Transmission "Do Not Shift" Light and Code 22 (Speed Sensor)
09-13-2007, 13:48
Greetings All; I started my coach today which has been sitting in
covered storage with shore power for about two weeks. The transmission "Do Not Shift" light and check transmission light are staying on. It flashes a Code 22 which indicates a Speed Sensor issue. Does anyone have any experience with this issue? I did not note any transmission problems on my last trip which was about two weeks ago. I cleaned the ground strap connections on the transmission and frame and checked the transmission cannon plug but the warning lights remain on. Thanks. David Hanvy 89WB PT40 Crosby, TX |
09-13-2007, 23:14
Although I don't think your bus would start if the remote rear start switch was
acting up, mine will give me a do not shift light in the rear start position and in the front position if it is not engaged properly. Not all coaches are wired to give a do not shift light on the remote rear start position but mine does. I have never checked my codes so can't help there. I would cycle that switch to rear, off, and back to front, restart and see what happens.. It is a long shot but easy to do. Let us know what you find for future reference. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: David Hanvy To: WanderlodgeForum@yahoogroups.com Sent: Thursday, September 13, 2007 8:48 PM Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light and Code 22 (Speed Sensor) Greetings All; I started my coach today which has been sitting in covered storage with shore power for about two weeks. The transmission "Do Not Shift" light and check transmission light are staying on. It flashes a Code 22 which indicates a Speed Sensor issue. Does anyone have any experience with this issue? I did not note any transmission problems on my last trip which was about two weeks ago. I cleaned the ground strap connections on the transmission and frame and checked the transmission cannon plug but the warning lights remain on. Thanks. David Hanvy 89WB PT40 Crosby, TX [Non-text portions of this message have been removed] |
09-14-2007, 06:09
Leroy/Kevin,
Thanks for your replies. I started the engine from the rear remote and the transmission warning light/do not shift remains on. No change when I switched back to the front either. Additionally, I disconnected from shore power and disconnected the ground cable on the battery bank in an effort to reset the tranny. No luck on that either. (do not shift equals WILL not shift) I plan to to locate and read up on the Speed Sensor as a next step. All input is appreciated. David Hanvy 89WB PT40 Crosby, TX --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Although I don't think your bus would start if the remote rear start switch was acting up, mine will give me a do not shift light in the rear start position and in the front position if it is not engaged properly. Not all coaches are wired to give a do not shift light on the remote rear start position but mine does. I have never checked my codes so can't help there. I would cycle that switch to rear, off, and back to front, restart and see what happens.. It is a long shot but easy to do. > Let us know what you find for future reference. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: David Hanvy > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, September 13, 2007 8:48 PM > Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light and Code 22 (Speed Sensor) > > > Greetings All; I started my coach today which has been sitting in > covered storage with shore power for about two weeks. The > transmission "Do Not Shift" light and check transmission light are > staying on. It flashes a Code 22 which indicates a Speed Sensor issue. > Does anyone have any experience with this issue? I did not note any > transmission problems on my last trip which was about two weeks ago. I > cleaned the ground strap connections on the transmission and frame and > checked the transmission cannon plug but the warning lights remain on. > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > [Non-text portions of this message have been removed] > |
09-14-2007, 07:02
David, I chased a do not shift light for months. mine would go out
when the coach was started and come on when the bus was shut off. Finally found loose wire on back of ignition switch. Low voltage and bad grounds do weird stuff to theses beasts. If you are unable to solve I'll get you the phone number for Industrial Transmission in Waco. They have the best Allison techs I have found and are usually willing to help you on the phone. Mike McMahan 1989 PT40 --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@...