New file uploaded to WanderlodgeForum
06-14-2005, 05:59
Post: #31
Thanks, now that I have reviewed the "device" I feel I might be missing
something. The accepted method of using a straight edge and a scale to measure
deflection appears to be equal to the accuracy the gage would provide. The
belts should be checked at oil change time, as should the fuel filters. I find
that the belts need to changed at 15/20k miles.
If one wants to observe a longer service life, it's OK with me.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Tuesday, June 14, 2005 10:40 AM
Subject: Re: [WanderlodgeForum] New file uploaded to WanderlodgeForum
Mike,
Here is the page with the tool. http://www.9xauto.com/tentiontool.htm
Wil Tifft
Wilton S. Tifft
tifft@...
http://www.tifft.com
NE PA
To:
Sent: Tuesday, June 14, 2005 11:29 AM
> Nice effort Tom, can't read it though.
> Mike Hohnstein
> Sent: Tuesday, June 14, 2005 10:10 AM
> Subject: [WanderlodgeForum] New file uploaded to WanderlodgeForum
> Hello,
> This email message is a notification to let you know that
> a file has been uploaded to the Files area of the WanderlodgeForum
> group.
> File : /3208 Belts 82 FC/Vbelt_tension.jpg
> Uploaded by : warbucks13477
> Description : Technical bulletin showing the correct V belt
tensions
> You can access this file at the URL:
http://groups.yahoo.com/group/Wanderlodg.../Vbel\
> To learn more about file sharing for your group, please visit:
> http://help.yahoo.com/help/us/groups/files
> Regards,
> warbucks13477
> Yahoo! Groups Links
> a.. To visit your group on the web, go to:
> http://groups.yahoo.com/group/WanderlodgeForum/
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> ------------------------ Yahoo! Groups
Sponsor --------------------~-->
> In low income neighborhoods, 84% do not own computers.
> At Network for Good, help bridge the Digital Divide!
> http://us.click.yahoo.com/B9pRWD/3MnJAA/.../pkiolB/TM
> Yahoo! Groups Links
Yahoo! Groups Links
06-14-2005, 10:30
Post: #32
Its probably due to your browser Mike and the size its displaying. Have you
printed it out?
tom
1982 FC35
Vernon Center,NY
>Mike Hohnstein
> Hello,
> group.
> Description : Technical bulletin showing the correct V belt tensions
>http://groups.yahoo.com/group/Wanderlodg...C/Vbe\
> Regards,
> warbucks13477
> Yahoo! Groups Links
>Yahoo! Groups Links
06-14-2005, 10:34
Post: #33
Mike I inspect the belts and hoses and change the oil and filters after
every longer trip and several times during the summer. then its easy to
check the belt tension with the Kriket which I believe has an advantage
over the old ruler and scale. Its small and you can very quickly push at
the center of each belt and get a readout. Once you use a kriket you will
throw away the ruler and scale. By the way where can you buy a scale?
tom
1982 FC35
Vernon Center,NY
>measure deflection appears to be equal to the accuracy the gage would
>provide. The belts should be checked at oil change time, as should the
>fuel filters. I find that the belts need to changed at 15/20k miles.
>Mike Hohnstein
>Germantown, WI
>83FC35
> From: Wilton S Tifft
> Mike,
> Wil Tifft
> Wilton S. Tifft
> tifft@...
> NE PA
> From: "Mike Hohnstein" <MHOHNSTEIN@...>
> To:
> > Mike Hohnstein
> > Hello,
> > group.
> tensions
06-15-2005, 09:04
Post: #34
Hello,
group.
File : /Jabsco Roof Lights/Jabsco Flood+Spot Light Control Diagram.JPG
Uploaded by : mbulriss <mbulriss@...>
Description : Wiring diagram for roof mounted spot and flood lights
http://groups.yahoo.com/group/Wanderlodg.../Jabs\
Regards,
06-16-2005, 07:23
Post: #35
Hello,
group.
