electrical problems
08-29-2008, 05:37
electrical problems
John,
Your so right, "The thing can crush you, electrocute you, you can
fall off, and then there is the road risk. I guess we can say it can
get you coming and going as well as a couple ways in between."
Speaking of road risk here's a vivid reminder of what can happen.
Bus Crash Tes.tEver wonder what a bus crash looks like, check this
out.
http://www.youtube.com/watch?v=rrZr-Qzbfxo
Kurt Horvath
95 PT-42
10AC
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
> The 30 amp cord is pretty much a standard 110 with a funny plug on
it
> then? I knew that 220 was essentially two 110 hot wires but did
not
> know that the 50 was similar. Having been in a RV store not long
ago
> I noticed they had a featured item up near the check out a 50 amp
> plug with a distinct pull handle on it. I think they also had 30amp
> plugs similar. Didn't impress me at the time nearly as much as it
> does now. I don't have 50 amps into my coach but I learned
> something. I also did not realize the risk involved in the battery
> campartments. I was informed last year at the Maxton rally about
> that. I guess the low voltage stuff can be rather nasty as well.
> Perhaps some one will review and explain what the risk with the low
> voltage. Does make a rather nasty spark if you short the positive
> against the metal I know that. All kinds of ways a fellow can get
> hurt. I was up on the roof of my bird this morning and I was VERY
> careful. I remember seeing Don's X rays. I don't much like it up
> there but once a year I go up to check it over and see that all is
> well. Lets see. The thing can crush you, electrocute you, you can
can
> John Heckman
> central Pa
> 1973 FC
> > I may not have been clear: It was the coach end of the shore
cord,
> not the connector that is part of the coach. The pole end is a
molded
> connector, but the coach end is not; don't know if that is original?
> > There is a plastic ring cinched down to the cord, just behind the
> connector. I never gave it much thought, but now I wonder why that
is
> there. It lends itself to be the point that is grabbed to pull the
> connector out, but that puts strain on the wires in the connector.
> Clearly I should grab the connector body to pull it out, not the
> wires.
> > On 8/28/2008 at 8:31 PM Curt Sprenger wrote:
> > >Don,
> > >Great Post...Everyone...All of us with our older coaches need to
> do what
> > >Don
> > >just did, check our coach connectors. I'll add that we should
also
> check
> > >our
> > >shore cord coach ends.
> > >.On Thu, Aug 28, 2008 at 5:34 PM, Don Bradner
> > >wrote:
> > >> I've experienced two serious electrical problems on our
> current trip.
> > >> I'm hoping the second problem (solved) was the cause of the
> first, but I
> > >> can't get my head around exactly how it would be, so I'm
hoping
> someone
> > >with
> > >> more RV electrical experience than I have will have a clue. I
> will rest
> > >> easier if I know what caused the first problem.
> > >> The first problem I talked about here earlier, but will run
> through for
> > >> clarity:
> > >> With a lot of draw going on, I had the 50-amp breaker on the
> park pole
> > >> blow, plus the main inside breakers, plus the breaker for the
> inverter.
> > >> Power was lost on the inverter circuit, and did not return
when
> breakers
> > >> were turned back on with reduced draw. The inverter, a ProSine
> 2.0, is
> > >toast
> > >> - burnt components obvious when opening the case. I removed
> inverter
> > >and
> > >> wired input/output together for power on the inverted circuit
> when on
> > >park
> > >> power, and bought a small charger to keep the batteries up
while
> parked.
> > >> Xantrex sent out a new ProSine 2.0 (half-price, well out-of-
> warranty)
> > >and I
> > >> will get it tomorrow. I've been worrying about hooking it up
> without
> > >knowing
> > >> what caused the failure.
> > >> Problem number 2: Yesterday I moved, and on arrival at a park
in
> Ogallala
> > >> the 50-amp park breaker blew as soon as turned on. After
turning
> off the
> > >> internal main breakers I was able to get the park breaker to
> hold after
> > >one
> > >> more failure. The breaker was "spongy" so I wasn't sure if it
> was just
> > >weak.
> > >> Turning on the main breakers inside worked fine.
