8v92 won't start update
08-31-2007, 21:38
Thanks for your replies. You were right it was a simple thing. For
some reason, the engine lost prime. They were able to get it started in the shop. I had the unit serviced at Bluebird in March and they also did the racor. Ever since then, I have been getting a check engine light when in a hard climb or when releasing the accelerator going down a hill. However it goes out when I crest the hill or when I put my foot back on the accelerator. Never a light on level ground or when ideling. They reserviced the racor, but said they really did not see anything that looked bad. Hope that fixed it since I am back on the road again. Thanks again for your help. Doug Mallory |
09-01-2007, 02:14
Glad it's running. Do you know how they diagnosed the lack of prime and what
they did to fix it? Do you have a primer pump on the engine? Kerry 82 FC 35 Denver- -- In WanderlodgeForum@yahoogroups.com, "dmallorys" > > Thanks for your replies. You were right it was a simple thing. For > some reason, the engine lost prime. They were able to get it started > in the shop. I had the unit serviced at Bluebird in March and they > also did the racor. Ever since then, I have been getting a check > engine light when in a hard climb or when releasing the accelerator > going down a hill. However it goes out when I crest the hill or when I > put my foot back on the accelerator. Never a light on level ground or > when ideling. They reserviced the racor, but said they really did not > see anything that looked bad. Hope that fixed it since I am back on > the road again. Thanks again for your help. > > Doug Mallory > |
09-01-2007, 04:30
Doug,
Glad you are back on the road and enjoying the trip! You say the engine lost prime and they serviced the racor. I hope they changed the spin on fuel filter(s) also. Seems like the road side service should have diagnosed the fuel starvation simply by dropping the spin on fuel filter(s) like I suggested in my first post, if he had checked to make sure it was getting fuel. Losing prime is an indication of an air leak in the fuel system somewhere or restrictions in the fuel supply, yes, like the plugged spin on fuel filter I described in my earlier response to you, or some other fuel line restriction. More than likely, it's just an air leak somewhere. Sounds to me like the 'real' problem still exists if you are getting check engine lights. You need to pull the code and figure out what is going on. Check your owners manual to find out how to do that if you don't know, or post the question here. You didn't list your coach in your signature on your last message, but I think it was a 1988? If so, I think you have the push button shifter and pulling the codes would involve watching the lights on the shifter console, counting the blinks and then checking the code manual for the related cause. If you are still sucking air somewhere in the fuel supply, running that thing real lean under load is not a good long term solution IMO. I would be watching the gauges really carefully, especially the temperature gauge and the Racor vacuum gauge. Good luck on the rest of the trip. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "dmallorys" wrote: > > Thanks for your replies. You were right it was a simple thing. For > some reason, the engine lost prime. They were able to get it started > in the shop. I had the unit serviced at Bluebird in March and they > also did the racor. Ever since then, I have been getting a check > engine light when in a hard climb or when releasing the accelerator > going down a hill. However it goes out when I crest the hill or when I > put my foot back on the accelerator. Never a light on level ground or > when ideling. They reserviced the racor, but said they really did not > see anything that looked bad. Hope that fixed it since I am back on > the road again. Thanks again for your help. > > Doug Mallory > |
09-02-2007, 02:48
The 8V92's and 6V92's don't have a booster pump and the fuel pump IS
NOT self-priming. I just replaced my fuel pump last month and replaced the hoses to the filters. Despite pre-filling the racor, spin-on and the fuel line between them, the new pump would not pull fuel up from the spin-on filter assembly. You have to "back-fill" the fuel line from the head of the spin-on filter assembly to the fuel pump in order to prime it. My guess is that one of the lines on yours is cracked and letting air seep into the fuel line between the pump and spin-on filter assembly. Those hoses are easy to replace, just remember to be exceptionally careful about not getting any contaminants into them when you re-attach the new hoses. Shane Fedeli 85PT40 6v92 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Glad it's running. Do you know how they diagnosed the lack of prime and what they did to > fix it? Do you have a primer pump on the engine? > > Kerry > 82 FC 35 > Denver- > > -- In WanderlodgeForum@yahoogroups.com, "dmallorys" > > > > Thanks for your replies. You were right it was a simple thing. For > > some reason, the engine lost prime. They were able to get it started > > in the shop. I had the unit serviced at Bluebird in March and they > > also did the racor. Ever since then, I have been getting a check > > engine light when in a hard climb or when releasing the accelerator > > going down a hill. However it goes out when I crest the hill or when I > > put my foot back on the accelerator. Never a light on level ground or > > when ideling. They reserviced the racor, but said they really did not > > see anything that looked bad. Hope that fixed it since I am back on > > the road again. Thanks again for your help. > > > > Doug Mallory > > > |
