New file uploaded to WanderlodgeForum
02-19-2006, 04:36
Post: #61
A neat write-up of a common story from when we were all newbies or
wannabes and for many of us, before these help forums existed. Thanks
for posting it.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com,
WanderlodgeForum@yahoogroups.com wrote:
> Hello,
> This email message is a notification to let you know that
> a file has been uploaded to the Files area of the WanderlodgeForum
> group.
> File : /BB to date.doc
> Uploaded by : fwernlein
> Description : Newbee & Wannabes....read this.
> You can access this file at the URL:
> http://groups.yahoo.com/group/Wanderlodg...20date.doc
> To learn more about file sharing for your group, please visit:
> http://help.yahoo.com/help/us/groups/files
> Regards,
> fwernlein
03-13-2006, 15:08
Post: #62
Hello,
group.
File : /Jac Page1.jpg
Uploaded by : wanderlodge3208 <share@...>
Description : Jacobs Retarder Instruction Manual
http://groups.yahoo.com/group/Wanderlodg...0Page1.jpg
Regards,
03-13-2006, 16:02
Post: #63
Hello,
group.
File : /Jacobs Retarder Manual/Jac CoverSM.JPG
Description : Front Cover
http://groups.yahoo.com/group/Wanderlodg...nual/\
Regards,
03-13-2006, 16:24
Post: #64
FWIW, this is for a retarder, not the Jake brake.
There are four types or means of auxiliary braking available and at
least three have been used on the BB WL.
The Jake Brake was originally developed by the Jacob's Machine Co. It
is correctly called an engine brake because it changes the timing of
the exhaust valves to utilize the engine compression for braking.
The Exhaust brake was originally developed by Pac Brake of Canada. It
is basically a butterfly valve that closes the exhaust causing greater
back pressure which gives a braking effect.
The Telma Retarder, pictured here as the Jacob's retarder, is a
magnetic device that uses magnetic field to reduce the rotational
speed of the drive shaft.
The transmission retarder, which is available on Allison
transmissions, is basically a torque converter working backwards. The
braking effect is dissipated as heat.
The first three, and I believe the fourth also, have had their patents
expire which means that anyone can produce these items and there are
several companies that produce more than one of these items. Jacob's
is one of these companies.
Ernie is looking for information on the Jake or engine brake. .
George Lowry
'06 Alpine Apex - Formerly '95 WBDA 4203
Spearfish, SD - Last day at Wilderness Lakes TTN, CA
> Hello,
> group.
> Regards,
> Yahoo! Groups Links
03-13-2006, 19:27
Post: #65
Thanks to Stephen for uploading that file. George is correct, I need the
engine brake retarder schematics. Ernie-83pt40 in Louisiana
03-14-2006, 00:58
Post: #66
Scott- the jacobs engine brake is what I need. Thanks, hope your rally is a
success. ernie-83pt40-going home wed!!!
03-14-2006, 02:15
Post: #67
Heck Ernie, I have those, I thought you wanted the Jake brake stuff I
do not have a Jake on my coach. I have the retarder. Email me and I
will either snail mail it or scan and email..depends on you.
Scott B
86FC35 "RUBY"
Murrells Inlet SC "right next to heaven"
need the
03-14-2006, 02:43
Post: #68
Opps.. no problem..
Well, If any one needs it, its there.. LOL
Stephen
81 FC-33SB
Plant City, FL
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of erniecarpet@...
Sent: Tuesday, March 14, 2006 7:28 AM
Subject: Re: [WanderlodgeForum] New file uploaded to WanderlodgeForum
03-22-2006, 07:34
Post: #69
Hello,
group.
File : /Rally Information/Lone Star Birds Rally Schedule 2006.pdf
Uploaded by : mbulriss <mbulriss@...>
Description : Lone Star Birds 2006 Rally Schedule
http://groups.yahoo.com/group/Wanderlodg...ne%20\
Star%20Birds%20Rally%20Schedule%202006.pdf
Regards,
03-23-2006, 10:53
Post: #70
Hello,
group.
File : /Question Sensor.JPG
Description : Question sensor
http://groups.yahoo.com/group/Wanderlodg...Sensor.JPG
Regards,
