Troubleshooting help
09-11-2007, 04:07
I have a new issue I would like to enlist the help of this esteemed
knowledge base. During our last trip, our suspension light stayed lit even after the coach was ready to drive. My air gauges for tag axle and front/rear suspension are operating normally. Tax axle pressure shows 60 psi, and the front/rear suspension gauges show 115psi, however my suspension warning light stays on (it actually stays flashing). Also, on visual inspection all of the airbags appear to be operating normally and the suspension airs up and dumps properly. Any cause I could troubleshoot myself? Thanks in advance for your help. Drew May 88WLWB40 |
09-11-2007, 04:18
Hi Drew:
On the drivers side front of the Coach, under the bumper and back a little, there should be a module there with 1/4 inch black plastic lines going to it, be sure it is not by passing air, there will be wires attached to it and those wires should be going to your suspension dump light. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 04:07 PM 9/11/2007 +0000, you wrote: >I have a new issue I would like to enlist the help of this esteemed >knowledge base. During our last trip, our suspension light stayed lit >even after the coach was ready to drive. My air gauges for tag axle >and front/rear suspension are operating normally. Tax axle pressure >shows 60 psi, and the front/rear suspension gauges show 115psi, >however my suspension warning light stays on (it actually stays >flashing). Also, on visual inspection all of the airbags appear to be >operating normally and the suspension airs up and dumps properly. Any >cause I could troubleshoot myself? > > > >Thanks in advance for your help. > >Drew May >88WLWB40 > > Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma |
09-11-2007, 04:34
I can't help with the problem, but thought that it should be noted that you do
NOT have a gauge for the front/rear suspension unless yours is unusual. That gauge is for front/rear brakes, and is separate from the suspension. To test that this is true, watch the gauge when you dump your suspension. On 9/11/2007 at 4:07 PM dam71967 wrote: >I have a new issue I would like to enlist the help of this esteemed >knowledge base. During our last trip, our suspension light stayed lit >even after the coach was ready to drive. My air gauges for tag axle >and front/rear suspension are operating normally. Tax axle pressure >shows 60 psi, and the front/rear suspension gauges show 115psi, >however my suspension warning light stays on (it actually stays >flashing). Also, on visual inspection all of the airbags appear to be >operating normally and the suspension airs up and dumps properly. Any >cause I could troubleshoot myself? > > > >Thanks in advance for your help. > >Drew May >88WLWB40 |