09-02-2007, 03:32
when air is found in a fuel system and the tank has not run dry, there
is a opening some place in the fuel path that is letting air in. Replacing a filter and experiencing a smooth running bus may give false security that you found the dirty filter to be the CAUSE of the 'engine will not start failure'. It could be that a partialy compramised filter with much more dirt capacity is causing a supply of fuel issue to the pump and this minor vacumn is enough to make the pump suck air through a crack as path of least resistance. Vacumn is the method used to determine if a filter is clogged and even that gauge will not work proper if there is a leak reducing vacumn pressure with introduction of air. If the gague is viewed prior to shut down and inches of water was within range, it may be a fuel/air leak issue GregoryO'Connor 94ptRomolandCa |
09-02-2007, 09:22
Would it be worth installing a manual or electric pump to solve just this
problem? Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > The 8V92's and 6V92's don't have a booster pump and the fuel pump IS > NOT self-priming. I just replaced my fuel pump last month and replaced > the hoses to the filters. Despite pre-filling the racor, spin-on and > the fuel line between them, the new pump would not pull fuel up from > the spin-on filter assembly. You have to "back-fill" the fuel line > from the head of the spin-on filter assembly to the fuel pump in order > to prime it. My guess is that one of the lines on yours is cracked and > letting air seep into the fuel line between the pump and spin-on > filter assembly. Those hoses are easy to replace, just remember to be > exceptionally careful about not getting any contaminants into them > when you re-attach the new hoses. > > Shane Fedeli > 85PT40 6v92 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Glad it's running. Do you know how they diagnosed the lack of prime > and what they did to > > fix it? Do you have a primer pump on the engine? > > > > Kerry > > 82 FC 35 > > Denver- > > > > -- In WanderlodgeForum@yahoogroups.com, "dmallorys" > > > > > > Thanks for your replies. You were right it was a simple thing. For > > > some reason, the engine lost prime. They were able to get it started > > > in the shop. I had the unit serviced at Bluebird in March and they > > > also did the racor. Ever since then, I have been getting a check > > > engine light when in a hard climb or when releasing the accelerator > > > going down a hill. However it goes out when I crest the hill or > when I > > > put my foot back on the accelerator. Never a light on level > ground or > > > when ideling. They reserviced the racor, but said they really did > not > > > see anything that looked bad. Hope that fixed it since I am back on > > > the road again. Thanks again for your help. > > > > > > Doug Mallory > > > > > > |
09-02-2007, 11:29
Good thought. An electric fuel pump could be plumbed to the spin-on filter
head. Its fuel source should be fairly close to the fuel tank or at least before the Racor filter. Turn the pump on to prime the engine. Shut if off after engine start. On 9/2/07, davidkerryedwards > > Would it be worth installing a manual or electric pump to solve just > this problem? > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com > "sfedeli3" <sfedeli3@...> wrote: > > > > The 8V92's and 6V92's don't have a booster pump and the fuel pump IS > > NOT self-priming. I just replaced my fuel pump last month and replaced > > the hoses to the filters. Despite pre-filling the racor, spin-on and > > the fuel line between them, the new pump would not pull fuel up from > > the spin-on filter assembly. You have to "back-fill" the fuel line > > from the head of the spin-on filter assembly to the fuel pump in order > > to prime it. My guess is that one of the lines on yours is cracked and > > letting air seep into the fuel line between the pump and spin-on > > filter assembly. Those hoses are easy to replace, just remember to be > > exceptionally careful about not getting any contaminants into them > > when you re-attach the new hoses. > > > > Shane Fedeli > > 85PT40 6v92 > > Hershey, PA > > > > --- In WanderlodgeForum@yahoogroups.com > "davidkerryedwards" > > > > > > > > Glad it's running. Do you know how they diagnosed the lack of prime > > and what they did to > > > fix it? Do you have a primer pump on the engine? > > > > > > Kerry > > > 82 FC 35 > > > Denver- > > > > > > -- In WanderlodgeForum@yahoogroups.com > "dmallorys" > > > > > > > > Thanks for your replies. You were right it was a simple thing. For > > > > some reason, the engine lost prime. They were able to get it started > > > > > in the shop. I had the unit serviced at Bluebird in March and they > > > > also did the racor. Ever since then, I have been getting a check > > > > engine light when in a hard climb or when releasing the accelerator > > > > going down a hill. However it goes out when I crest the hill or > > when I > > > > put my foot back on the accelerator. Never a light on level > > ground or > > > > when ideling. They reserviced the racor, but said they really did > > not > > > > see anything that looked bad. Hope that fixed it since I am back on > > > > the road again. Thanks again for your help. > > > > > > > > Doug Mallory > > > > > > > > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