File : /koni shock bushings/bushings for koni shocks
Uploaded by : dream_35_team
Description : split conical rubber bushings for koni's
http://groups.yahoo.com/group/Wanderlodg...s/bus\
hings%20for%20koni%20shocks
Regards,
dream_35_team
06-19-2005, 09:27
Post: #36
Hello,
group.
File : /BB AC Notes.doc
Uploaded by : fwernlein
Description : FC Dash AC project
http://groups.yahoo.com/group/Wanderlodg...0Notes.doc
Regards,
fwernlein
06-19-2005, 12:18
Post: #37
Just an observation. Why didnt you use the Red Dot 6260 at 38KBTU instead
of the smaller 6160 at 24KBTU? I believe the compressor will easily handle
it. If my condenser goes bad t hat is what I intend to use.
http://www.freezonerb276.com/RED_DOT_CONDENSERS.htmtom
1982 FC35
Vernon Center,NY
vndAt 09:27 PM 6/19/2005 +0000, you wrote:
>Hello,
>group.
>Regards,
>fwernlein
06-20-2005, 00:01
Post: #38
I was a close call...the Red Dot 6260 has same basic "roof
footprint", draws a little more power with the dual fans, and ran
about $350 more than the 6160 (which was in stock). Kysor AC had two
models that I looked at also, one similar to what I got, the next one
up was as I recall about 40" wide and too big for my mounting area.
Based solely on my W.A.G., I went with the smaller unit for $ and
also based on what tiny size of the OEM cond. element...even the 6160
adds roughly 25-30% to the heat exchange area, so I am hoping this is
sufficent for my needs. My opinion is that to realistically improve
performance of the dash air, the OEM condenser unit has to go, and I
think that going to either the 6160 or the 6260 unit is a good way to
go (but I am a novice, these are just my guesses). Another concern
is that the OEM electrical wiring is in my view another possible weak
link. I was trying to reduce amp load with the one fan.
I agree that the York/CCI type compressor will handle about anything,
this type unit fits the RPM range of our 3208's perfectly and we have
really no reason to worry about engine load with our engines.
Hopefully next weekend I can do final installs, evacuate and recharge
and see what I have accomplished. I'll take readings of pressures
and temps and update my posting...that will let us both know.
Frank
85FC33
Woodbridge, VA.
instead
handle
> 1982 FC35
> Vernon Center,NY
06-20-2005, 02:37
Post: #39
frank I already have converted my front A/C to R134A using the original
condenser. It works fine and blows cold but in my opinion is still
inadequate when the temp starts going up. Since the compressor is capable
of putting out somewhere in the range of 40,000 BTU it only makes sense to
me to make maximum use of it and go with the larger condenser.
But to make this work correctly (or even the stock one) you have to make
some basic changes in the electrical wiring.
There is to much current flowing thru the drivers side A/C switch in the
dash and the wiring going to the condenser fans is undersized also. Both of
those are easily taken care of by using Bosch relays to "trigger" new
wiring to both the fans in the evaporator and the condenser.
I am convinced that if you make this change and go with the larger
condenser you will get the cold air you need from the chassis A/C that you
need under the worse conditions. Seems like a very small cost to me for
such a large pay off.
We are lucky to have the forward control coaches in that the chassis air
can be truly made to work. The PT models on the other hand have such long
runs of A/C lines that even under the very best conditions they are
inadequate. For those I would defineatly change to the 6260 or even larger.
tom
1982 FC35
Vernon Center,NY
>Frank
>85FC33
>Woodbridge, VA.
>instead
>handle
> > 1982 FC35
> > Vernon Center,NY
>Yahoo! Groups Links
07-01-2005, 03:22
Post: #40
Hello,
group.
File : /Bluebird Engineering drawings /1982 Bluebird drawings.xls
Description : list of BB drawings for Tom Warners 1982 FC35
http://groups.yahoo.com/group/Wanderlodg...%20dr\
awings%20/1982%20Bluebird%20drawings.xls
Regards,
warbucks13477
