Air Step 90 SP36
09-07-2007, 05:53
Air Step 90 SP36
I just need to tell someone that I actually fixed my air step! If
yours refuses to operate check the grounds from the plugs on the air valve. I found, after much searching and swearing, that the entire step structure had lost contact (ground) with the rest of the coach. The plugs are grounded to the step structure hence the step doesn't operate. Ran a new ground wire from under the step tread down through the hole where you fill the reservor for the jacks. They work!! I hope this saves someone time. Bob Criss Bethel Park, PA 90SP36 |