> wrote: > > Leroy/Kevin, > Thanks for your replies. I started the engine from the rear remote > and the transmission warning light/do not shift remains on. No change > when I switched back to the front either. Additionally, I > disconnected from shore power and disconnected the ground cable on > the battery bank in an effort to reset the tranny. No luck on that > either. (do not shift equals WILL not shift) I plan to to locate and > read up on the Speed Sensor as a next step. > All input is appreciated. David Hanvy 89WB PT40 Crosby, TX > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > Although I don't think your bus would start if the remote rear > start switch was acting up, mine will give me a do not shift light in > the rear start position and in the front position if it is not > engaged properly. Not all coaches are wired to give a do not shift > light on the remote rear start position but mine does. I have never > checked my codes so can't help there. I would cycle that switch to > rear, off, and back to front, restart and see what happens.. It is a > long shot but easy to do. > > Let us know what you find for future reference. > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > Royale Conversion > > ----- Original Message ----- > > From: David Hanvy > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, September 13, 2007 8:48 PM > > Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light and > Code 22 (Speed Sensor) > > > > > > Greetings All; I started my coach today which has been sitting in > > covered storage with shore power for about two weeks. The > > transmission "Do Not Shift" light and check transmission light > are > > staying on. It flashes a Code 22 which indicates a Speed Sensor > issue. > > Does anyone have any experience with this issue? I did not note > any > > transmission problems on my last trip which was about two weeks > ago. I > > cleaned the ground strap connections on the transmission and > frame and > > checked the transmission cannon plug but the warning lights > remain on. > > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
09-14-2007, 08:51
Mike, Thanks for the input. I'll check the ignition switch wiring on
both the front and rear remote. I would appreciate the contact info re Industrial Transmission in anycase. The local Allison rep is the Houston Stewart & Stevenson shop. I have spent more than a reasonable amount of $$ with this outfit on other type repairs in the past. David Hanvy 89WB Crosby, TX --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@...> wrote: > > David, I chased a do not shift light for months. mine would go out > when the coach was started and come on when the bus was shut off. > Finally found loose wire on back of ignition switch. Low voltage > and bad grounds do weird stuff to theses beasts. If you are unable > to solve I'll get you the phone number for Industrial Transmission > in Waco. They have the best Allison techs I have found and are > usually willing to help you on the phone. Mike McMahan 1989 PT40 > > > --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@> > wrote: > > > > Leroy/Kevin, > > Thanks for your replies. I started the engine from the rear remote > > and the transmission warning light/do not shift remains on. No > change > > when I switched back to the front either. Additionally, I > > disconnected from shore power and disconnected the ground cable on > > the battery bank in an effort to reset the tranny. No luck on that > > either. (do not shift equals WILL not shift) I plan to to locate > and > > read up on the Speed Sensor as a next step. > > All input is appreciated. David Hanvy 89WB PT40 Crosby, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > Although I don't think your bus would start if the remote rear > > start switch was acting up, mine will give me a do not shift light > in > > the rear start position and in the front position if it is not > > engaged properly. Not all coaches are wired to give a do not shift > > light on the remote rear start position but mine does. I have > never > > checked my codes so can't help there. I would cycle that switch to > > rear, off, and back to front, restart and see what happens.. It is > a > > long shot but easy to do. > > > Let us know what you find for future reference. > > > Leroy Eckert > > > 1990 WB-40"Smoke N Mirrors" > > > Niceville, FL > > > Royale Conversion > > > ----- Original Message ----- > > > From: David Hanvy > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, September 13, 2007 8:48 PM > > > Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light > and > > Code 22 (Speed Sensor) > > > > > > > > > Greetings All; I started my coach today which has been sitting > in > > > covered storage with shore power for about two weeks. The > > > transmission "Do Not Shift" light and check transmission light > > are > > > staying on. It flashes a Code 22 which indicates a Speed > Sensor > > issue. > > > Does anyone have any experience with this issue? I did not > note > > any > > > transmission problems on my last trip which was about two > weeks > > ago. I > > > cleaned the ground strap connections on the transmission and > > frame and > > > checked the transmission cannon plug but the warning lights > > remain on. > > > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
09-14-2007, 09:18
Howard, Industrial Transmission Ray Dobbs 254-776-4436 outside of
