UPDATE on Mysterious Items in Bedroom Closet 1993 Wanderlodge
09-26-2007, 04:56
Howdy,Y'all
THANK YOU for all of the replies to our thread. Jack kinda likes this one by Bob.. 93PT. IL., quoted below. Jack & Liz...You have two power cord's for your coach. One 50amp is > hard wired and you should have another plug in 30amp cord. The small > breaker box with the 30amp breakers is for the plug in cord. It goes > here first then to the main breaker box. You also should have a > antenna control switch in the same area. this work's same as the one > up front to control the direction of the tv antenna. Bob..93pt.Il. It was suggested that the rheostat turns on a convection fan, a component of the hydronic heating system, and that this fan is under the bedbox,near the big water filter. So we are going to lift up that mattress, open up the bed box cover and see if Jack can find that fan. This is where our MYSTERY stands, so far. Thanks again for all of the replies. This Forum is such a good, good place. Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Still in Buena Vista, CO |
