M380 Plasma moniter replacement
09-26-2007, 13:23
The TV monitor in my rig needs to be replaced. Has anyone had to
replace theirs? It appears Panasonic has a new version available
model TH-37PH10UK. If anyone has replaced the unit, where did you
puchase it from. I am in Massachusetts. Thank you
Ross Rosano
W000197
09-27-2007, 02:05
Ross,
I would seriously consider replacing it with a like size LCD if
available. Much less weight, no burn-in and many times less fragile.
The new LCD's rival the picture quality of plasma without the
problems associated with plasma in the extreme conditions associated
with a vehicle. JMHO, others may vary.
Rich D. '99LXi43' CT
--- In WanderlodgeForum@yahoogroups.com, "Ross Rosano"
> Ross Rosano
> W000197
09-27-2007, 14:50
I have to agree with Rich here. Don't waste your money on another
plasma if you can help it. Get yourself an LCD. Only thing you have to
worry about is physical dimensions - if it will fit and you like the
picture you see on the store's display unit, buy it and don't look
back.
-Ryan
'86 PT-40 8V92
On 9/27/07, g_man1146 wrote:
> Ross,
09-28-2007, 14:08
Thanks for your thoughts Ryan, I appreciated them. Ross R. M380
> back.
> -Ryan
> '86 PT-40 8V92
> > Ross,