09-02-2007, 13:44
From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 02, 2007 6:29 PM Subject: Re: [WanderlodgeForum] Re: 8v92 won't start update Maybe I am lucky But have had this bird for 10 years and the times that I have lost fuel prime it was my own fualt either did not change the O ring on the top hold down bolt .Before you change fuel filters was it running? Also there is a chance you fuel line collapse. Bob Loomas 1985 PT 36 Good thought. An electric fuel pump could be plumbed to the spin-on filter head. Its fuel source should be fairly close to the fuel tank or at least before the Racor filter. Turn the pump on to prime the engine. Shut if off after engine start. On 9/2/07, davidkerryedwards > > Would it be worth installing a manual or electric pump to solve just > this problem? > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com > "sfedeli3" <sfedeli3@...> wrote: > > > > The 8V92's and 6V92's don't have a booster pump and the fuel pump IS > > NOT self-priming. I just replaced my fuel pump last month and replaced > > the hoses to the filters. Despite pre-filling the racor, spin-on and > > the fuel line between them, the new pump would not pull fuel up from > > the spin-on filter assembly. You have to "back-fill" the fuel line > > from the head of the spin-on filter assembly to the fuel pump in order > > to prime it. My guess is that one of the lines on yours is cracked and > > letting air seep into the fuel line between the pump and spin-on > > filter assembly. Those hoses are easy to replace, just remember to be > > exceptionally careful about not getting any contaminants into them > > when you re-attach the new hoses. > > > > Shane Fedeli > > 85PT40 6v92 > > Hershey, PA > > > > --- In WanderlodgeForum@yahoogroups.com > "davidkerryedwards" > > > > > > > > Glad it's running. Do you know how they diagnosed the lack of prime > > and what they did to > > > fix it? Do you have a primer pump on the engine? > > > > > > Kerry > > > 82 FC 35 > > > Denver- > > > > > > -- In WanderlodgeForum@yahoogroups.com > "dmallorys" > > > > > > > > Thanks for your replies. You were right it was a simple thing. For > > > > some reason, the engine lost prime. They were able to get it started > > > > > in the shop. I had the unit serviced at Bluebird in March and they > > > > also did the racor. Ever since then, I have been getting a check > > > > engine light when in a hard climb or when releasing the accelerator > > > > going down a hill. However it goes out when I crest the hill or > > when I > > > > put my foot back on the accelerator. Never a light on level > > ground or > > > > when ideling. They reserviced the racor, but said they really did > > not > > > > see anything that looked bad. Hope that fixed it since I am back on > > > > the road again. Thanks again for your help. > > > > > > > > Doug Mallory > > > > > > > > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-02-2007, 14:10
When I chage fuel filters I finish the racor first, then i fill up the spin on,
i crack the two outlet lines at the filter going to the fuel passages in the heads and spin the engine until clear fuel comes out with no bubbles. tighten the lines She usually starts in about 15 seconds after that. re in geogria > > From: "bloomas" > Date: 2007/09/02 Sun PM 09:44:21 EDT > To: > Subject: Re: [WanderlodgeForum] Re: 8v92 won't start update > > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, September 02, 2007 6:29 PM > Subject: Re: [WanderlodgeForum] Re: 8v92 won't start update > Maybe I am lucky But have had this bird for 10 years > and the times that I have lost fuel prime it was my own fualt either did not change the O ring on the top hold down bolt .Before you change fuel filters was it running? > Also there is a chance you fuel line collapse. > Bob Loomas 1985 PT 36 > > > > Good thought. An electric fuel pump could be plumbed to the spin-on filter > head. Its fuel source should be fairly close to the fuel tank or at least > before the Racor filter. Turn the pump on to prime the engine. Shut if off > after engine start. > > On 9/2/07, davidkerryedwards > > > > Would it be worth installing a manual or electric pump to solve just > > this problem? > > > > Kerry > > 82 FC 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com > > "sfedeli3" <sfedeli3@...