> > >> Moved again today, and the problem repeated except that
nothing
> would
> > >make
> > >> it work. In trying various things I found that my 30/50 cord
> worked fine.
> > >> So, I took the coach connector apart and found:
> > >> Screw for black wire fell out, and was quite black on the end.
> White and
> > >> Red attached, but screw not tight. Green was not attached at
> all - screw
> > >all
> > >> the way in, and wire laid across the top. Contacting case, but
> who knows
> > >how
> > >> well.
> > >> It is amazing I had power at all. I cut the end off and
rebuilt
> the
> > >> connector, and had no problem turning on the power.
> > >> It would seem to be an odd coincidence if problem one was not
> caused by
> > >> problem two, but since the ProSine 2.0 should in theory work
> regardless
> > >of
> > >> what occurs on the input side I'm not sure what the connection
> is.
> > >Anybody
> > >> have thoughts on this?
> > >> Don Bradner
> > >> 90 PT40 "Blue Thunder"
> > >> Posting today by satellite from Grand Island, Nebraska
> > >> My location: http://www.bbirdmaps.com/user2.cfm?user=1
> > >Curt Sprenger
> > >1987 PT38 8V92 "MacAttack Racing"
> > >Anaheim Hills, CA
08-29-2008, 05:45
electrical problems
Kurt,
That link as posted does not work. YouTube says "the video you
requested is not available".
FWIW,
1991 WB40 "Texas Minivan"
San Antonio, TX - not a real good weekend to go to the coast!
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> John,
> out.
> Kurt Horvath
> 95 PT-42
> 10AC
> it
> not
> ago
> can
> > John Heckman
> > central Pa
> > 1973 FC
> cord,
> molded
> is
> > wires.
> > > >Don,
> > do what
> > > >Don
> also
> > check
> > > >our
> > current trip.
> > first, but I
> hoping
> > someone
> > > >with
> > will rest
> > through for
> > > >> clarity:
> > park pole
> > inverter.
> when
> > breakers
> > 2.0, is
> > > >toast
> the
> > inverter
> > > >and
> > when on
> > > >park
> while
> > parked.
> > warranty)
> > > >and I
> > without
> > > >knowing
> in
> > Ogallala
> turning
> > off the
> > hold after
> > > >one
> > was just
> > > >weak.
> nothing
> > would
> > > >make
> > worked fine.
> > White and
> > all - screw
> > > >all
> > who knows
> > > >how
> > > >> well.
> rebuilt
> > the
> > caused by
> > regardless
> > > >of
> > is.
> > > >Anybody
> > > >> Don Bradner
> > > >Curt Sprenger
> > > >Anaheim Hills, CA
08-29-2008, 05:50
electrical problems
I see that Mike, here's the address again , You might havr to copy
and paste in address bar???
http://www.youtube.com/watch?v=rrZr-QZbfxo
Kurt Horvath
95 PT-42
10Ac
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...>
> Kurt,
> FWIW,
> Mike Bulriss
> > John,
can
this
> > out.
> > Kurt Horvath
> > 95 PT-42
> > 10AC
on
> > it
did
> > not
long
> > ago
amp
30amp
it
battery
about
well.
low
positive
get
VERY
up
is
can
it
> > can
> > > John Heckman
> > > central Pa
> > > 1973 FC
> > cord,
> > molded
original?
that
> > is
connector.
> > > wires.
> > > > >Don,
need to
> > > do what
> > > > >Don
should
> > also
> > > check
> > > > >our
> > > current trip.
> > > first, but I
> > hoping
> > > someone
> > > > >with
clue. I
> > > will rest
run
> > > through for
> > > > >> clarity:
> > > park pole
> > > inverter.
> > when
> > > breakers
ProSine
> > > 2.0, is
> > > > >toast
removed
> > the
> > > inverter
> > > > >and
circuit
> > > when on
> > > > >park
> > while
> > > parked.
of-
> > > warranty)
> > > > >and I
up
> > > without
> > > > >knowing
park
> > in
> > > Ogallala
> > turning
> > > off the
to
> > > hold after
> > > > >one
it
> > > was just
> > > > >weak.