Waco, Tx I would reccomend them highly. Ray's brother Mike is the Stewart and Stevenson shop manager in Hewitt, Tx great team. Mike McMahan 1989 PT 40 --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@...> wrote: > > Mike, Thanks for the input. I'll check the ignition switch wiring on > both the front and rear remote. I would appreciate the contact info re > Industrial Transmission in anycase. The local Allison rep is the > Houston Stewart & Stevenson shop. I have spent more than a reasonable > amount of $$ with this outfit on other type repairs in the past. > David Hanvy 89WB Crosby, TX > > --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" > <mmcmahan@> wrote: > > > > David, I chased a do not shift light for months. mine would go > out > > when the coach was started and come on when the bus was shut off. > > Finally found loose wire on back of ignition switch. Low voltage > > and bad grounds do weird stuff to theses beasts. If you are unable > > to solve I'll get you the phone number for Industrial Transmission > > in Waco. They have the best Allison techs I have found and are > > usually willing to help you on the phone. Mike McMahan 1989 PT40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@> > > wrote: > > > > > > Leroy/Kevin, > > > Thanks for your replies. I started the engine from the rear > remote > > > and the transmission warning light/do not shift remains on. No > > change > > > when I switched back to the front either. Additionally, I > > > disconnected from shore power and disconnected the ground cable > on > > > the battery bank in an effort to reset the tranny. No luck on > that > > > either. (do not shift equals WILL not shift) I plan to to locate > > and > > > read up on the Speed Sensor as a next step. > > > All input is appreciated. David Hanvy 89WB PT40 Crosby, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > > > > Although I don't think your bus would start if the remote rear > > > start switch was acting up, mine will give me a do not shift > light > > in > > > the rear start position and in the front position if it is not > > > engaged properly. Not all coaches are wired to give a do not > shift > > > light on the remote rear start position but mine does. I have > > never > > > checked my codes so can't help there. I would cycle that switch > to > > > rear, off, and back to front, restart and see what happens.. It > is > > a > > > long shot but easy to do. > > > > Let us know what you find for future reference. > > > > Leroy Eckert > > > > 1990 WB-40"Smoke N Mirrors" > > > > Niceville, FL > > > > Royale Conversion > > > > ----- Original Message ----- > > > > From: David Hanvy > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, September 13, 2007 8:48 PM > > > > Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light > > and > > > Code 22 (Speed Sensor) > > > > > > > > > > > > Greetings All; I started my coach today which has been > sitting > > in > > > > covered storage with shore power for about two weeks. The > > > > transmission "Do Not Shift" light and check transmission > light > > > are > > > > staying on. It flashes a Code 22 which indicates a Speed > > Sensor > > > issue. > > > > Does anyone have any experience with this issue? I did not > > note > > > any > > > > transmission problems on my last trip which was about two > > weeks > > > ago. I > > > > cleaned the ground strap connections on the transmission and > > > frame and > > > > checked the transmission cannon plug but the warning lights > > > remain on. > > > > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > |
09-15-2007, 11:27
All, I'm sorry to report that my best efforts yielded no progress
today. I'll sleep on it and if nothing else occurs to me to try, I'll give Industrial Transmission a call on Monday. Hate to think what a pain it would be to have get the coach towed. It's inside a storage building and there is very lttle room to maneuver in and out of the facility in the base case. David Hanvy, 89WB PT40 Crosby, TX --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@...> wrote: > > Howard, Industrial Transmission Ray Dobbs 254-776-4436 outside of > Waco, Tx I would reccomend them highly. Ray's brother Mike is the > Stewart and Stevenson shop manager in Hewitt, Tx great team. Mike > McMahan 1989 PT 40 > > > --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@> > wrote: > > > > Mike, Thanks for the input. I'll check the ignition switch wiring > on > > both the front and rear remote. I would appreciate the contact > info re > > Industrial Transmission in anycase. The local Allison rep is the > > Houston Stewart & Stevenson shop. I have spent more than a > reasonable > > amount of $$ with this outfit on other type repairs in the past. > > David Hanvy 89WB Crosby, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" > > <mmcmahan@> wrote: > > > > > > David, I chased a do not shift light for months. mine would go > > out > > > when the coach was started and come on when the bus was shut > off. > > > Finally found loose wire on back of ignition switch. Low > voltage > > > and bad grounds do weird stuff to theses beasts. If you are > unable > > > to solve I'll get you the phone number for Industrial > Transmission > > > in Waco. They have the best Allison techs I have found and are > > > usually willing to help you on the phone. Mike McMahan 1989 > PT40 > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@> > > > wrote: > > > > > > > > Leroy/Kevin, > > > > Thanks for your replies. I started the engine from the rear > > remote > > > > and the transmission warning light/do not shift remains on. No > > > change > > > > when I switched back to the front either. Additionally, I > > > > disconnected from shore power and disconnected the ground > cable > > on > > > > the battery bank in an effort to reset the tranny. No luck on > > that > > > > either. (do not shift equals WILL not shift) I plan to to > locate > > > and > > > > read up on the Speed Sensor as a next step. > > > > All input is appreciated. