oil type for 8v 92
10-08-2007, 06:46
oil type for 8v 92
Rob,
My comment was in response to the post that said:
> > Detroits use 40wt only!
> > Other Diesels are fine with 15-40 DIESEL RATED such as Rotella or
Delo.
My point is not ALL Detroits should use 40wt only (only 2 cycles).
And according to Detroit, SOME should use 15-40 (the four cycles).
1991 WB40 "Texas Minivan"
> My comment was in reference to Mr Rahn email with a signature of
88PT 40. I
> do believe all 88PT 40 require straight 40wt oil.
> On 08/10/2007, mbulriss <mbulriss@...> wrote:
> > Ummmm, oil..... always a controversial topic.
> > Just so we don't sow incorrect information for new users, I believe
> > what you meant to say was that Detroit Two-Stroke Diesels (series 53,
> > 71, 92, 149) are recommended by DD official publications to use
> > monograde (40 or 50 weight) oils above freezing temps.
> > Four Stroke Detroits are not recommended to use monograde oils per the
> > Detroit Diesel publication on ENGINE REQUIREMENTS — LUBRICATING OIL,
> > FUEL AND FILTERS:
> > 2.1.5 MONOGRADE OILS
> > Monograde oils, irrespective of API service category, should not be
> > used in on-road applications in any DDC 4-stroke engines or in
> > off-road applications in Series 40E, 50, 60, MBE 900 and
> > MBE 4000 engines.
> > At least that's they way I read their literature.
> > Mike Bulriss
> > San Antonio, TX - using Amsoil 15w-40 Heavy Duty Synthetic Diesel and
> > Marine Oil and not using any or slinging any
> > --- In
or Delo.
> > > YMMV, check with manufactor's site.
> > > Pete
> > > -------------- Original message --------------
> > > From: "Robert & Teri Rahn"
> > > It has been a couple years since I have changed the oil in our bus
> > > since we havnt been using it much. I forgot what type and how
much oil
> > > to buy. Seems like it was 8 gallons of chevron delo. Wal mart has a
> > > cheap fully synthetic oil, it is 12 dollars a gallon, does it make
> > > sense to use this or is it not suitable for diesels? They have 10 30
> > > and 5 30 I think. Thanks
> > > Robert Rahn
> > > Kalispell, Mt.
> > > 88 pt 40
> > > [Non-text portions of this message have been removed]
> Rob, Sue & Merlin Robinson
> 94 WLWB
10-08-2007, 07:04
oil type for 8v 92
Ok I thought you were referring to my post. Here is the info I got from DD.
It is spec 7SE270 0703 date 2007
2.2 TWO-STROKE CYCLE ENGINES
The lubricating oil requirements for On-Highway applications of Series 53,
Series 71, and Series 92 two-stroke engines are outlined in this section.
SAE Viscosity Grade 40
> Rob,
> Delo.
> Mike Bulriss
> San Antonio, TX
> "Rob Robinson"
> 88PT 40. I
> > > FUEL AND FILTERS:
> > > MBE 4000 engines.
> > > Mike Bulriss
> > > --- In
> or Delo.
> > > > Pete
> much oil
> > > > Robert Rahn
> > > > Kalispell, Mt.
> > > > 88 pt 40
> > 94 WLWB
94 WLWB
10-08-2007, 07:10
oil type for 8v 92
Pete, No problem! I just didn't want to hear about some newbie later
saying he read to only put 40wt in his series 60 on the
WanderlodgeForum! LOL!
--- In WanderlodgeForum@yahoogroups.com, PM7088@... wrote:
> Thank-you for the correction! Yes, old fellow that I am, I think of
a "Detroit" as a two stoke, happy to run in reverse and make a fool of
itself! I saw one die that way....
> Pete
> From: "mbulriss" <mbulriss@...>
> FUEL AND FILTERS:
> MBE 4000 engines.
> Mike Bulriss
Delo.
> > Pete
> > since we havnt been using it much. I forgot what type and how much
oil
> > Robert Rahn
> > Kalispell, Mt.