> > nothing
> > > would
> > > > >make
cord
> > > worked fine.
end.
> > > White and
at
> > > all - screw
> > > > >all
but
> > > who knows
> > > > >how
> > > > >> well.
> > rebuilt
> > > the
not
> > > caused by
work
> > > regardless
> > > > >of
connection
> > > is.
> > > > >Anybody
> > > > >> Don Bradner
> > > > >Curt Sprenger
> > > > >Anaheim Hills, CA
08-29-2008, 06:00
electrical problems
Mike,
It worked this time.
Notice the millisecond timer in the top left corner on the interior
portion of the video, S--T happens fast. The second you don't respect
one of these machines is when they let you know who's boss.
Kurt Horvath
95 PT-42
10Ac
> Kurt Horvath
> 95 PT-42
> 10Ac
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> > Kurt,
> > FWIW,
> > Mike Bulriss
> > wrote:
> > > John,
can
it
> can
happen.
> this
> > > out.
> > > Kurt Horvath
> > > 95 PT-42
> > > 10AC
plug
> on
> > > it
> did
> > > not
> long
> > > ago
> amp
> 30amp
as
> it
> battery
> about
> well.
> low
> positive
can
> get
> VERY
it
> up
all
> is
you
> can
say
> it
> > > can
between.
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
shore
> > > cord,
a
> > > molded
> original?
behind
> the
> that
> > > is
pull
> the
> connector.
> the
> > > > wires.
> > > > > >Don,
> need to
> > > > do what
> > > > > >Don
> should
> > > also
> > > > check
> > > > > >our
our
> > > > current trip.
> the
> > > > first, but I
> > > hoping
> > > > someone
> > > > > >with
> clue. I
> > > > will rest
> run
> > > > through for
> > > > > >> clarity:
> the
> > > > park pole
for
> the
> > > > inverter.
return
> > > when
> > > > breakers
> ProSine
> > > > 2.0, is
> > > > > >toast
> removed
> > > the
> > > > inverter
> > > > > >and
> circuit
> > > > when on
> > > > > >park
up
> > > while
> > > > parked.
> of-
> > > > warranty)
> > > > > >and I
it
> up
> > > > without
> > > > > >knowing
> park
> > > in
> > > > Ogallala
> > > turning
> > > > off the
breaker
> to
> > > > hold after
> > > > > >one
if
> it
> > > > was just
> > > > > >weak.
> > > nothing
> > > > would
> > > > > >make
> cord
> > > > worked fine.
> end.
> > > > White and
attached
> at
> > > > all - screw
> > > > > >all
case,
> but
> > > > who knows
> > > > > >how
> > > > > >> well.
> > > rebuilt
> > > > the
was
> not
> > > > caused by
> work
> > > > regardless
> > > > > >of
> connection
> > > > is.
> > > > > >Anybody
> > > > > >> Don Bradner
> > > > > >Curt Sprenger
> > > > > >Anaheim Hills, CA
08-29-2008, 06:14
electrical problems
--- In WanderlodgeForum@yahoogroups.com, "Gary Smith"
> While I have some minor disagreements with some of what Juergen said
(there is only one common wire in the cable, two hot, and one ground),
with loose wires, it is possible you crossed the two 120v hot lines,
providing the high voltage he suggests. I believe the whole problem
was caused by the poor connections, Don. Not sure how the ProSine
should react to 240v hitting it, but could well weld some contacts, as
you found.
> Gary
> SOB
> From: Juergen
> Sent: Friday, August 29, 2008 8:27 AM
> Subject: Re: [WanderlodgeForum] Electrical problems
> All I do know is that if you put the 2 hot wires, or put the
2 hot spades into the socket and let only the third wire do the
ground, you will get a 250V zap. The 4th wire is the ground for the
other hot one. I don't know the details exactly, but whenever you let
2 hot and only 1 ground enter, you go BOOM. I know that you must have
all 4 wires, contacts, firmly connected before you turn the breakers on.
Black=hot
Red=Hot
White = Ground,
Bare wire = ground
These four must be in solid contact.