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > > > > > > > Although I don't think your bus would start if the remote > rear > > > > start switch was acting up, mine will give me a do not shift > > light > > > in > > > > the rear start position and in the front position if it is not > > > > engaged properly. Not all coaches are wired to give a do not > > shift > > > > light on the remote rear start position but mine does. I have > > > never > > > > checked my codes so can't help there. I would cycle that > switch > > to > > > > rear, off, and back to front, restart and see what happens.. > It > > is > > > a > > > > long shot but easy to do. > > > > > Let us know what you find for future reference. > > > > > Leroy Eckert > > > > > 1990 WB-40"Smoke N Mirrors" > > > > > Niceville, FL > > > > > Royale Conversion > > > > > ----- Original Message ----- > > > > > From: David Hanvy > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Thursday, September 13, 2007 8:48 PM > > > > > Subject: [WanderlodgeForum] Transmission "Do Not Shift" > Light > > > and > > > > Code 22 (Speed Sensor) > > > > > > > > > > > > > > > Greetings All; I started my coach today which has been > > sitting > > > in > > > > > covered storage with shore power for about two weeks. The > > > > > transmission "Do Not Shift" light and check transmission > > light > > > > are > > > > > staying on. It flashes a Code 22 which indicates a Speed > > > Sensor > > > > issue. > > > > > Does anyone have any experience with this issue? I did not > > > note > > > > any > > > > > transmission problems on my last trip which was about two > > > weeks > > > > ago. I > > > > > cleaned the ground strap connections on the transmission > and > > > > frame and > > > > > checked the transmission cannon plug but the warning > lights > > > > remain on. > > > > > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > |
09-17-2007, 09:13
Hoorah for a happy ending; Thanks to all who responded. The problem
was finally found to be a bad connection on the connector plug going to the speed sensor. It looked okay but ony worked after a liberal spraying of contact cleaner and an application of connector compound/grease. I did gleam the following info for anyone with an Allison HTB 748 tranny. A correctly functioning speed sensor on this tranny should read from 116 to 165 ohms (per Industrial Transmission) when checked across the two leads. David Hanvy 89WB PT40 TX --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@...> wrote: > > All, I'm sorry to report that my best efforts yielded no progress > today. I'll sleep on it and if nothing else occurs to me to try, I'll > give Industrial Transmission a call on Monday. Hate to think what a > pain it would be to have get the coach towed. It's inside a storage > building and there is very lttle room to maneuver in and out of the > facility in the base case. David Hanvy, 89WB PT40 Crosby, TX > > --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" > <mmcmahan@> wrote: > > > > Howard, Industrial Transmission Ray Dobbs 254-776-4436 outside of > > Waco, Tx I would reccomend them highly. Ray's brother Mike is the > > Stewart and Stevenson shop manager in Hewitt, Tx great team. Mike > > McMahan 1989 PT 40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@> > > wrote: > > > > > > Mike, Thanks for the input. I'll check the ignition switch wiring > > on > > > both the front and rear remote. I would appreciate the contact > > info re > > > Industrial Transmission in anycase. The local Allison rep is the > > > Houston Stewart & Stevenson shop. I have spent more than a > > reasonable > > > amount of $$ with this outfit on other type repairs in the past. > > > David Hanvy 89WB Crosby, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" > > > <mmcmahan@> wrote: > > > > > > > > David, I chased a do not shift light for months. mine would > go > > > out > > > > when the coach was started and come on when the bus was shut > > off. > > > > Finally found loose wire on back of ignition switch. Low > > voltage > > > > and bad grounds do weird stuff to theses beasts. If you are > > unable > > > > to solve I'll get you the phone number for Industrial > > Transmission > > > > in Waco. They have the best Allison techs I have found and are > > > > usually willing to help you on the phone. Mike McMahan 1989 > > PT40 > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" > <shanvy@> > > > > wrote: > > > > > > > > > > Leroy/Kevin, > > > > > Thanks for your replies. I started the engine from the rear > > > remote > > > > > and the transmission warning light/do not shift remains on. > No > > > > change > > > > > when I switched back to the front either. Additionally, I > > > > > disconnected from shore power and disconnected the ground > > cable > > > on > > > > > the battery bank in an effort to reset the tranny. No luck on > > > that > > > > > either. (do not shift equals WILL not shift) I plan to to > > locate > > > > and > > > > > read up on the Speed Sensor as a next step. > > > > > All input is appreciated. