air throttle cable
09-06-2007, 13:24
air throttle cable
Where can I purchase a air throttle cable for DD 6V92 1984 1/2 PT 40
Thanks Joe South Bend IN 1984 1/2 PT 40 |
12-15-2009, 17:00
air throttle cable
Am in need of finding a source for the air throttle cable on an
87 PT. It is approx 4' long. I remember we had some discussion on this awhile back, but can't any info on it. Morse is out of business, and can't find another source. Steve Gureasko 90WBWL401/2 Jus Chillin Ponchatoula, La. Where we are starting on building the ark after a week of steady rain and over 21" of the wet stuff this month. |
12-15-2009, 22:57
air throttle cable
Steve- what is wrong with yours? Is it binding up or sticky? We can disassemble
and clean it at Q. You might also consider rebuilding the air throttle assembly. If you really need a cable, I would take it to a marine supply house and tell them it's for a boat. If you tell them it's in an over the road application, they won't help. There are numbers stamped into the side of the plastic insulation near one end that give the exact length in inches. You may have to rub off the crud and then wet the insulation to read it. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Patticake" <sgureasko@...> wrote: > > Am in need of finding a source for the air throttle cable on an > 87 PT. It is approx 4' long. > I remember we had some discussion on this awhile back, but can't > any info on it. Morse is out of business, and can't find another > source. > > Steve Gureasko > 90WBWL401/2 Jus Chillin > Ponchatoula, La. Where we are starting on building the ark after > a week of steady rain and over 21" of the > wet stuff this month. > |
12-16-2009, 11:49
air throttle cable
Shane,
Thanks for the reply, but this is not for me. A friend who has an '87 needs the cable. He said it was binding in the housing and the sheathing was staring to rust(go figure! Just because he lives in New Orleans). He knows that it is 4' long and has metric threads on it. The marine places he has tried don't have it. Most of the boats have mechanical linkage with zerk fittings. He did say that if he can figure out how to convert over to mechanical linkage he would. Steve Gureasko 90WBWL401/2 Jus Chillin Ponchatoula, La. Where it finally stopped raining, and I stopped with the ark, but the animals are wet and smelly. Anyone want to buy fresh fertilizer? |
12-16-2009, 21:55
air throttle cable
Steve- Have him contact these folks- [http://www.midwestcontrol.com/240.php]
It's a standard push-pull cable with unique ends. He'd probably be able to send them the old cable and have a new one made up. On ag equipment, this kind of stuff is pretty common -Shane --- In WanderlodgeForum@yahoogroups.com, "Patticake" <sgureasko@...> wrote: > > Shane, > Thanks for the reply, but this is not for me. A friend who has > an '87 needs the cable. He said it was binding in the housing and > the sheathing was staring to rust(go figure! Just because he lives > in New Orleans). He knows that it is 4' long and has metric threads > on it. The marine places he has tried don't have it. Most of > the boats have mechanical linkage with zerk fittings. > He did say that if he can figure out how to convert over to mechanical linkage he would. > > Steve Gureasko > 90WBWL401/2 Jus Chillin > Ponchatoula, La. Where it finally stopped raining, and I > stopped with the ark, but the animals are > wet and smelly. Anyone want to buy fresh > fertilizer? > |
12-17-2009, 00:21
air throttle cable
Steve,
This cable has been an issue with little or no inputs for an easy fix. The cable is used on the Bendix curise control / air throttle cylinder, also used on many PT's, SP's and late model FC's. There are many posts on the WOG forum, In the interest of helping your friend one on the threads is http://www.wanderlodgeownersgroup.com/fo...=midw\ estcontrol also do a search for Bendix air throttle or Bendix Cruise. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Patticake" <sgureasko@...> wrote: > > Am in need of finding a source for the air throttle cable on an > 87 PT. It is approx 4' long. > I remember we had some discussion on this awhile back, but can't > any info on it. Morse is out of business, and can't find another > source. > > Steve Gureasko > 90WBWL401/2 Jus Chillin > Ponchatoula, La. Where we are starting on building the ark after > a week of steady rain and over 21" of the > wet stuff this month. > |
12-17-2009, 00:27
air throttle cable
Steve,
This cable has been an issue with little or no inputs for an easy fix. The cable is used on the Bendix cruise control / air throttle cylinder, also used on many PT's, SP's and late model FC's. There are many posts on the WOG forum, In the interest of helping your friend one on the threads is http://www.wanderlodgeownersgroup.com/fo...=midw\ estcontrol also do a search for Bendix air throttle or Bendix Cruise. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Patticake" <sgureasko@...> wrote: > > Am in need of finding a source for the air throttle cable on an > 87 PT. It is approx 4' long. > I remember we had some discussion on this awhile back, but can't > any info on it. Morse is out of business, and can't find another > source. > > Steve Gureasko > 90WBWL401/2 Jus Chillin > Ponchatoula, La. Where we are starting on building the ark after > a week of steady rain and over 21" of the > wet stuff this month. > |