Juergen in PA
1991 WLSP 36
08-29-2008, 06:23
electrical problems
Oh my! I wonder is that was a monocoque framework on that bus rather
than the solid steel frame rails the BB has?
> Mike,
> Kurt Horvath
> 95 PT-42
> 10Ac
> > Kurt Horvath
> > 95 PT-42
> > 10Ac
> > wrote:
> > > Kurt,
> > > FWIW,
> > > Mike Bulriss
> > > wrote:
> > > > John,
> can
> it
> > can
> happen.
> > this
> > > > out.
> > > > Kurt Horvath
> > > > 95 PT-42
> > > > 10AC
> plug
> > on
> > > > it
> > did
> > > > not
> > long
> > > > ago
> > amp
> > 30amp
> as
> > it
> > battery
> > about
> > well.
> the
> > low
> > positive
> can
> > get
> > VERY
> it
> > up
> all
> > is
> you
> > can
> say
> > it
> > > > can
> between.
> > > > > John Heckman
> > > > > central Pa
> > > > > 1973 FC
> shore
> > > > cord,
> a
> > > > molded
> > original?
> behind
> > the
> > that
> > > > is
> pull
> > the
> > connector.
> > the
> > > > > wires.
> > > > > > >Don,
> > need to
> > > > > do what
> > > > > > >Don
> > should
> > > > also
> > > > > check
> > > > > > >our
> our
> > > > > current trip.
> > the
> > > > > first, but I
> > > > hoping
> > > > > someone
> > > > > > >with
> > clue. I
> > > > > will rest
> > run
> > > > > through for
> > > > > > >> clarity:
> > the
> > > > > park pole
> for
> > the
> > > > > inverter.
> return
> > > > when
> > > > > breakers
> > ProSine
> > > > > 2.0, is
> > > > > > >toast
> > removed
> > > > the
> > > > > inverter
> > > > > > >and
> > circuit
> > > > > when on
> > > > > > >park
> up
> > > > while
> > > > > parked.
> > of-
> > > > > warranty)
> > > > > > >and I
> it
> > up
> > > > > without
> > > > > > >knowing
> > park
> > > > in
> > > > > Ogallala
> > > > turning
> > > > > off the
> breaker
> > to
> > > > > hold after
> > > > > > >one
> if
> > it
> > > > > was just
> > > > > > >weak.
> > > > nothing
> > > > > would
> > > > > > >make
> > cord
> > > > > worked fine.
> the
> > end.
> > > > > White and
> attached
> > at
> > > > > all - screw
> > > > > > >all
> case,
> > but
> > > > > who knows
> > > > > > >how
> > > > > > >> well.
> > > > rebuilt
> > > > > the
> was
> > not
> > > > > caused by
> > work
> > > > > regardless
> > > > > > >of
> > connection
> > > > > is.
> > > > > > >Anybody
> > > > > > >> Don Bradner
> > > > > > >Curt Sprenger
> > > > > > >Anaheim Hills, CA
08-29-2008, 07:45
electrical problems
As much as I dislike messing with electrical problems, especially 30
and 50 amp stuff, I agree with Gary on this one - there is only one
common wire in the cable, two hot, and one ground.
I just recently posted about losing my neutral connection in my power
cord plug that goes into the pedestal, so it is somewhat fresh in my
mind. The round or 'u' shaped lug is the ground wire (green
sheathing). The two spade lugs on either side are hot (black and red
sheaths) and the bottom spade lug opposite the rounded one is the
shared neutral (white wire). There is only one shared ground for both
legs and one shared neutral for both hot legs.
Given the recent problems for Don and myself, this should be an item
on everyone's to-do list to open their plugs and check to make sure
the wire connections are tight. I know, hard to do on a molded plug.
These plugs and cords get lots of play wiggling them in and out of
the pedestals and coaches. I replaced mine with the new style yellow
plug end that has a molded handle built into the back. That way I
have a better grip to firmly insert/remove the plug without having to
wiggle the cord also. (Just remember that I then had to replace my
50-30 dogbone converter since the heavy ground lug on the new plug
would not go into my old converter cord.)
