Air Dryer issue
05-10-2005, 04:38
Air Dryer issue
I had my BB in for a service check and the mechanic said that the air
dryer was not working properly and that it would be cheaper and easier just to replace the old air dryer with a newer version. I guess it is supposed to purge each time it comes up to pressure and mine did not do it. What is the process to replace the parts of the original air dryer (84 FC35)? Is this within the capabilities of a fairly handy but BB novice owner? I am assuming that the parts would be cheaper if I do it myself vs replacement. The replacement part was an AD-9 (I think that is what the parts dept said) for $317 plus labor of about $150. I might be able to get a discount on the air dryer to about $200-250. Steve Meach 84 FC35 |
05-10-2005, 04:51
Air Dryer issue
--- In WanderlodgeForum@yahoogroups.com, "SFMEACH" <sfmeach@y...> wrote:
>on ebay currently 149.00 Stephen |
05-10-2005, 05:02
Air Dryer issue
I paid $133.81 for the parts to rebuild the AD-2 air dryer...check &
purge valve maint. Kits, desiccant cartridge and new (not rebuilt) air governor. Shop charged 3 hours labor. I asked the shop about the AD-9 and they said it is a lengthy job as the air lines will need to be reworked for that unit. Curt Sprenger â87PT38, Anaheim, Calif. SFMEACH wrote: > I had my BB in for a service check and the mechanic said that the air > dryer was not working properly and that it would be cheaper and easier > just to replace the old air dryer with a newer version. I guess it is > supposed to purge each time it comes up to pressure and mine did not do > it. What is the process to replace the parts of the original air dryer > (84 FC35)? Is this within the capabilities of a fairly handy but BB > novice owner? I am assuming that the parts would be cheaper if I do it > myself vs replacement. The replacement part was an AD-9 (I think that > is what the parts dept said) for $317 plus labor of about $150. I > might be able to get a discount on the air dryer to about $200-250. > > Steve Meach > 84 FC35 |
05-10-2005, 05:15
Air Dryer issue
Steve,
I assume that you have the Bendix AD-2 air dryer on there now. The dryer cartridge assembly is like $30-35 plus a refundable core charge. The spitter valve kit is like another $12-15 or so. Going from memory on the prices since I don't have my log book with me, but those are in the range of the parts I got last fall. The replacement procedure should be in your blue box. It is basically a simple job, three bolts to drop the dryer bottom plate, unscrew the filter, clean the cannister, replace filter and bottom plate. If you do the spitter valve also, you will probably need to put the end plate in a vise between some wood pieces in order to get the big hex nut to break free. Then just follow the instructions on the spitter valve rebuilt kit. Just a few o-rings basically. Cheaper than going to the AD-9, which as I recall will involve some re-plumbing of air lines. Mike Bulriss 83 PT40 "Stagecoach" - for sale 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "SFMEACH" <sfmeach@y...> wrote: > I had my BB in for a service check and the mechanic said that the air > dryer was not working properly and that it would be cheaper and easier > just to replace the old air dryer with a newer version. I guess it is > supposed to purge each time it comes up to pressure and mine did not do > it. What is the process to replace the parts of the original air dryer > (84 FC35)? Is this within the capabilities of a fairly handy but BB > novice owner? I am assuming that the parts would be cheaper if I do it > myself vs replacement. The replacement part was an AD-9 (I think that > is what the parts dept said) for $317 plus labor of about $150. I > might be able to get a discount on the air dryer to about $200-250. > > Steve Meach > 84 FC35 |
05-10-2005, 05:50
Air Dryer issue
I agree Mike. I rebuilt mine and it took me longer to figure things out
then to actually do it. A competent mechanic should be able to do it in 1 hour easily. I got the rebuilt cartridge , spitter valve etc from NAPA for about the same prices you quote. Anyone should be able to do it if you follow the instructions. tom 1982 FC35 Vernon Center,NY At 05:15 PM 5/10/2005 +0000, you wrote: >Steve, > >I assume that you have the Bendix AD-2 air dryer on there now. The >dryer cartridge assembly is like $30-35 plus a refundable core charge. >The spitter valve kit is like another $12-15 or so. Going from >memory on the prices since I don't have my log book with me, but those >are in the range of the parts I got last fall. The replacement >procedure should be in your blue box. It is basically a simple job, >three bolts to drop the dryer bottom plate, unscrew the filter, clean >the cannister, replace filter and bottom plate. If you do the spitter >valve also, you will probably need to put the end plate in a vise >between some wood pieces in order to get the big hex nut to break >free. Then just follow the instructions on the spitter valve rebuilt >kit. Just a few o-rings basically. Cheaper than going to the AD-9, >which as I recall will involve some re-plumbing of air lines. > >Mike Bulriss >83 PT40 "Stagecoach" - for sale >91 PT40 "Texas Minivan" >San Antonio, TX > >--- In WanderlodgeForum@yahoogroups.com, "SFMEACH" <sfmeach@y...> wrote: > > I had my BB in for a service check and the mechanic said that the air > > dryer was not working properly and that it would be cheaper and easier > > just to replace the old air dryer with a newer version. I guess it is > > supposed to purge each time it comes up to pressure and mine did not do > > it. What is the process to replace the parts of the original air dryer > > (84 FC35)? Is this within the capabilities of a fairly handy but BB > > novice owner? I am assuming that the parts would be cheaper if I do it > > myself vs replacement. The replacement part was an AD-9 (I think that > > is what the parts dept said) for $317 plus labor of about $150. I > > might be able to get a discount on the air dryer to about $200-250. > > > > Steve Meach > > 84 FC35 > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
