					Camera trigger - front overhead solenoid
					09-07-2007, 02:54
					Still trying to get my backup camera operating. I've had the camera
			tested - it works. The coax is good from between the camera and the monitor chassis. The monitor is working. The camera gets power when the monitor is turned on. Still no backup camera when ignition is turned on. A lead in the front overhead is labled "camera trigger". This circuit breaker is enabled w/the ignition. Does anyone know where this lead goes or what it actually does? The soleniod in there stays up when the ignition is turned off. It should release. After much testing I suspect a bad solenoid. Where can I get a replacement? Art Weatherly Riverside Ca. '85 PT36  |
					09-07-2007, 03:52
			From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 07, 2007 9:54 AM Subject: [WanderlodgeForum] Camera trigger - front overhead solenoid You can get one at most napa stores or truck parts store. Bob Loomas 1985 PT 36 Still trying to get my backup camera operating. I've had the camera tested - it works. The coax is good from between the camera and the monitor chassis. The monitor is working. The camera gets power when the monitor is turned on. Still no backup camera when ignition is turned on. A lead in the front overhead is labled "camera trigger". This circuit breaker is enabled w/the ignition. Does anyone know where this lead goes or what it actually does? The soleniod in there stays up when the ignition is turned off. It should release. After much testing I suspect a bad solenoid. Where can I get a replacement? Art Weatherly Riverside Ca. '85 PT36 [Non-text portions of this message have been removed]  |