This is the way I understand the plug wiring. And yes, I am
relatively happy that I lost the neutral rather than the ground. At
least I did not fry anything really important to me (like me, my wife,
friends, pets, bus) other than the pedestal outlet.
That's my story and I'm sticking to it - at least for this post!
TGIF! TGIF!
--- In WanderlodgeForum@yahoogroups.com, "Juergen"
> you found.
> > Gary
> > SOB
> > From: Juergen
on.
> Black=hot
> Red=Hot
> White = Ground,
> Bare wire = ground
> Juergen in PA
> 1991 WLSP 36
08-29-2008, 09:22
electrical problems
That was one expensive test. New Setra ($600K??) and 44 test dummies.
Wonder how fast it was traveling when it hit the wall -- there was a
lot of front end damage. Sure lets you know why they have alternate
escape hatches!
aeonix1@...
On the road at Idaho Springs, CO
On Aug 29, 2008, at 12:00 PM, Kurt Horvath wrote:
> Mike,
> Kurt Horvath
> 95 PT-42
> 10Ac
>> Kurt Horvath
>> 95 PT-42
>> 10Ac
>> wrote:
>>> Kurt,
>>> FWIW,
>>> Mike Bulriss
>>> wrote:
>>>> John,
> can
> it
>> can
> happen.
>> this
>>>> out.
>>>> Kurt Horvath
>>>> 95 PT-42
>>>> 10AC
> plug
>> on
>>>> it
>> did
>>>> not
>> long
>>>> ago
>> amp
>> 30amp
> as
>> it
>> battery
>> about
>> well.
> the
>> low
>> positive
> can
>> get
>> VERY
> it
>> up
> all
>> is
> you
>> can
> say
>> it
>>>> can
> between.
>>>>> John Heckman
>>>>> central Pa
>>>>> 1973 FC
> shore
>>>> cord,
> a
>>>> molded
>> original?
> behind
>> the
>> that
>>>> is
> pull
>> the
>> connector.
>> the
>>>>> wires.
>>>>>>> Don,
>> need to
>>>>> do what
>>>>>>> Don
>> should
>>>> also
>>>>> check
>>>>>>> our
> our
>>>>> current trip.
>> the
>>>>> first, but I
>>>> hoping
>>>>> someone
>>>>>>> with
>> clue. I
>>>>> will rest
>> run
>>>>> through for
>>>>>>>> clarity:
>> the
>>>>> park pole
> for
>> the
>>>>> inverter.
> return
>>>> when
>>>>> breakers
>> ProSine
>>>>> 2.0, is
>>>>>>> toast
>> removed
>>>> the
>>>>> inverter
>>>>>>> and
>> circuit
>>>>> when on
>>>>>>> park
> up
>>>> while
>>>>> parked.
>> of-
>>>>> warranty)
>>>>>>> and I
> it
>> up
>>>>> without
>>>>>>> knowing
>> park
>>>> in
>>>>> Ogallala
>>>> turning
>>>>> off the
> breaker
>> to
>>>>> hold after
>>>>>>> one
> if
>> it
>>>>> was just
>>>>>>> weak.
>>>> nothing
>>>>> would
>>>>>>> make
>> cord
>>>>> worked fine.
> the
>> end.
>>>>> White and
> attached
>> at
>>>>> all - screw
>>>>>>> all
> case,
>> but
>>>>> who knows
>>>>>>> how
>>>>>>>> well.
>>>> rebuilt
>>>>> the
> was
>> not
>>>>> caused by
>> work
>>>>> regardless
>>>>>>> of
>> connection
>>>>> is.
>>>>>>> Anybody
>>>>>>>> Don Bradner
>>>>>>> Curt Sprenger
>>>>>>> Anaheim Hills, CA
> Yahoo! Groups Links
08-29-2008, 10:44
electrical problems
The new ProSine 2.0 was waiting for me on arrival in Greenwood, Nebraska. It is
now installed and everything is normal. Ran every test I could think of
before/after, and nothing appears to be amiss.