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > > > > > > > > > > Although I don't think your bus would start if the remote > > rear > > > > > start switch was acting up, mine will give me a do not shift > > > light > > > > in > > > > > the rear start position and in the front position if it is > not > > > > > engaged properly. Not all coaches are wired to give a do not > > > shift > > > > > light on the remote rear start position but mine does. I have > > > > never > > > > > checked my codes so can't help there. I would cycle that > > switch > > > to > > > > > rear, off, and back to front, restart and see what happens.. > > It > > > is > > > > a > > > > > long shot but easy to do. > > > > > > Let us know what you find for future reference. > > > > > > Leroy Eckert > > > > > > 1990 WB-40"Smoke N Mirrors" > > > > > > Niceville, FL > > > > > > Royale Conversion > > > > > > ----- Original Message ----- > > > > > > From: David Hanvy > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > Sent: Thursday, September 13, 2007 8:48 PM > > > > > > Subject: [WanderlodgeForum] Transmission "Do Not Shift" > > Light > > > > and > > > > > Code 22 (Speed Sensor) > > > > > > > > > > > > > > > > > > Greetings All; I started my coach today which has been > > > sitting > > > > in > > > > > > covered storage with shore power for about two weeks. The > > > > > > transmission "Do Not Shift" light and check transmission > > > light > > > > > are > > > > > > staying on. It flashes a Code 22 which indicates a Speed > > > > Sensor > > > > > issue. > > > > > > Does anyone have any experience with this issue? I did > not > > > > note > > > > > any > > > > > > transmission problems on my last trip which was about two > > > > weeks > > > > > ago. I > > > > > > cleaned the ground strap connections on the transmission > > and > > > > > frame and > > > > > > checked the transmission cannon plug but the warning > > lights > > > > > remain on. > > > > > > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > |
09-17-2007, 12:20
David,
Thank you for your posting. I've saved it in my Good-Things-To-Know, Transmission Info. folder. On 9/17/07, David Hanvy <shanvy@...> wrote: > > Hoorah for a happy ending; Thanks to all who responded. The problem > was finally found to be a bad connection on the connector plug going > to the speed sensor. It looked okay but ony worked after a liberal > spraying of contact cleaner and an application of connector > compound/grease. I did gleam the following info for anyone with an > Allison HTB 748 tranny. A correctly functioning speed sensor on this > tranny should read from 116 to 165 ohms (per Industrial Transmission) > when checked across the two leads. David Hanvy 89WB PT40 TX > > --- In WanderlodgeForum@yahoogroups.com > "David Hanvy" <shanvy@...> > wrote: > > > > All, I'm sorry to report that my best efforts yielded no progress > > today. I'll sleep on it and if nothing else occurs to me to try, > I'll > > give Industrial Transmission a call on Monday. Hate to think what a > > pain it would be to have get the coach towed. It's inside a storage > > building and there is very lttle room to maneuver in and out of the > > facility in the base case. David Hanvy, 89WB PT40 Crosby, TX > > > > --- In WanderlodgeForum@yahoogroups.com > "Mike McMahan" > > <mmcmahan@> wrote: > > > > > > Howard, Industrial Transmission Ray Dobbs 254-776-4436 outside of > > > Waco, Tx I would reccomend them highly. Ray's brother Mike is > the > > > Stewart and Stevenson shop manager in Hewitt, Tx great team. > Mike > > > McMahan 1989 PT 40 > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > "David Hanvy" <shanvy@> > > > wrote: > > > > > > > > Mike, Thanks for the input. I'll check the ignition switch > wiring > > > on > > > > both the front and rear remote. I would appreciate the contact > > > info re > > > > Industrial Transmission in anycase. The local Allison rep is > the > > > > Houston Stewart & Stevenson shop. I have spent more than a > > > reasonable > > > > amount of $$ with this outfit on other type repairs in the past. > > > > David Hanvy 89WB Crosby, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > "Mike McMahan" > > > > <mmcmahan@> wrote: > > > > > > > > > > David, I chased a do not shift light for months. mine would > > go > > > > out > > > > > when the coach was started and come on when the bus was shut > > > off. > > > > > Finally found loose wire on back of ignition switch. Low > > > voltage > > > > > and bad grounds do weird stuff to theses beasts. If you are > > > unable > > > > > to solve I'll get you the phone number for Industrial > > > Transmission > > > > > in Waco. They have the best Allison techs I have found and > are > > > > > usually willing to help you on the phone. Mike McMahan 1989 > > > PT40 > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > "David Hanvy" > > <shanvy@> > > > > > wrote: > > > > > > > > > > > > Leroy/Kevin, > > > > > > Thanks for your replies. I started the engine from the rear > > > > remote > > > > > > and the transmission warning light/do not shift remains on. > > No > > > > > change > > > > > > when I switched back to the front either. Additionally, I > > > > > > disconnected from shore power and disconnected the ground > > > cable > > > > on > > > > > > the battery bank in an effort to reset the tranny. No luck > on > > > > that > > > > > > either. (do not shift equals WILL not shift) I plan to to > > > locate > > > > > and > > > > > > read up on the Speed Sensor as a next step. > > > > > > All input is appreciated. