Sound-deadening mat under carpet?
10-06-2007, 05:51
Scott, on the newer 80's coaches, there was a sound deadening material
already installed. Unless you have wood up front and someone has not removed it- the material should be there. Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
10-06-2007, 06:53
I am still trying to quite my generator as much as possible. Has
anyone tried adding a sound-deadening mat under the carpet and did you get good results? If so, what did you use? I am running out of ideas for working inside the gen compartment, figured this might be another option. Scott Forman 86 PT38 Memphis |
10-06-2007, 09:08
Scott contact John Finn. He'll direct you to some parts of his site where
he's docuemented his whole sound deadening process On 06/10/2007, Scott Forman <sforman@...> wrote: > > I am still trying to quite my generator as much as possible. Has > anyone tried adding a sound-deadening mat under the carpet and did you > get good results? If so, what did you use? I am running out of ideas > for working inside the gen compartment, figured this might be another > option. > > Scott Forman > 86 PT38 > Memphis > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
10-08-2007, 03:28
Hello Scott,
We installed an enclosed/fan cooled generator in our coach and then replaced the decaying foam insulation with new 1" thick sound insulation material on the interior of the generator compartment. Also installed a new pancake style muffler on the generator exhaust. We still hear a low roar when the generator is on but we can sleep with it on without a problem. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I am still trying to quite my generator as much as possible. Has > anyone tried adding a sound-deadening mat under the carpet and did you > get good results? If so, what did you use? I am running out of ideas > for working inside the gen compartment, figured this might be another > option. > > Scott Forman > 86 PT38 > Memphis > |
10-08-2007, 04:46
What model gen did you use?
Scott --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > Hello Scott, > > We installed an enclosed/fan cooled generator in our coach and then replaced the > decaying foam insulation with new 1" thick sound insulation material on the interior of the > generator compartment. Also installed a new pancake style muffler on the generator > exhaust. We still hear a low roar when the generator is on but we can sleep with it on > without a problem. > > Regards, Eric in San Antonio > 84FC35SBWL2 > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> wrote: > > > > I am still trying to quite my generator as much as possible. Has > > anyone tried adding a sound-deadening mat under the carpet and did you > > get good results? If so, what did you use? I am running out of ideas > > for working inside the gen compartment, figured this might be another > > option. > > > > Scott Forman > > 86 PT38 > > Memphis > > > |
10-09-2007, 08:27
Eric:
You got some pics of your installation, sound and muffler?? Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 8, 2007 8:28:54 AM Subject: [WanderlodgeForum] Re: Sound-deadening mat under carpet? Hello Scott, We installed an enclosed/fan cooled generator in our coach and then replaced the decaying foam insulation with new 1" thick sound insulation material on the interior of the generator compartment. Also installed a new pancake style muffler on the generator exhaust. We still hear a low roar when the generator is on but we can sleep with it on without a problem. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@... > wrote: > > I am still trying to quite my generator as much as possible. Has > anyone tried adding a sound-deadening mat under the carpet and did you > get good results? If so, what did you use? I am running out of ideas > for working inside the gen compartment, figured this might be another > option. > > Scott Forman > 86 PT38 > Memphis > Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com [Non-text portions of this message have been removed] |
10-10-2007, 11:22
Hi Bill,
I'll take some pictures tomorrow and post them in the photos section. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs wrote: > > Eric: > You got some pics of your installation, sound and muffler?? > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Eric Johnson > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, October 8, 2007 8:28:54 AM > Subject: [WanderlodgeForum] Re: Sound-deadening mat under carpet? > > Hello Scott, > > We installed an enclosed/fan cooled generator in our coach and then replaced the > decaying foam insulation with new 1" thick sound insulation material on the interior of the > generator compartment. Also installed a new pancake style muffler on the generator > exhaust. We still hear a low roar when the generator is on but we can sleep with it on > without a problem. > > Regards, Eric in San Antonio > 84FC35SBWL2 > > --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@ > wrote: > > > > I am still trying to quite my generator as much as possible. Has > > anyone tried adding a sound-deadening mat under the carpet and did you > > get good results? If so, what did you use? I am running out of ideas > > for working inside the gen compartment, figured this might be another > > option. > > > > Scott Forman > > 86 PT38 > > Memphis > > > > > > > > Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com > > [Non-text portions of this message have been removed] > |
10-10-2007, 14:20
I'm new to all of this and recently purchased an 83FC 35. I want to replace
insolation in dog house and generator compartment. I was reading a thread last night about lead/ fibreglss material that was used by one of the members. His report was that it was very effective. I hope to learn more before I choose the wrong stuff. Bill Garamella 83 FC 35 Manchester, NH > > 84FC35SBWL2 > > > > --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@ > wrote: > > > > > > I am still trying to quite my generator as much as possible. Has > > > anyone tried adding a sound-deadening mat under the carpet and did you > > > get good results? If so, what did you use? I am running out of ideas > > > for working inside the gen compartment, figured this might be another > > > option. > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > > > > > > > > > > Ask a question on any topic and get answers from real people. Go to Yahoo! > Answers and share what you know at http://ca.answers.yahoo.com > > > > [Non-text portions of this message have been removed] > > > |
10-11-2007, 04:55
I did my dog/cat house about 6k miles ago with a combination of foil/bubble
house insulation and duct liner used by the HVAC guys. Total cost was about $20. There is no heat radiating through the insulation on my (driver side) or my wifes side even after 10-12 hours of driving. If you want more info I will get it for you. Brad Bloxham 78FC 35' 3208NA [Non-text portions of this message have been removed] |
