How often do you check your battery level water?
09-13-2007, 08:15
So far with my single battery cooker, I check mine once a month. No
problems, so far.
83PT40
Livingston, Mt
09-13-2007, 08:35
I saw Ralph install one of those on Wallace's PT 40. Sure is a neat system.
83PT40
Livingston, Mt
09-13-2007, 10:38
In a message dated 9/13/2007 6:47:25 P.M. Mountain Standard Time,
jipjob@... writes:
When you go those RV sales lots, you the ones that have millions and
millions dollars worth of stock how do they maintain those units
befor sale time
Most are plugged into elec. Some are not. I had my 35FC for sale at a
consignment lot, years ago. The management said the coach would always have
electricity. I went there 3 weeks later, no electricity, no sales person to
bug
ya.Dead batteries-- I had to crawl under coach to attach jumper cables to genny
battery to start generator and then fired the coach up. Drove it off that
consignment lot and didn't look back.
83PT40
Livingston, Mt
09-13-2007, 12:04
Well this probably is an old subject but its interesting to think that
this is probably one of the most over looked items on our coaches. I
try to remember once a month to refill my battery's because of a cost
of over 350 dollars for four battery's this an easy solution. All
these items such as such battery tenders and whatnot's still those
items will not let you know that your battery acid water is below the
plates. So does anyone here have any horror stories to tell about this
most forgetful item?
Jipjob
78 Wanderlodge
09-13-2007, 12:13
that
this
> Jipjob
> 78 Wanderlodge
I was kind of wondering about our friends who have the 200,000 dollars
rigs how often do you guys take a peak at your batterys?
Jipjob
09-13-2007, 12:31
Why dont you install a single point battery watering system
http://capeinnovation.com/singlepoint/
Stephen 77fc35
> Jipjob
> 78 Wanderlodge
09-13-2007, 13:44
system.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
http://www.aol.com
Do the newer Wanderlodge coaches come with this single point device?
Looks like a winner for a sure cure for that low water problem in our
batterys.
befor sale time.
Jipjob
Rebel Bird
09-13-2007, 15:38
Jipjob
Untill I installed a "Smart Battery Charger" they needed checking once
a week. Now once a month is fine. Having a 79FC checking the batteries
is a challange to say the least. I made a battery filler/checker. I
used a water alarm it's sold for warning you of a flooded basement. I
made 2 probes that are the correct length for my batteries this is the
checker section. The filler consists of a gallon jug and a small hand
pump. The tube from the pump has the probes on it. Stick the end in
each cell and add water untill the alarm sounds. Now it takes more time
to remove the caps. Cost less than 30$. The auto filler sounds great,
but I like to check the cables and compartment as well.
Picky
79FC33SB
> Jipjob
> 78 Wanderlodge
09-13-2007, 16:33
For my money you can't beat AGM batteries. Lots going for them, and never having
to check fluid levels is just one of them.
Don Bradner
90 PT40 "Blue Thunder"
Posting today by satellite from Salt Lake City, headed for Cheyenne in a couple
of days.
>Jipjob
>78 Wanderlodge
User(s) browsing this thread: 6 Guest(s)