> > 88 pt 40
10-08-2007, 07:15
oil type for 8v 92
Hit the wrong button and sent only part of the info. Here's the whole quote
QUOTE 2.2 TWO-STROKE CYCLE ENGINES
API Classification CF-2
Lubricating oil for On-Highway applications for two-stroke cycle engines
must meet the following requirements:
a. 1.0% Ash Maximum as measured by ASTM D874
b. 7.0 TBN minimum as measured by ASTM D2896
c. 700 ppm zinc minimum as measured by ASTM D5185
At ambient temperature below freezing (0C (32F)), sufficient starter
cranking speed may not be achieved to start the engine with SAE 40 grade
oils. Where starting aids are not available or at very cold temperatures
(-18 to -32C) (0 to -25F) even if starting aids are available, the use of
multigrade SAE 15W-40 or monograde SAE 30 will improve startability. These
lubricants must possess a HT/HS Viscosity (measured by ASTM D 4741 or
equivalent) of 3.7 cP minimum. These oils must be replaced with monograde
SAE 40 lubricants as soon as ambient conditions permit. UNQUOTE
On 08/10/2007, PM7088@... wrote:
> Thank-you for the correction! Yes, old fellow that I am, I think of a
> Pete
> FUEL AND FILTERS:
> MBE 4000 engines.
> Mike Bulriss
> > Other Diesels are fine with 15-40 DIESEL RATED such as Rotella or Delo.
> > Pete
> > since we havnt been using it much. I forgot what type and how much oil
> > Robert Rahn
> > Kalispell, Mt.
> > 88 pt 40
> Yahoo! Groups Links
94 WLWB
10-08-2007, 07:24
oil type for 8v 92
Hey Rob,
Yeah, we're saying the same thing. Kind of funny that the DD link to
their lubricating standards on their Motorcoach front page is to their
older brochure from 2005 (7SE270 0510). In that one they list a
table in Section 2.2 that basically says 40wt preferred and 50wt
secondary.
Then they go on to say (in part):
3. For continuous high temperature operation (over 200° F or 93° C
coolant out), the use of an SAE grade 50 lubricant in DDC two-stroke
cycle Series 53, 71 and 92 engines is required. SAE grade 50
lubricants are also required for all Series 149 engines where
ambient temperatures are above 95° F (35° C).
4. At ambient temperatures below freezing (32° F or 0° C), sufficient
starter cranking speed may not be achieved to start the engine with
SAE 40 grade oils. Where starting aids are not available or at very
cold temperatures (0° F to -25° F or -18° C to -32° C) even if
starting aids are available, the use of multigrade SAE 15W-40 or
monograde lubricant SAE 30 will improve startability. These lubricants
must possess a High Temperature – High Shear Rate Viscosity (measured
by ASTM D 4741 or equivalent) of 3.70 cP minimum. These oils must be
replaced with monograde SAE 40 lubricants as soon as ambient
conditions permit. Do not use multigrade or SAE 30 grade lubricants in
two-stroke cycle marine engines or Series 149 under any circumstances.
Send me the link to the 2007 revision when you get a chance. Save me
from searching their site! Thanks.
from DD.
Series 53,
section.
> > Rob,
> > Delo.
> > Mike Bulriss
> > San Antonio, TX
> > --- In
> > "Rob Robinson"
> > 88PT 40. I
believe
(series 53,
per the
LUBRICATING OIL,
> > > > FUEL AND FILTERS:
not be
> > > > MBE 4000 engines.
> > > > Mike Bulriss
Diesel and
> > > > --- In
> > or Delo.
> > > > > Pete
our bus
> > much oil
mart has a
it make
have 10 30
> > > > > Robert Rahn
> > > > > Kalispell, Mt.
> > > > > 88 pt 40
> > > 94 WLWB
> 94 WLWB
10-08-2007, 09:12
oil type for 8v 92
That which I quoted I retyped from their actual manual titled "Detroit
Diesel Lubricating Oil, Fuel and Filters" and designated 7SE270 0703. This
manual is dated 2007. I checked their site at http://www.detroitdiesel.com and
didn't see anything that might lead me to this manual. I was given this
manual and another titled "Coolant Selection" (7SE298 Sept 2002) while at
an FMCA rally. It is interesting that they have dropped the info on SAE 50W
oil. I'd like to know why. Maybe next rally I'll remember to ask them.
> Hey Rob,
> secondary.
> Mike Bulriss
> San Antonio, TX
> "Rob Robinson"
> from DD.
> Series 53,
> section.
> > > Rob,
> > > Delo.
> > > Mike Bulriss
> > > San Antonio, TX
> > > --- In
> > > "Rob Robinson"
> > > 88PT 40. I
> believe
> (series 53,
> per the
> LUBRICATING OIL,
> > > > > FUEL AND FILTERS:
> not be
> > > > > MBE 4000 engines.
> > > > > Mike Bulriss
> Diesel and
> > > > > --- In
> > > or Delo.
> > > > > > Pete
> our bus
> > > much oil
> mart has a
> it make
> have 10 30
> > > > > > Robert Rahn
> > > > > > Kalispell, Mt.
> > > > > > 88 pt 40
> > > > 94 WLWB
> > 94 WLWB
94 WLWB