Don Bradner
08-29-2008, 11:19
electrical problems
If this was anNCAP test it should have been performed at 35MPH. The last 18 years of my engineering work was in safety restraints and vehicle impact performance. The front end must have a very stiff structure to withstand the impact loads, however the dummies do not do so well the energy that did not get absorbed in the frame was transferred to the occupants. I don't understand the 5* rating that is printedat the bottomscreenbelow the video.
Hisham Amaral
W. Bloomfield, MI.
--- On Fri, 8/29/08, Pete Masterson wrote:
Subject: Re: [WanderlodgeForum] Re: Electrical problems
Date: Friday, August 29, 2008, 5:22 PM
escape hatches!
"aeonix1%40mac.com"
> Mike,
> Kurt Horvath
> 95 PT-42
> 10Ac
> --- In "WanderlodgeForum%40yahoogroups.com", "Kurt
Horvath"
>> http://www.youtube. com/watch? v=rrZr-QZbfxo
>> Kurt Horvath
>> 95 PT-42
>> 10Ac
>> --- In "WanderlodgeForum%40yahoogroups.com", "mbulriss" <mbulriss@>
>> wrote:
>>> Kurt,
>>> FWIW,
>>> Mike Bulriss
coast!
>>> --- In "WanderlodgeForum%40yahoogroups.com", "Kurt Horvath"
>>> wrote:
>>>> John,
> can
> it
>> can
> happen.
>> this
>>>> out.
>>>> http://www.youtube. com/watch? v=rrZr-Qzbfxo
>>>> Kurt Horvath
>>>> 95 PT-42
>>>> 10AC
>>>> --- In "WanderlodgeForum%40yahoogroups.com", "bubblerboy64"
> plug
>> on
>>>> it
>> did
>>>> not
>> long
>>>> ago
amp
>> 30amp
> as
>> it
>> battery
>> about
>> well.
> the
>> low
>> positive
> can
>> get
>>>>> hurt. I was
>> VERY
> it
>> up
> all
>> is
> you
>> can
> say
>> it
>>>> can
> between.
>>>>> John Heckman
>>>>> central Pa
>>>>> 1973 FC
> shore
cord,
> a
>>>> molded
>> original?
> behind
>> the
>> that
>>>> is
> pull
>> the
>> connector.
>> the
>>>>> wires.
>>>>>>> Don,
>>>>>>> Great Post...Everyone. ..All of us with our older coaches
>> need to
>>>>> do what
>>>>>>> Don
>> should
>>>> also
>>>>> check
>>>>>>> our
> our
>>>>> current trip.
of
>> the
>>>>> first, but I
>>>> hoping
>>>>> someone
>>>>>>> with
>> clue. I
>>>>> will rest
>> run
>>>>> through for
>>>>>>>> clarity:
>> the
>>>>> park pole
breaker
> for
>> the
>>>>> inverter.
> return
>>>> when
>>>>> breakers
>> ProSine
>>>>> 2.0, is
>>>>>>> toast
>> removed
>>>> the
>>>>> inverter
>>>>>>> and
>> circuit
>>>>> when on
>>>>>>> park
> up
>>>> while
parked.
>> of-
>>>>> warranty)
>>>>>>> and I
> it
>> up
>>>>> without
>>>>>>> knowing
>> park
>>>> in
>>>>> Ogallala
>>>> turning
>>>>> off the
> breaker
to
>>>>> hold after
>>>>>>> one
> if
>> it
>>>>> was just
>>>>>>> weak.
>>>> nothing
>>>>> would
>>>>>>> make
>> cord
>>>>> worked fine.
on
> the
>> end.
>>>>> White and
> attached
>> at
>>>>> all - screw
>>>>>>> all
> case,
>> but
>>>>> who knows
>>>>>>> how
>>>>>>>> well.
>>>> rebuilt
>>>>> the
> was
>> not
>>>>> caused
by
>> work
>>>>> regardless
>>>>>>> of
>> connection
>>>>> is.
>>>>>>> Anybody
>>>>>>>> Don Bradner
>>>>>>>> My location: http://www.bbirdmaps. com/user2. cfm?user=
1
>>>>>>> Curt Sprenger
>>>>>>> Anaheim Hills, CA
> Yahoo! Groups Links
