron) Marabito, Dallas, tX 92WB40
--- In WanderlodgeForum@yahoogroups.com, "luckyron1"
08-31-2007, 09:58
Thanks guys, and I'm sure that this will also exercise the bulk tank
mechanicals at the same time. It seems like everything in these high
end coaches goes by the old saw: Use it or lose it.
--- In
WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
> your sump.
bulk
yrs. have
up
