tire questions....
11-06-2007, 13:17
tire questions....
Hi group
Have spent some hours the last few days talking to tire shops. Les Schwab and Commercial Tire Have 6 good toyos (only a couple years and less old) but they are rated G. I've known since last year I needed to replace the steer tires with a heavier rated tire. The duals I plan to run out some time on.... Michelin 12 R 22.5 ZX2 had been recommended but have been out of stock each time I inquire. All the 11 r 22.5 seem to be underrated, the highest at 13200...still not enough to have much leeway. Today talking with commercial about a Yokohama 12 R 22.5 for a good rating. My question is - there is + .5 difference in the overall height of the tire, compared to what I am currently running (11R 22.5 Toyo) -will this difference in pitch cause a problem with the driveline (vibration, possible damage??). Wouldn't be an issue I reckon if I were replacing all 6 tires but that isn't happening..... Not looking for cheap, looking for right and safe, after this bird experiencing 3 steer blowouts in the heat the past few years...the last with me at the wheel. We've been lucky to have kept it on the blacktop upright and no other vehicles got involved. Equal to use or not to use, that is another question..... Thanks Rose Mary 82 FC 35 JP's White Bird |
11-07-2007, 02:07
tire questions....
Good morning Rose Mary:
You will not have a problem with the 12 R 22.5 in the front and the difference in height will not even be noticed when it comes to bottom line. The Yokohama tires have gained a good reputation and I have seen allot of them on coaches, trucks and so forth. Yokohama is owned by Goodyear but don't let that stop you. service. I have run equal and it did a good job until I needed to add air and even with the special filter type of valve installed, the equal kept getting back into the valve and I would have slow but sure air leaks. I went back to the spin balance and weight system and have just gotten over the fact that at times the weights look like a blemish on the rim when in fact it is a part of the tire, so be it. Ok now we can get on to the good subject of "what kind of coffee are we having today." This is one of those subjects where everyone has a different idea and experience. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 01:17 AM 11/7/2007 +0000, you wrote: >Hi group >Have spent some hours the last few days talking to tire shops. Les >Schwab and Commercial Tire > >Have 6 good toyos (only a couple years and less old) but they are >rated G. I've known since last year I needed to replace the steer >tires with a heavier rated tire. The duals I plan to run out some time >on.... >Michelin 12 R 22.5 ZX2 had been recommended but have been out of stock >each time I inquire. >All the 11 r 22.5 seem to be underrated, the highest at 13200...still >not enough to have much leeway. >Today talking with commercial about a Yokohama 12 R 22.5 for a good >rating. >My question is - >there is + .5 difference in the overall height of the tire, compared >to what I am currently running (11R 22.5 Toyo) -will this difference >in pitch cause a problem with the driveline >(vibration, possible damage??). Wouldn't be an issue I reckon if I >were replacing all 6 tires but that isn't happening..... > >Not looking for cheap, looking for right and safe, after this bird >experiencing 3 steer blowouts in the heat the past few years...the >last with me at the wheel. We've been lucky to have kept it on the >blacktop upright and no other vehicles got involved. > >Equal to use or not to use, that is another question..... > >Thanks >Rose Mary >82 FC 35 >JP's White Bird > > > |
11-07-2007, 08:53
tire questions....
The .5 difference in tire height won't affect anything if it's placed
on the steer axle. If used on the drive axle, you need to match all tires to have the same rolling diameter. The different diameter may also affect your speedometer/odometer readings. Although others may have strong opinions about Equal, when I had to replace a steer tire, it was 'spin balanced' with standard weights. It appears to be satisfactory. If you use equal, be sure to have filtered Schrader valves installed to avoid later leakage problems. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart TX On Nov 6, 2007, at 7:17 PM, Rose Mary wrote: > Hi group > Have spent some hours the last few days talking to tire shops. Les > Schwab and Commercial Tire > > Have 6 good toyos (only a couple years and less old) but they are > rated G. I've known since last year I needed to replace the steer > tires with a heavier rated tire. The duals I plan to run out some time > on.... > Michelin 12 R 22.5 ZX2 had been recommended but have been out of stock > each time I inquire. > All the 11 r 22.5 seem to be underrated, the highest at 13200...still > not enough to have much leeway. > Today talking with commercial about a Yokohama 12 R 22.5 for a good > rating. > My question is - > there is + .5 difference in the overall height of the tire, compared > to what I am currently running (11R 22.5 Toyo) -will this difference > in pitch cause a problem with the driveline > (vibration, possible damage??). Wouldn't be an issue I reckon if I > were replacing all 6 tires but that isn't happening..... > > Not looking for cheap, looking for right and safe, after this bird > experiencing 3 steer blowouts in the heat the past few years...the > last with me at the wheel. We've been lucky to have kept it on the > blacktop upright and no other vehicles got involved. > > Equal to use or not to use, that is another question..... > > Thanks > Rose Mary > 82 FC 35 > JP's White Bird > |