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > "Leroy Eckert" > > > > > > > > > > > > > > > > > > > > Although I don't think your bus would start if the remote > > > rear > > > > > > start switch was acting up, mine will give me a do not > shift > > > > light > > > > > in > > > > > > the rear start position and in the front position if it is > > not > > > > > > engaged properly. Not all coaches are wired to give a do > not > > > > shift > > > > > > light on the remote rear start position but mine does. I > have > > > > > never > > > > > > checked my codes so can't help there. I would cycle that > > > switch > > > > to > > > > > > rear, off, and back to front, restart and see what > happens.. > > > It > > > > is > > > > > a > > > > > > long shot but easy to do. > > > > > > > Let us know what you find for future reference. > > > > > > > Leroy Eckert > > > > > > > 1990 WB-40"Smoke N Mirrors" > > > > > > > Niceville, FL > > > > > > > Royale Conversion > > > > > > > ----- Original Message ----- > > > > > > > From: David Hanvy > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > Sent: Thursday, September 13, 2007 8:48 PM > > > > > > > Subject: [WanderlodgeForum] Transmission "Do Not Shift" > > > Light > > > > > and > > > > > > Code 22 (Speed Sensor) > > > > > > > > > > > > > > > > > > > > > Greetings All; I started my coach today which has been > > > > sitting > > > > > in > > > > > > > covered storage with shore power for about two weeks. > The > > > > > > > transmission "Do Not Shift" light and check > transmission > > > > light > > > > > > are > > > > > > > staying on. It flashes a Code 22 which indicates a > Speed > > > > > Sensor > > > > > > issue. > > > > > > > Does anyone have any experience with this issue? I did > > not > > > > > note > > > > > > any > > > > > > > transmission problems on my last trip which was about > two > > > > > weeks > > > > > > ago. I > > > > > > > cleaned the ground strap connections on the > transmission > > > and > > > > > > frame and > > > > > > > checked the transmission cannon plug but the warning > > > lights > > > > > > remain on. > > > > > > > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
09-17-2007, 14:37
Thanks for the report. Happy it was something simple.
One question. What prompted you to zero in on the speed sensor? Do you have a drawing of the TCM wiring and functions? If the bus is not moving how does the speed sensor affect the shifter pad, if you know? Just for future reference. I would like to know more since I do not have a manual or drawing on my TCM. Thanks Leroy Eckert 1990 WB-40"Smoke N Mirrors Niceville, FL Royale Conversion ----- Original Message ----- From: David Hanvy To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 14, 2007 1:09 PM Subject: [WanderlodgeForum] Re: Transmission "Do Not Shift" Light and Code 22 (Speed Sensor) Leroy/Kevin, Thanks for your replies. I started the engine from the rear remote and the transmission warning light/do not shift remains on. No change when I switched back to the front either. Additionally, I disconnected from shore power and disconnected the ground cable on the battery bank in an effort to reset the tranny. No luck on that either. (do not shift equals WILL not shift) I plan to to locate and read up on the Speed Sensor as a next step. All input is appreciated. David Hanvy 89WB PT40 Crosby, TX --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Although I don't think your bus would start if the remote rear start switch was acting up, mine will give me a do not shift light in the rear start position and in the front position if it is not engaged properly. Not all coaches are wired to give a do not shift light on the remote rear start position but mine does. I have never checked my codes so can't help there. I would cycle that switch to rear, off, and back to front, restart and see what happens.. It is a long shot but easy to do. > Let us know what you find for future reference. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: David Hanvy > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, September 13, 2007 8:48 PM > Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light and Code 22 (Speed Sensor) > > > Greetings All; I started my coach today which has been sitting in > covered storage with shore power for about two weeks. The > transmission "Do Not Shift" light and check transmission light are > staying on. It flashes a Code 22 which indicates a Speed Sensor issue. > Does anyone have any experience with this issue? I did not note any > transmission problems on my last trip which was about two weeks ago. I > cleaned the ground strap connections on the transmission and frame and > checked the transmission cannon plug but the warning lights remain on. > Thanks. David Hanvy 89WB PT40 Crosby, TX > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