> wrote: > > > > > > The 8V92's and 6V92's don't have a booster pump and the fuel pump IS > > > NOT self-priming. I just replaced my fuel pump last month and replaced > > > the hoses to the filters. Despite pre-filling the racor, spin-on and > > > the fuel line between them, the new pump would not pull fuel up from > > > the spin-on filter assembly. You have to "back-fill" the fuel line > > > from the head of the spin-on filter assembly to the fuel pump in order > > > to prime it. My guess is that one of the lines on yours is cracked and > > > letting air seep into the fuel line between the pump and spin-on > > > filter assembly. Those hoses are easy to replace, just remember to be > > > exceptionally careful about not getting any contaminants into them > > > when you re-attach the new hoses. > > > > > > Shane Fedeli > > > 85PT40 6v92 > > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "davidkerryedwards" > > > > > > > > > > > Glad it's running. Do you know how they diagnosed the lack of prime > > > and what they did to > > > > fix it? Do you have a primer pump on the engine? > > > > > > > > Kerry > > > > 82 FC 35 > > > > Denver- > > > > > > > > -- In WanderlodgeForum@yahoogroups.com > > "dmallorys" > > > > > > > > > > Thanks for your replies. You were right it was a simple thing. For > > > > > some reason, the engine lost prime. They were able to get it started > > > > > > > in the shop. I had the unit serviced at Bluebird in March and they > > > > > also did the racor. Ever since then, I have been getting a check > > > > > engine light when in a hard climb or when releasing the accelerator > > > > > going down a hill. However it goes out when I crest the hill or > > > when I > > > > > put my foot back on the accelerator. Never a light on level > > > ground or > > > > > when ideling. They reserviced the racor, but said they really did > > > not > > > > > see anything that looked bad. Hope that fixed it since I am back on > > > > > the road again. Thanks again for your help. > > > > > > > > > > Doug Mallory > > > > > > > > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > > |
09-02-2007, 14:12
one more though ..if air is down you can't give the engine throttle to crank,
you can push on the governor if your rear start switch is workibg > > From: "bloomas" > Date: 2007/09/02 Sun PM 09:44:21 EDT > To: > Subject: Re: [WanderlodgeForum] Re: 8v92 won't start update > > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, September 02, 2007 6:29 PM > Subject: Re: [WanderlodgeForum] Re: 8v92 won't start update > Maybe I am lucky But have had this bird for 10 years > and the times that I have lost fuel prime it was my own fualt either did not change the O ring on the top hold down bolt .Before you change fuel filters was it running? > Also there is a chance you fuel line collapse. > Bob Loomas 1985 PT 36 > > > > Good thought. An electric fuel pump could be plumbed to the spin-on filter > head. Its fuel source should be fairly close to the fuel tank or at least > before the Racor filter. Turn the pump on to prime the engine. Shut if off > after engine start. > > On 9/2/07, davidkerryedwards > > > > Would it be worth installing a manual or electric pump to solve just > > this problem? > > > > Kerry > > 82 FC 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com > > "sfedeli3" <sfedeli3@...> wrote: > > > > > > The 8V92's and 6V92's don't have a booster pump and the fuel pump IS > > > NOT self-priming. I just replaced my fuel pump last month and replaced > > > the hoses to the filters. Despite pre-filling the racor, spin-on and > > > the fuel line between them, the new pump would not pull fuel up from > > > the spin-on filter assembly. You have to "back-fill" the fuel line > > > from the head of the spin-on filter assembly to the fuel pump in order > > > to prime it. My guess is that one of the lines on yours is cracked and > > > letting air seep into the fuel line between the pump and spin-on > > > filter assembly. Those hoses are easy to replace, just remember to be > > > exceptionally careful about not getting any contaminants into them > > > when you re-attach the new hoses. > > > > > > Shane Fedeli > > > 85PT40 6v92 > > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "davidkerryedwards" > > > > > > > > > > > Glad it's running. Do you know how they diagnosed the lack of prime > > > and what they did to > > > > fix it? Do you have a primer pump on the engine? > > > > > > > > Kerry > > > > 82 FC 35 > > > > Denver- > > > > > > > > -- In WanderlodgeForum@yahoogroups.com > > "dmallorys" > > > > > > > > > > Thanks for your replies. You were right it was a simple thing. For > > > > > some reason, the engine lost prime. They were able to get it started > > > > > > > in the shop. I had the unit serviced at Bluebird in March and they > > > > > also did the racor. Ever since then, I have been getting a check > > > > > engine light when in a hard climb or when releasing the accelerator > > > > > going down a hill. However it goes out when I crest the hill or > > > when I > > > > > put my foot back on the accelerator. Never a light on level > > > ground or > > > > > when ideling. They reserviced the racor, but said they really did > > > not > > > > > see anything that looked bad. Hope that fixed it since I am back on > > > > > the road again. Thanks again for your help. > > > > > > > > > > Doug Mallory > > > > > > > > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > > |
