					Trojan T-105
					09-04-2007, 22:38
				Trojan T-105
					I have read several posts fairly recently where someone mentions Trojan
			T-105 batteries. If you are replacing your batteries and plan on staying with the T-105, take a look at the T-125 instead. Its the same foot print, fits in an FC easily and has greater AH ratings..... John Stiles 1980 33FC "My Navion"  |
					09-05-2007, 02:30
				Trojan T-105
			From: John Stiles To: wanderlodgeforum@yahoogroups.com Sent: Wednesday, September 05, 2007 5:38 AM Subject: [WanderlodgeForum] Trojan T-105 A couple of weeks ago I had replace my batteries.10 of them they were trojan 605.Called a couple of places that were listed as dealers they no longer handle Trojan because they double in prices.Well it was back to Sam's I know you only get what you pay for but trojan at $150. a pop is not worth it to me. Bob Loomas 1985 PT 36 I have read several posts fairly recently where someone mentions Trojan T-105 batteries. If you are replacing your batteries and plan on staying with the T-105, take a look at the T-125 instead. Its the same foot print, fits in an FC easily and has greater AH ratings..... John Stiles 1980 33FC "My Navion" [Non-text portions of this message have been removed]  |
					09-05-2007, 04:34
				Trojan T-105
					In the early birds, the step solenoid is always hot- another phantom draw.
			Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed]  |
					09-05-2007, 06:19
				Trojan T-105
					John, I have looked into the T-125's several times  in the past years and have
			determined, at least for my purposes, that they just aren't cost effective. The cost per ah for the T-105 is the best deal I can find in a Trojan battery, even when comparing with the L-16. Now, if cost isn't an issue and/or one needs more ah and doesn't have the space to add enough T-105 batteries to meet the requirements, then I definitely would consider the T-125's or ever the L-16's. Just to give you an idea of our arrangement - we have 6, T-105 batteries and they are very adequate for our needs. We boon-dock for 5 months every winter. There are 5 solar panels on the roof (totaling about 460 watts and actually that's too many). We use the generator whenever ac power is needed for something that the inverter can't handle (i.e. air conditioners.) Off topic but related, I discovered a 4 amp, or so, draw that was not needed and will disconnect it when we will be boon-docking. That should make it even better than the last few years. The draw was the Sporlan Summer valve (bottom Sporlan valve) in the engine compartment. As originally wired by BB, that valve stays on when you are parked. I have no idea why it was that way. You always hear of "phantom" currents in our birds and this is the biggest single draw I have found. After turning the "A/T" switch off, the spot lights switch to left position and disconnecting a few relays that were always on and no longer needed, I think that I have reduced the phantom current to near zero. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: John Stiles To: wanderlodgeforum@yahoogroups.com Sent: Wednesday, September 05, 2007 3:38 AM Subject: [WanderlodgeForum] Trojan T-105 I have read several posts fairly recently where someone mentions Trojan T-105 batteries. If you are replacing your batteries and plan on staying with the T-105, take a look at the T-125 instead. Its the same foot print, fits in an FC easily and has greater AH ratings..... John Stiles 1980 33FC "My Navion" [Non-text portions of this message have been removed]  |
					09-05-2007, 06:51
				Trojan T-105
					What I mean by saying hot- it is hot to the touch.
					09-05-2007, 07:53
				Trojan T-105
					Way to go!  I think you are the first that I recall who has pin
			pointed this as a battery drain. Thanks! John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Off topic but related, I discovered a 4 amp, or so, draw that was not needed and will disconnect it when we will be boon-docking. That should make it even better than the last few years. The draw was the Sporlan Summer valve (bottom Sporlan valve) in the engine compartment. As originally wired by BB, that valve stays on when you are parked. I have no idea why it was that way. You always hear of "phantom" currents in our birds and this is the biggest single draw I have found. After turning the "A/T" switch off, the spot lights switch to left position and disconnecting a few relays that were always on and no longer needed, I think that I have reduced the phantom current to near zero. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > >  |
					09-05-2007, 08:01
				Trojan T-105
					John,
			I only wish I could figure our why the valve is even needed at all. And then to leave it in an on state when parked just does not make sense. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: John Stiles To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 05, 2007 12:53 PM Subject: [WanderlodgeForum] Re: Trojan T-105 Way to go! I think you are the first that I recall who has pin pointed this as a battery drain. Thanks! John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > Off topic but related, I discovered a 4 amp, or so, draw that was not needed and will disconnect it when we will be boon-docking. That should make it even better than the last few years. The draw was the Sporlan Summer valve (bottom Sporlan valve) in the engine compartment. As originally wired by BB, that valve stays on when you are parked. I have no idea why it was that way. You always hear of "phantom" currents in our birds and this is the biggest single draw I have found. After turning the "A/T" switch off, the spot lights switch to left position and disconnecting a few relays that were always on and no longer needed, I think that I have reduced the phantom current to near zero. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > [Non-text portions of this message have been removed]  |
					09-05-2007, 08:41
				Trojan T-105
			From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 05, 2007 1:19 PM Subject: Re: [WanderlodgeForum] Trojan T-105 Thanks Dick Going to check mine out today.So far the only draw I have been able to fiend are the clocks. Bob Loomas 1985 PT 36 John, I have looked into the T-125's several times in the past years and have determined, at least for my purposes, that they just aren't cost effective. The cost per ah for the T-105 is the best deal I can find in a Trojan battery, even when comparing with the L-16. Now, if cost isn't an issue and/or one needs more ah and doesn't have the space to add enough T-105 batteries to meet the requirements, then I definitely would consider the T-125's or ever the L-16's. Just to give you an idea of our arrangement - we have 6, T-105 batteries and they are very adequate for our needs. We boon-dock for 5 months every winter. There are 5 solar panels on the roof (totaling about 460 watts and actually that's too many). We use the generator whenever ac power is needed for something that the inverter can't handle (i.e. air conditioners.) Off topic but related, I discovered a 4 amp, or so, draw that was not needed and will disconnect it when we will be boon-docking. That should make it even better than the last few years. The draw was the Sporlan Summer valve (bottom Sporlan valve) in the engine compartment. As originally wired by BB, that valve stays on when you are parked. I have no idea why it was that way. You always hear of "phantom" currents in our birds and this is the biggest single draw I have found. After turning the "A/T" switch off, the spot lights switch to left position and disconnecting a few relays that were always on and no longer needed, I think that I have reduced the phantom current to near zero. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: John Stiles To: wanderlodgeforum@yahoogroups.com Sent: Wednesday, September 05, 2007 3:38 AM Subject: [WanderlodgeForum] Trojan T-105 I have read several posts fairly recently where someone mentions Trojan T-105 batteries. If you are replacing your batteries and plan on staying with the T-105, take a look at the T-125 instead. Its the same foot print, fits in an FC easily and has greater AH ratings..... John Stiles 1980 33FC "My Navion" [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]  |
					09-05-2007, 09:30
				Trojan T-105
					Dick can you elaborate on where in the engine compartment this valve is
			located. On 05/09/07, Richard Hayden > > John, > I only wish I could figure our why the valve is even needed at all. And > then to leave it in an on state when parked just does not make sense. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: John Stiles > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, September 05, 2007 12:53 PM > Subject: [WanderlodgeForum] Re: Trojan T-105 > > Way to go! I think you are the first that I recall who has pin > pointed this as a battery drain. Thanks! > > John Stiles > 1980 33FC > "My Navion" > > --- In WanderlodgeForum@yahoogroups.com > > "Richard Hayden" > > > > > > Off topic but related, I discovered a 4 amp, or so, draw that was > not needed and will disconnect it when we will be boon-docking. That > should make it even better than the last few years. The draw was the > Sporlan Summer valve (bottom Sporlan valve) in the engine > compartment. As originally wired by BB, that valve stays on when you > are parked. I have no idea why it was that way. You always hear > of "phantom" currents in our birds and this is the biggest single > draw I have found. After turning the "A/T" switch off, the spot > lights switch to left position and disconnecting a few relays that > were always on and no longer needed, I think that I have reduced the > phantom current to near zero. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed]  |
					09-05-2007, 09:38
				Trojan T-105
					I found a valve on the propane line at the tank that is on all  the time too.
			I just noticed it being warm the other day. Don 89 SP 36' Butler, PA In the early birds, the step solenoid is always hot- another phantom draw. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed]  |
